Drag tires for Pony rims - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > Drag Racing
Old 02-01-2003, 04:06 PM   #1
4play's Avatar
Location: S. TX small town "we only have one working traffic light"
I have extra pony rims & want to get a set of Drag tires for them.
I would like to be able to drive them on the street to & from the track sometimes. (there is an 1/8 mile is on my way home from work). I would like to occaisionally drive the car to work & race it on the way home. What would be the best choice to get? or how much would I be giving up to slicks? I can also use 10holes if 15's are really that much better.
Approx 300rwhp, 3300lbs with driver, 5speed, 4.10's, 4cyl front springs, V8 rear. No quad shocks, boxed upper/aftermarket lower control arms.
The car has run 112-113 in the 1/4 by a Vericom & a G-tech spining some in 1st & second (hey! it's all I have right now )
__________________
Currently Mustangless
4play is offline
Old 02-01-2003, 06:30 PM   #2
cleanLX's Avatar
Location: Phoenix AZ. by way of Fredericton, NB, Canada
26 x 11.5 -16 Mickey Thompson ET Streets.
255/50-16 BFG DR's.
245/50-16 Nitto DR's.
__________________
Mike H.
'92 deep jewel green coupe, MAM, clutch, full exhaust, gears, u/d's, air bag - otherwise, factory original.
12.960 @ 104.012 w/ 1.73 60' (2600 d/a)
new combo in the works; 306, ported E7's, Buddy Rawls cam.
cleanLX is offline
Old 02-01-2003, 06:40 PM   #3
4play's Avatar
Do the 11.5's clear the car ok?
How much am I giving up over true slicks?
__________________
4play is offline
Old 02-01-2003, 06:45 PM   #4
cleanLX's Avatar
you'll probably need to flip your quad shocks.
depending on how well your cat back fits, and what your rear suspension consists of, you'll likely have rubbing on the exhaust when turning aggressivly. If you are pan hard bar man, or have really good turn oriented control arms, you may be fine.
__________________
Mike H.
cleanLX is offline
Old 02-02-2003, 03:07 AM   #5
maverick0716's Avatar
11.5 inch tread on a 7 inch wheel? I put a 10 inch slick on my 10 hole wheels and there was WAY too much bulge for my liking. The tread was completely rounded, not semi flat like it should be
maverick0716 is offline
Old 02-02-2003, 09:38 AM   #6
Member
11Sec_Lx's Avatar
This is somewhat off topic since he's looking for 26" tires for Pony's but....
Mickey Thompson either just released or will be releasing soon ET Streets for 16" wheels in a 28" tire height. I beleive they said they would be 11.5's and 12.5's. Also, 17" wheel sized ET Streets are coming down the pipe as well, in 26" and 28" sizes. I talked to them last week. I would really like to try some 26x11.5x17's on some of the 'not yet released 17x9 Pony R's'!!!!!
11Sec_Lx is offline
Old 02-02-2003, 11:42 AM   #7
There is also a 26x10.50x16 ET Street. By the dimensions it would be a near perfect fit on a stock rim. If you need a wider tire, I'd seriously think about a wider rim.
TC86GT is offline
Old 02-02-2003, 11:47 AM   #8
Bill Viverette's Avatar
11.50 ET Streets
Remember, the 11.50 on an ET Street does not mean 11.50 tread width like it might imply on an ET Drag (actually that varies by size as well).
The tread on a 26x11.50-16 ET Street is 9.7" and the sidewall is 10.8":
http://www.mickeythompsontires.com/strip.html
Bill
Bill Viverette is offline
Old 02-02-2003, 03:00 PM   #9
cleanLX's Avatar
exactly.
__________________
Mike H.
cleanLX is offline
Old 02-02-2003, 03:44 PM   #10
4play's Avatar
Thanks!
How much would I be giving up to ET drags? & what size ET drags will fit properly?
__________________
4play is offline
Old 02-02-2003, 04:25 PM   #11
cleanLX's Avatar
From what I've seen and read, 0.03-0.05 in the 60'.
I dunno what size drag will fit. I would not run a drag on the street, too soft, and sidewall is too weak, and the Et streets are bad enough in the damp, I'd not want to deal with full on slick.
__________________
Mike H.
cleanLX is offline
Old 02-02-2003, 04:39 PM   #12
4play's Avatar
I'm not thinking of driving slicks on th street, I'm wanting to have my cake & eat it too I jut don't want to give uo too much on the track because I'd like the ability to drive them occaisionally.
Thanks!
__________________
4play is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
