#1 |
Are ET Streets considered Slicks?
Just like the subject...For NHRA rules are ET Streets considered slicks? I am almost ready to take my car to the track but need to know if I have to get all the extra stuff you need if you are running slicks. I will get it eventually but I am poor and on a budget.
-Aaron |
| Sponsored Links | |
Advertisement |
#3 |
do you mean, should I have a d/s loop? If so. YES
__________________
-John- 1995 Black Cobra Bolt ons/Street tires 13.049@105.80 12.96@104.96 on 17" et streets 11.93@117.01 1.68 60' n20 01 5spd Zinc Vert GT Sold 4/05 12.997@103.75 w/1.72 60' 13.467@102.84 w/1.97 60' on street tires @ 3600lbs race weight Pic and Mods |
#4 |
Trader Feedback: (22)
d/s loop
If you've got the cash to get through the gates at the strip you have enough money to buy a d/s loop. It's an inexpensive safety measure.
__________________
85 Capri GS (Under Construction) 82 Coupe. 302, Gt40's, Torker289, 3:73's (SOLD) 94 GT Lots a bolt on n gears |
#5 |
Driveshaft loop, extended lugs and more importantly (because the other stuff is cheap and gonna be quick in coming) I thought I read that with slicks you needed a blow-proof bellhousing...I could be wrong about that, maybe I should just buy the rule book. I don't plan on the housing until I figure out what trans I am gonna run for sure.
On a side note....Why doesn't NHRA make the rule book available in its entirety online? |
#6 |
i would just buy the safety stuff anyways. i wouldn't want a clutch coming through the floor boards.
the only thing i haven't picked up yet is the d/s loop and that is on the list for this coming year.
__________________
'91 GT: SOLD '04 GT: 4.6L, Ported Heads, Stg 2 cams, P-51, Precision 7175, T-56, 3.73's = a whole lot of fun. |
#7 |
Scattershield is when you are 11.49 and under, the extended wheel studs are necessary for a wheel like a weld that requires a non-stock style shanked lug nut-and even then the rule is that it has to thread the diameter of the stud into the hex portion of the lug. This isn't a problem if you are running a set of slicks or ET streets on a stock style rim.
__________________
2009 Candy-Apple Red Glass-Roof GT |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
