how fast with 7.5 rearend - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > Drag Racing
Old 02-10-2005, 08:08 PM   #1
like it says whats the fastest anyone's run with the 7.5. i have one thats a posi so i thought i might try it for a while. does it save any horsepower compared to the 8.8?
dt79 is offline
Old 02-11-2005, 12:43 PM   #2
Don't know for sure, I've heard of guys running bottom 11s on them, most likely with Autos. My cousin is installing some GT40 Y heads, exhaust, E303, weiand intake, 650 holley, and tuning. We're going to see how far we can push his 85GT with the stock 7.5 rear and stock gears with a stock T-5
__________________
Carl S.: 434ci, AFR 225s, Ported SuperVic, Dominator, Powerglide, 4.10s, 3000 lbs raceweight. 9.58@138 all motor, 5.68@122 nitrous!
Sponsors: My wallet, your company?
http://i269.photobucket.com/albums/jj77/carlrenee1/sigpic1-1.jpg
White90GT is offline
Old 02-11-2005, 12:51 PM   #3
AnthonyDalrymple's Avatar
Same thing I've heard; but have not seen in person. I would think, just like using an 8" versus the more popular 9" rear diff in the "older days; the 8" get's the job done up to about 300rwhp. Probably the same situation with the 7.5 versus the 8.8" More power than that.... It becomes a crap shoot.
__________________
'89 LX 'vert. 331 stroker, TKO600, 11.52@118.93mph; new motor in & looking forward to better times!
P.O.S '88 GT 'vert; barely saved from the junkyard
AnthonyDalrymple is offline
Old 02-15-2005, 11:20 PM   #4
I was wondering the same thing. I have a 7.5 T/L rear out of an 86 Turbo Coupe I am going to install in my Futura to start out with. Later it will be replaced by a 9".
Unless I have been ill informed, aren't the axles the same as 8.8 axles? The units look kind of puny, but I am not putting drag radials or slicks on right away, so I am hoping it will give me a summer's worth of use.
Anyone who has beat on one of these things hard, please chime in!
Thanks- L.W.
MONTsterLW is offline
Old 02-16-2005, 02:43 PM   #5
Had one in my 83 gt DONT dump the clutch at 5,000 took off 5 teeth on the ring gear.
forsale is offline
Old 02-16-2005, 05:47 PM   #6
red89coupe's Avatar
Trader Feedback: (28)
see sig.. I just added nitrous and it has taken the 75 shot with no problems so far It will be taking a 150 shot and we will see what happens but I think the reason mine wont break is beacuse I have a 8.8 ready to be swaped in when it does go
__________________
Turbonetics 62-1 on stock junk ran good...
red89coupe is offline
Old 02-16-2005, 05:53 PM   #7
red89coupe's Avatar
Thanks- L.W.
I have BEAT THE CRAP out of mine. it just seems to take it. I have broke 2 trannys,1 imput shaft and 1 second gear cluster but the 7.5 is fine so far. 100 timeslips,10,000 miles and 1000 miles of driving like I was trying to break it
I dont dump the clutch and I dont hook for crap with street tires. with STICKEY TIRES IT WILL BREAK.
__________________
Old 02-17-2005, 06:59 AM   #8
Trader Feedback: (143)
Thats the main thing, if you put tires to it or dump the clutch alot, it WILL break fast! I come from F-Bodys, they come with a d@mn 7.5 stock and it's a JOKE with a stick shift. If you can keep the clutch or tires spinning it will last a little while, take the fusable link out of the equation and blam!
Speeds8erM-1 is offline
Old 02-17-2005, 07:37 AM   #9
I broke the one in my old ranger with a 2.9 busted every tooth of the ring gear.
__________________
Nick L.
Nick L is offline
Old 02-22-2005, 07:54 PM   #10
90 Crustang LX's Avatar
What gears came stock in the 7.5's?
__________________
1990 Mustang GT 5.0, 5 speed, GT40s, 1.72rr's, B-cam, 1.5 Kenne Bell'ed and Nitrous'ed
1990 Mustang LX Coupe 5.0, 5 speed, some bolt ons and tube front end with coilovers
1972 Honda CB350 Four
Current project: 1931 Model A Ford tudor sedan, rat rodish with 2.3 turbo 5 speed
90 Crustang LX is offline
Old 02-22-2005, 10:37 PM   #11
red89coupe's Avatar
3.45 came in mine and seems to be pretty common.
__________________
Old 02-22-2005, 11:54 PM   #12
onesillynotch's Avatar
they last a while if they dont have a trac-loc..
__________________
1988 Notch...2.5T
5 lug cobra brakes, full MM CO, MM PH, MM TA, MM FLSFC, SN95 A-Arms.
onesillynotch is offline
Old 02-23-2005, 12:02 AM   #13
red89coupe's Avatar
I dont know
my trac-loc has seen many many passes and alot of street/highway miles. but I get NO traction,(2.1 60 foot ) NO dumping the clutch,NO crazy burnouts or anything like that.
now that I said that next time out its flying out the cover
__________________
Old 02-23-2005, 12:44 AM   #14
Rather B. Racin''s Avatar
Running a 7.5 w 4.10s and lincoln locked its been bullet proof for several years now on slicks.
__________________
If it wasn't for the last minute I'd never get anything done.
www.jsiskphotos.com
Rather B. Racin' is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
