going racing thurday, think i get my 11sec slip?? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > Drag Racing
Old 09-21-2004, 09:15 PM   #1
rob
rob's Avatar
been once with this setup and ran 12.3@109;
306, 10.5:1 cr, afr165's, rpm carb intake, wolverine 1087 cam, full exhaust, c4 trans, 3.73's, etc.....
i've added 4.10's and pulley's. expect 5-10 degree's lower temp and lot less humidity.
think i can do it? hope so.
reason for gear swap is i was going through traps at 51-5200 and car just wasn't in powerband.
__________________
1982 Ford Fairmont Futura H/C/I, fuel injected and turbocharged 10.67@128
rob is offline
Old 09-22-2004, 01:01 AM   #2
Well I'll route for you. What was your 60ft with that 12.3? How high is your stall? If you get a few runs in and it's optimum conditions I'll bet you'll get it.
__________________
91 LX 5.0 AOD
93 Eagle Talon TSI 5-Speed
xhaust50 is offline
Old 09-22-2004, 01:03 PM   #3
fke snk's Avatar
Good luck, it sounds like more MPH would definitely help. Very good time already
__________________
347/AOD on the bottle
TFS R intake, FTI cam, ported TW heads
fke snk is offline
Old 09-22-2004, 06:19 PM   #4
rob
rob's Avatar
high 1.7's for 60ft.
car really fell on it's face in 3rd with 3.73's. 1/8 mile was around 88 (can't find the slip). most with that 1/8th i've seen are doing 112 with n/a 302. hoping with the gear swap and the pulley's i can hit 113's and go through the traps at 6k or.
__________________
rob is offline
Old 09-22-2004, 06:24 PM   #5
WHAT STALL?????? I WOULD THINK YOU SHOULD BE THERE!
__________________
GOOD TRANSACTIONS::::VORTECD, mailbox, 93 Black Coupe, LSCRACER, asemaster, goldbomb69, 00SVTdubs, vibrant94gt, shmokinjoe, stangster, SICKBOY, robamus, DSG04GT venom
Unistang is offline
Old 09-23-2004, 09:32 AM   #6
Good luck tonight.
__________________
91 LX 5.0 AOD
xhaust50 is offline
Old 09-24-2004, 12:30 AM   #7
rob
rob's Avatar
3k stall (killing me off the line)
didn't get my 11. weather had been great past week till probably monday. tonight was lower 70's with 100% humidity.
best i could do was a 12.20@111 with 1.81 60ft. hopefully in a month or 2 ill get my 11. after tonight my new goal is 11.5. gonna strip this budget beater of everything.
__________________
rob is offline
Old 09-24-2004, 12:32 AM   #8
Blk88GT's Avatar
Work on your 60ft, nevermind stripping the car.
__________________
Ian
1962 Chevy II - 11.99 @ 115.72
1988 Mustang GT 418w/NX plate - 8.97 @ 150.46 on 275 radials (1.32 60ft)
Walls Rod Custom - Your One Stop Horsepower Shop
Blk88GT is offline
Old 09-24-2004, 08:50 AM   #9
fke snk's Avatar
Yep 1.6's will prob get you 11's
__________________
fke snk is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
