Do I need to switch to a 26 inch tire - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > Drag Racing
Old 06-25-2012, 01:22 PM   #1
306 89LX's Avatar
Hey guys I have a set of 28 10.5 et drags I went to the track and went slower then last year since I swapped in an automatic and kept my 373s I didn't have my transbrake hooked up then but I got that squared away along with some other issues I found with the car I have since swapped the 373s out for 410s and was told by a few people to get rid out my 28s and get a set of 26s what do you guys suggest any help would be great thanks in advance chris
Sent from my SPH-D700 using AutoGuide.Com Free App
306 89LX is offline
Old 06-25-2012, 04:25 PM   #2
gray86hatch's Avatar
Trader Feedback: (81)
Only reason to switch them is if you need more RPM at the finish line or they don't fit on the car.
You need to give alot more info to get anymore help than that.
what is the converter. The wrong one can slow you down a bunch.
Tim
__________________
86 mustang
418 FTI LS3 Mast intake FTI hyd roller Holley EFI 275 MT Pump gas 93 oct.
9.53 140.73 1.33 60' 6.05 113.58
HR Drag Week 2007 SB-NA Runner Up with help from My wife and daughter's 2 www.flowtechinduction.com www.boozebrothersracing.com
gray86hatch is offline
Old 06-25-2012, 05:58 PM   #3
306 89LX's Avatar
Its a 306 short block f cam 1.6 roller rockers gt40 upper and lower tubular 1inch spacer world product iron heads aod with lentec vb shorty headers with or h pipe and minor suspenion work
306 89LX is offline
Old 06-25-2012, 09:29 PM   #4
306 89LX's Avatar
And a 3200 stall convertor
306 89LX is offline
Old 06-26-2012, 03:14 PM   #5
306 89LX's Avatar
It also gets a shot of spray from time to time between 125 to 175hp
306 89LX is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
