#1 |
Member
408 stroker, eagel crank & rods, JE pistons, BG Demon 750 carb mechanical, Luanti 51017 roller cam with 536* valve lift, Harland Sharp 1.6 ratio 7/16 stud rockers,Victor Jr. Heads & Intake fully ported & polished plus bowl blended, Pete Jackson gear drive, MSD Ignition & Distributor, BBK Long Tube creamic coated headers, BBK H Pipe no cats,MAC Pro Dumps exaust, FMS Aluminum drive shaft, Lakewood Bellhousing, Centerforce 11" clutch, Tremec TKO. Still to come: Paxton supercharger Should be pushing around 550 HP in a 1993 Notch, Nice!!! Thats racing! __________________ See ya in my rear view mirror!!!
__________________
See ya in my rear view mirror!!! |
| Sponsored Links | |
Advertisement |
#2 |
not to be a jerk, man--but you are bragging about 408 cubes and a blower making 550 hp?
__________________
'95 GT- 348" and a big cam "Timeslips tell you how fast your car is, not RWHP #'s. I've never raced a dyno in my life." |
#7 |
Thats a wussy cam for a 408" motor man..... I got more lift than that in my lil 306.... put a real cam in there and I'm really hoping you don't have the BBK 1 5/8" 302 headers on there with Victor heads... you'll be lucky to make 450hp. You need no less than a 1 7/8" primary with a big inch motor and a race head.
__________________
2003 BLACK SVT Cobra 2.76 Upper, Bassani X pipe, Flowmaster catback. |
#8 |
Everyone has to start off somewhere. When I started out over twenty years ago, I was the perfect example of " the bigger, the better it must be syndrome". My '67 mustang ran low 15's high 14's because nothing was designed to work within the same parameters.
Now look at my car!! Massive amounts of power everywhere in the power band!!! Oh yeah, I only used 1 3/4" headers and a conservative cam with good flowing heads. That builds something called TORQUE. I wonder what torque is good for? (refer to avitar to your left) James
#10 |
What's the duration of that Lunati cam? Are the headers 1 5/8" or 1 3/4" and what size is the collector? If it's 3" and you use a 3" exhuast system with a good muffler, you should be alright.
My cam was 244 in 256 ex @ .050" lift with lifts of .595" on both in and ex on a 112 LSA. It pulled hard to 6500 RPM's ran 10.40's at 132 MPH. James |
#12 |
LOL
This thread is hilarious.
__________________
Ian 1962 Chevy II - 11.99 @ 115.72 1988 Mustang GT 418w/NX plate - 8.97 @ 150.46 on 275 radials (1.32 60ft) Walls Rod Custom - Your One Stop Horsepower Shop |
#14 |
Mike: To post a pic of your car, just open this thread, make a reply and while you're making the reply, press alt+f4 on your keyboard.
__________________
1990 Ranger - 302 swap (planning stages) |
#15 | |
#16 |
Member
James,
The cam @.50 is 218/228, it also likes nitrous. By the way I also know that pressing alt+f4 closes windows, nice try CDP. James, how can I post a picture of my car. Thanks.
__________________
#17 |
Click POST REPLY at the very top-right corner of thread.
It will take you to a different page and it will have different options including uploading an IMAGE (IMG button in the middle of the page) that you can have on your hard drive. hth's ks
__________________
Kevin Slaby Read: Launching a Drag Car Read: Measuring Pinion Angle Read: Setting Zero Suspension Preload Diary of a 5.0 Mustang 79 Pace Car 302, 200hp N2O, Tremec, 9" w/ 4.11's 11.10 @ 122mph 60': 1.47 Stock Factory Control arms. 87 GN 12.05 @ 111, 1.60 60', 15psi launch Goal: To grow up and be Spiderman |
#18 | |
As far as the cam, that thing is incredibly small for a 408. It is relatively mild even for a 306. Your intake isn't matched very well to it. You'd be better off by selecting something with about 20 to 30 degrees more duration @ .050" lift. Those motors produce tremendous torque, but you'll have no top end power with that cam which would be better matched to a dual plane intake. I would switch cams; just trying to steer you in the right direction. James
#19 |
I agree that the cam is much too small for what you want to do.
I think Car Craft used this cam on a "build your first engine" article on a 302 with a holley street avenger top end and made 352 hp. On your engine with the nice heads I'm guessing 460hp@ probably 5500 due to the wide LSA, 112, but lots of torque down low. Other than that, it sounds like a nice build.
__________________
69 Roadrunner 70 Cuda 71 Demon |
#20 |
Member
Thanks for the cam lessons, although my car runs very strong, she has alot of torque too. Can you tell me what to expect after adding my Paxton Supercharger with 8 lbs of boost.
Thanks again ))
__________________
#21 |
you tell us..aparently you are teaching us a lesson here
lol @that killer 408 cam btw whats the compression of this beast..i mean you plan on 550 hp on motor then going to blow on it.. also you think a paxton for a 302 with a 8# pully is going to give you 8#s on a 408
__________________
1988 Notch...2.5T ![]() 5 lug cobra brakes, full MM CO, MM PH, MM TA, MM FLSFC, SN95 A-Arms. |
#22 | |
My car would spin the tires in third gear up to 70 MPH on the street. I originally had a 230 in 238 ex @.050" lift cam on a 114 LSA which did'nt have the power up top I wanted. I switched to a larger cam 244 in 256 ex @ .050" on a 112 LSA and picked up 2.5 tenths in the eighth without losing any power down low. My sixty foots consistently ran in the mid 1.30's with a best of 1.315; all on the motor, with a stock T-5. 408's are big motor and a cam that may act wild in a 306 will be tame in a 408. Basically, what I'm trying to say is you would definitely benefit from a larger cam. I'm not trying to blow smoke up your arse! As for the blower, same thing. They can only push a certain CFM of air. If your motor is already pulling in let's say 60-70% of the CFM rating of the blower naturally aspirated, the blower will not be able to support the CFM needed to produce the rated boost for the unit. Boost is a measure of pressure. Not to mention your combo is carbureated. James |
#23 | |
Re: Real Power
__________________
93gt...10.48 @ 128.19, 88 notch...10.98 @ 123, 90 triple black gt.......I need a hooptie.......
#24 |
550 HP from a 408 with a 536*cam...should be around 13.5 :1 compression with 116 octane gas...yea throw that blower on it and get back to us with some "REAL POWER".
__________________
Mike |
#25 |
I ran your combo through my engine analyzer and came up with :
495hp@ 5500, 485ftlb@ 4500. I used stock rod length of 5.956 since you didn't specify and a stroke of 4", bore 4.03", also I guessed at 10.5:1 compression ratio and stuck a 900cfm carb on it. Those are very good numbers for a small cam, indicating excellent head flow. I can't figure out this supercharging yet but I'll guess with 8psi on top of that you'll push over 600 hp at the flywheel. You'll need good gas though, if the compression ratio is that high.
__________________
#27 |
KillaCoupe, E.T. is the time it takes for a car to get from point A to point B, it's not what makes it fast.
A Dyno sheet is what a Dyno makes when measuring an engines torque. It is then converted to horsepower in the formula HP=TQxRPM/5252. Then you get the Horsepower curve along with the Torque curve. This in itself isn't worth much, but when combined with other variables such as vehicle weight, gear, tire size and traction limits, transmission efficiency, converter slippage and stall, Barometric pressure, humidity and temperature, one can make a fairly accurate guess as to how fast a car can E.T.
__________________
#28 |
Okay, I put a Paxton NOVI on the engine with a 2:1 belt ratio on it and a honking intercooler and I got 747hp at 5500 and 714# also at 5500, but even with 100 octane in it, the program still had to retard timing.
I lowered the compression ratio to 8:1 and you only lost about 21 hp with no supercharger and with Paxton it made 724hp and 691# again at 5500. The program said it was getting lifter pump up at 6000 so you might want to set the preload at zero lash.
__________________
#29 |
The combo in my sig made 600hp at the flywheel with a bigger better matched 252/262@.50 .576/.576 cam .
You will not make 550hp to the wheels with that combo.
__________________
04 Comp. Orange mach 1-Built by http://advancedenginedevelopment.com/index.html built short block ,new cobra heads,Ford GT cams,built 31 spline rear end,built 3650,Kooks lt,Kooks X-pipe,new K-member,17lbs of boost thanks to a Whipple 605rwhp 580rwtq 11.41@131.5mph |
#30 | |
If it dosen't make enough power change a pulley.....LOL.....I usually like a cam that about one size smaller than anyone else would pick out but lil 218@.050 isn't enough.....something 230 ish is about the smallest i'd get for a 408. And those vic jr's want more lift.
__________________
#31 |
did i miss something.... 550hp out of a blown 408? theres guys on turbomustangs.com making 550hp on stock 302 shortblocks. Do yourself a favor... run a meaner cam, and forget about the blower.... buy yourself a T88 and then make some REAL power, then after you go to the strip and stomp on it and **** yourself... then come back again and ask us "how do i control my beast"
#33 | ||
__________________
#34 | |
__________________
#35 | |
__________________
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
James
James
Linear Mode
