417 Motorsports tube front end - Ford Mustang Forums : Corral.net Mustang Forum
 14Likes
post #1 of 42 Old 01-29-2017, 01:14 AM Thread Starter
Was looking to get a custom tube front end and most places quoted me $1500+. 417 motorsports has this priced at $750, full chromoly with fender mounts (which was a must for me). I have little experience in this type of thing, this was the first time I had ever drilled out a spot weld even.
It was surprisingly easy. Blake, the owner, is easy to get ahold of to ask questions.
Things I'm doing that others might not... welding a plate where the factory upper crush area meets the tube front. Relocating the radiator further back from OEM. I'm also adding a bar to the front frame rails to support the fender/a2a intercooler.
Keep in mind, You'll have to put hood pins or something of the like in since factory hood mount will be deleted.
Lastly, its light. The box the tube front came in weighed 25lbs. They claim a savings of over 63lbs if you include the factory crash bumper.
92FiveOGt is offline
post #2 of 42 Old 01-29-2017, 05:55 AM
I will be looking for updated pics as you progress and put it back together. What was your old setup like?
I have contemplated going this route to clean up my engine bay even more and to help with packaging...might even use that as an excuse to change my hotside around for a front mount a bigger turbo, no intercooler (meth instead) and side bumper exit downpipes.
kbscobravert is offline
post #3 of 42 Old 01-29-2017, 10:53 AM Thread Starter
Well I'm completely changing it up. Old setup was a 331 with small twins.
Now doing 4v 5.4 with a s480
I want the turbo up high in the passenger wheel well so I can run an exhaust out back (no fender exit for me) and I wanted space up front to put a big a2a with as little cutting to bumper as possible.
post #4 of 42 Old 01-29-2017, 04:04 PM
StalkerStang's Avatar
Also curious.... I have no experience with stuff like this either. Looks to be nothing there anymore..... I don't see how you can mount anything to it lol.....
90' LX________________2011 GT Premium, DD, manual
Previous 4 cyl.__________Brembo Package, Borla ATAK system
427W, in the works______JLT Intake, Tuned
StalkerStang is offline
post #5 of 42 Old 01-30-2017, 11:21 AM
SRTthis798's Avatar
Trader Feedback: (15)
i cant wait to get my car back and order one of these from blake! i really like the look of his set up over the hazard fab set up
DT Racing and Fabrication
Crew Chief
HOME OF THE FASTEST X LEGAL SVA 302!
my car-88lx...time to go nucking futs with it!
SRTthis798 is offline
post #6 of 42 Old 01-30-2017, 11:59 AM Thread Starter
The hazard fab one looks nice, but I'm not a fan of how far they move the top bars in so they could mount off the strut tower.
post #7 of 42 Old 01-30-2017, 12:18 PM
SRTthis798's Avatar
exact reason i like the 417 over the hazard...
Crew Chief
post #8 of 42 Old 01-30-2017, 01:13 PM
Can you shoot me a couple of pics of the 417 setup?
I am concerned about not using the strut tower plates like Hazard uses. BUT, the 417 gives you tons more room. I don't even think Hazards would clear my turbo and down pipe stuff.
It looks like there is a vertical plate that covers the hole in the upper rail from the cut, but is there a bottom plate with a bolt that runs through it to help hold it up that is also welded too? I can see it in their photos on FB but it doesn't give a lot of description.
The lower core support I assume is in the stock location, but they ship this thing in pieces (got pics of it before install) and it looks like their lower slides over the main tube rails with a sleeve that also has the tab for the upper support welded to it. Can you shoot me a pic of that area? I would need to move my lower back about 1-2" to account for my radiator being canted into the bumper cover on my car. I wouldn't be using the upper radiator support for a radiator, it would hold my Air/Water intercooler.
post #9 of 42 Old 01-30-2017, 04:51 PM Thread Starter
Yes, there is a bottom plate. As you can see in this photo, I accidentally cut 1/4" too much from this side so I'm putting a piece of steel on the end to weld the 417 plate to.
I dont have any before pics, and I'm away from my garage for 2 weeks. It comes in 4 pieces. 2 frame rails, the lower radiator support and the bolt on upper support. I drew this on my phone, haha.
The slip joint buts right up to the upper frame rail.
lk
TM50 likes this.
post #10 of 42 Old 01-31-2017, 10:24 AM
that explains it perfectly
what kind of instructions does he give you so you know where to cut.
As soon as he offeres a 94-95 (should be same as his 98up) I am going to go this route.
post #11 of 42 Old 01-31-2017, 12:46 PM Thread Starter
No instructions. The spot weld seam is where you separate on the inside, so I measured from the bolt hole to the plate and hit it spot on passenger side and 1/4 off driver.
Doing it again, I'd completely drill out spot welds leaving the OEM fender support understructure attached and then cut. Then you can see where line is from inside.
post #12 of 42 Old 02-02-2017, 02:24 AM
ZSR
Zach
ZSR's Avatar
Looks really good. I like it. Weight savings and more room=win/win
ZSR is offline
post #13 of 42 Old 02-02-2017, 05:04 AM
Thanks for the reply. I saw some other pics on their FB page that also explains the folded under tab at the upper rails.
As soon as they can confirm a 94-95, I am gonna purchase it. I will be doing the install in my garage with my little Lincoln 180 myself. This will deffinitely be a nerve racking task. I've done some welding, built my own 4" dp, went tubular lower core support and other little things. Heck, I have a dozen spot rivet drill bits new in a box to use. Certainly I can install this too. Just gonna measure a thousand times before cutting.
Please keep this thread going with pics of your progress along the way.
post #14 of 42 Old 02-10-2017, 10:28 PM
Throttlejunkie-13's Avatar
Any updates, pictures on this front end install? I'm really looking forward to seeing the results. Thank you.
Throttlejunkie-13 is offline
post #15 of 42 Old 02-10-2017, 10:45 PM
Saleen414's Avatar
He said on Jan 30th that he was going to be away from the garage for 2 weeks, that would suggest that it will be Feb 13/14 before you can expect any update. Today is Feb 10th, so maybe by next Wed you will get an answer.
26 X 8.5 Hoosier
Best 1/4 mile time 8.623 @ 159.82 mph with a 1.34 60' (5.55 1/8th at 128)
Best 1/8 mile time 5.384 @ 130.75 mph with a 1.29 60'
2001 V-6 5 speed Mustang 189k miles and counting
08' Bullitt #4097 N/A 325 RWHP <<<<<FOR SALE!
Saleen414 is online now
post #16 of 42 Old 02-11-2017, 01:18 AM Thread Starter
I should have an opportunity to do some work on it tomorrow.
post #17 of 42 Old 02-11-2017, 11:45 PM Thread Starter
Got my plates welded in.
Everything is tac'd in, but leaving rest to a more skilled welder.
TM50, StalkerStang and SRTthis798 like this.
post #18 of 42 Old 02-12-2017, 10:31 AM
GilroyRacing's Avatar
Trader Feedback: (111)
Looks good
91 Fox
R.I.P. 347: 1.43 60' 6.78@101.30 1/8th 10.64@127.84 1/4
302 1.59 60' 7.63@88.19 12.06@110.58
GilroyRacing is offline
post #19 of 42 Old 02-12-2017, 10:57 AM
Damn ,that looks good
post #20 of 42 Old 02-12-2017, 08:18 PM
Thanks for the update. Keep them coming please.
post #21 of 42 Old 02-13-2017, 07:46 PM Thread Starter
Blake just posted radiator mounts for this kit on his facebook.
TM50 and Cantbuyitright like this.
post #22 of 42 Old 02-21-2017, 10:03 PM
Trader Feedback: (33)
Thanks for posting this up. Very helpful. Your car looks great. I just ordered one for my 04.
92FiveOGt likes this.
TM50 is offline
post #23 of 42 Old 02-27-2017, 02:50 PM
SRTthis798's Avatar
so how hard was it to weld to the factory sheet metal in the fenders?
Crew Chief
post #24 of 42 Old 03-18-2017, 02:09 PM
1995gtCPE's Avatar
Trader Feedback: (34)
I demand an update!!!
80 coupe, A4 347, Bullet hyd roller, ported 11r 190's, ported Super Vic, HPI e85 carb, Liberty TKO500/4.30
1995gtCPE is offline
post #25 of 42 Old 03-19-2017, 02:57 AM Thread Starter
Car is out at a chassis shop getting a cage. Anything in particular you would like to see?
post #26 of 42 Old 03-20-2017, 09:52 AM
What are you going to do for a downpipe/exhaust? I havent lopped the front end off yet, doing a similar setup with the same turbo. Pondered that position but figured the outlet for the downpipe would go straight into the tire and not have enough room for the actual pipe.
Scott
89 GT-S Trim, TFS Highports, etc. Engine part out. See my for sale ads.
12 GT Premium-Grabber Blue
BoostedOne is offline
post #27 of 42 Old 03-20-2017, 11:55 AM Thread Starter
I'm planning on going over the tire and down under the car.
post #28 of 42 Old 03-20-2017, 12:43 PM
SRTthis798's Avatar
little different turbo placement but we run a 4" pipe up over the tire in the fender. you can also get 4" oval pipe in steel. if you want a ton of clearance
File Type: jpg 17218580_10212575976860727_8182980531599758038_o.jpg (98.0 KB, 63 views)
Crew Chief
post #29 of 42 Old 03-21-2017, 01:38 PM
Oh thats awesome. What are you doing for radiator(s)? And will it handle street driving like a true street kind of deal?
Scott
post #30 of 42 Old 03-22-2017, 08:07 AM
SRTthis798's Avatar
None any more... We use to run dual vw style radiators. One was in each corner behind the head lights. But we changed that when we moved the intercooler to the front bumper. It's not a street car anymore. I think we could put radiators back in it if we ran M1 but it's not a realistic option with it making more boost and more cylinder pressure compared to what we already have
post #31 of 42 Old 03-22-2017, 12:30 PM
TomR's Avatar
I'm amazed at the cost and work for just a few pounds of weight. I'd only do a tube front end for room.
89 LX. 363, single turbo S482 FMW, Super Vic EFI, Fox Lake Stage III heads, solid roller, glide. Holley HP EFI. (combo varies)
TomR is offline
post #32 of 42 Old 03-22-2017, 12:40 PM
Nice!
In the very first picture - I would love to know the weight of that chunk of metal sitting on the ground.
Just really like to compare the (cut off) unibody frame weight to the 417 Motorsports tubing weight. Somewhere on their Facebook says it weighs 17#. Looking for apples to apples...
Thanks!
93GT - NOVI2000, Twisted Wedge Heads, E303, Bolt-on Car
93 Coupe - Project Car - 100% gutted - 9.99 Goal
Wolfe framework & 10pt moly cage, TeamZ & Strange Suspension, Minitubs
EFI 438w n/a, E-85, solid roller, C4, 4.10's
EAR2EAR is offline
post #33 of 42 Old 03-22-2017, 02:37 PM
Fast895ohstang's Avatar
Tom i agree about the space gained. The weight savings is just a nice plus to add. Either way it looks like a very nice set up and ive looked into doing it as well.
TomR likes this.
2001 Bullitt Mustang GT 13.5@101 stock...need to run with the new setup 4.10s, bigs and littles, and prochamber
1989 Mustang Lx 5.0 - under the Knife...70mm turbo build
2015 F150 - 5.0 FX4 Sport
Fast895ohstang is offline
post #34 of 42 Old 03-22-2017, 10:48 PM
y2k02's Avatar
Mine is a 02 and the front I cut off like pictured was 44lbs. The 417 unit was 17lbs.
2002 2v TF heads Logan Intake NA SVT Cams
Twin 60mm Turbos TH400 Holley Dominator EFI
y2k02 is offline
post #35 of 42 Old 03-23-2017, 12:25 AM Thread Starter
Originally Posted by EAR2EAR View Post
Nice!
Thanks!
I don't have a scale at the house, but I'd guess it's ~40lbs. I'll see what i can do.
