WHat's the best oil for drag racing? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 09-26-2003, 08:43 PM Thread Starter
I just broke in my 392 w frpp crate motor.
It has 20w50 in it(thats what was in it) And they say to use natural or synthetic 20w50 after the break in cycle. Do I really need that thick of oil? The car will be race only and trailered.
I want to use synthetic just because It's a personal preferance.
Any advice? Thanks
p.s. It ran 11.75 on drag radials! I'm pretty happy.
jmac5032 is offline
post #2 of 11 Old 09-26-2003, 08:53 PM
My builder set mine up for Valvoline 20W-50 racing oil. I would use what ever your builder recomends.
Rex
2013 GHIG Mustang GT
385hp/372ftlbs
12.89@111.8mph 2.0 60ft
REX347 is offline
post #3 of 11 Old 09-26-2003, 09:18 PM
90LX's Avatar
I've had excellent results with Royal Purple. I use the 20W-50 street blend, not the all out race belnd with oxygenators that are used up in 6 runs. I check the bearings at 150 passes and they looked like I just put them in. I could still see the bore guage marks from where I measured them. At 300 passes, it all comes apart for new aluminum rods, rings, etc. Bearings still look great at 300 runs.
90LX
13.875 @ 98.33
S/C 2327
7.89 @ 166.5 1/4mile
4.95 @ 141.2 1/8mile
90LX is offline
post #4 of 11 Old 09-27-2003, 02:31 PM Thread Starter
jmac5032 is offline
post #5 of 11 Old 10-17-2003, 11:56 PM
I'd shy away from synthetics because there mainly designed to hold there viscosity at high tepature. Not that big of a problem for an engine that runs hard for a few minutes at a time. Synthetics also give up some of thier (slipperyness) in order to be more heat resistant. Thus the ban at break in. Anyways thatstheconcensous from the machinists I hang with. Hope it helps!
goin fast
mac 520 is offline
post #6 of 11 Old 10-18-2003, 09:16 AM
I run regular 10w30 from walmart. Costs $1/litre. I change the oil after every race so its not a big deal. I run a 393W,I wouldnt worry so much about break in, my break in consistent of 20 minutes of idel to get up to temperature, a few burnouts behind the shop, drove it home, droped the oil. Drove it to the track the next day. Had no problems what so ever. Ran 9.82@140 2 weeks ago. Good Luck.
93 LX, stock suspension, true 10.5s, 3000lb race weight, 396 ci sbf= 8.24-170 on one fogger
WhiteStangRacing is offline
post #7 of 11 Old 10-19-2003, 11:58 PM
Fomoco347's Avatar
WhiteStang, i just bought 5 quarts of Supertech 20w/50 at Walmart for $4.18. Do you really change it after every race? What oil pressure are you guys seeing? Mine is about 50 at idle, and about 70-75 WOT in 3rd. Is that too low for 7k?
Pat
nashootout.com
MCRP.us
Fomoco347 is offline
post #8 of 11 Old 10-20-2003, 02:27 AM
I was alway told that the rule of thumb about oil pressure is 10psi per 1000 rpm.
so going by that .....
O.G. X275 racer
1.17 60' 5.29@131 with the angry peanut!
1.16 60' 4.85@147 on 1 gun (In testing)
88gtguy is offline
post #9 of 11 Old 10-20-2003, 03:10 AM
Fomoco347- 70-75 is prefect for 7000RPM.
What oil pan are you running?
post #10 of 11 Old 10-20-2003, 04:22 PM
Fomoco347's Avatar
WhiteStang-----Canton 7 quart
nashootout.com
MCRP.us
post #11 of 11 Old 10-20-2003, 07:02 PM
saleen_n_around's Avatar
I set up my 347 with 22-thousandths clearance and it is running 80# at idle with 5-w30 Kendall GT-1 in it. I just swtiched it out to 5w-20 Ford Synthetic. I am running an HV pump with a Canton 7qt T-Pan using 6 qts. I am concerned with that high of a pressure, because with the thicker grades of oil, you are building heat. I don't like it that high to start with, in a light grade oil. Oil pressure is nothing more than hydraulic resistance. and with a thicker oil, you're building higher pressure more resistance and more heat with that resistance. I bet if you cut back in oil weight, you'll have comparable pressure with a cooler running temp.
Ron Turransky
NMRA EFI/Ren# 4150
NMRA SSO #8 Crew
Support our sponsors Matukas Motorsports Race Cars, Vincent Performance, Nitrous Express, Vortech, Brodix, Kooks Headers, Holcomb Motorsports, NGK Spark Plugs, PA Transmissions, Pro Power, Racecraft Inc, Total Engine Airflow, UPR Products, VP Fuels & Weld Racing
saleen_n_around is offline
