9.xx is it possible???? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > Drag Racing
Old 09-15-2011, 06:56 PM   #1
9.xx is it possible???? Upate....
So I'm wondering if theres a 9.xx pass in this car. Let me know what you think...
car weighs about 2800 lbs with me in it
306, ported edelbrock heads, vic intake, tfs3 cam, 4800stall converter, 3.73 gear, 28 in tire, 100 shot of spray
foot brake to 1500 and hammer the gas on the yellow, it goes 1.4x 60ft and 10.71 at 129mph on a 100 shot
Add in a transbrake up to about 3000-3500 and come off the brake spraying a 150 shot, think it has the nuts to go high 9's
what do you guys think????
daves80capri is offline
Old 09-15-2011, 09:15 PM   #2
COP_STANG's Avatar
Trader Feedback: (25)
.70 is lot of time to kill
COP_STANG is offline
Old 09-15-2011, 10:11 PM   #3
your 100% right but, the car runs 12.3 with the nitrous tune not spraying. So it picks up 1.5 s with a 100 shot.
So .70 would be reasonable with a 50 shot one would think. And probably pick up a few coming off the t-brake instead of foot brake.
Old 09-15-2011, 10:18 PM   #4
Nutzz's Avatar
Trader Feedback: (36)
No I dont think it will. But it might with a 200 !! Try a progressive? Faster you go harder it is to gain a .010th. Good luck
__________________
TOO_NUTS Racing
N/A- Pump Gas- 408 Clevor - 9.81@125.70 lifting.
Best 60ft on stock type suspension 1.29 UPR UCA/ Megabyte lowers/ stock anti roll bar. No battle boxes!
Nutzz is offline
Old 09-15-2011, 11:56 PM   #5
You're not going to get it with what you have listed. It's going to need more sauce.
__________________
O.G. X275 racer
1.17 60' 5.29@131 with the angry peanut!
1.16 60' 4.85@147 on 1 gun (In testing)
88gtguy is offline
Old 09-16-2011, 01:43 AM   #6
87coupe50's Avatar
Trader Feedback: (21)
with your current MPH (and mine) it should already be in the low 10's. I know I'm slow on the 60" and up to the 1/8th (slow shifting) but you've got a decent 60'. You might need to analyze your slip to figure out where you're slow and work on that. Then your additions should put you in the 9's.
__________________
Retired Army
'87 Notch: Coyote swapped!
'90 Notch: stock 302 with a blower, AOD, Moates Quarterhorse
87coupe50 is offline
Old 09-16-2011, 08:25 PM   #7
NASTY5.0's Avatar
more spray should get you there
__________________
Joel B
Carbureted 349 with Afr 205s, Funnelweb intake TKO600 and some spray.
9.41@145 @3250
http://www.youtube.com/watch?v=QhVEP_epiHY
NASTY5.0 is offline
Old 09-17-2011, 01:15 AM   #8
chvyeter's Avatar
Probably have to end up spraying 250 shot to get you there.
__________________
8.0 @ 88 on motor, old 306
7.0 @ 100 on new engine combo
6.4 @ 108 letting out twice on bottle.
11.2 @ 126 in 1/4 on motor
chvyeter is offline
Old 09-17-2011, 09:30 PM   #9
went to the track today and picked up 3ths leaving off the brake. Went 10.40 at 132. Still only 100 shot. Back again tommorow and I'll try 150 shot if eliminations dont run too long.
Old 09-17-2011, 09:33 PM   #10
My only issue with that is the motors got a hyperutectic piston in it. I'd like them to stay where they are. Maybe a piston and rod upgrade is needed for next year. probably up the compression to about 12:1 or so.
Old 09-18-2011, 10:25 AM   #11
i would'nt go no more than a 150 with those hypers.
__________________
87 GT, Keith Craft Racing 427 Dart
2003 mach1, garage queen
acproxer is offline
Old 09-22-2011, 10:40 AM   #12
132 mph is getting it done with that combo for sure. The extra 50 shot will help in the sixty foot department if you are already hooking that is. I think you will be borderline 10.00s-10.10 or so on the 150 hit based on what you have run so far. Get some more weight off the nose and get it to hook better and you just might get there.
__________________
Carl S.: 434ci, AFR 225s, Ported SuperVic, Dominator, Powerglide, 4.10s, 3000 lbs raceweight. 9.58@138 all motor, 5.68@122 nitrous!
Sponsors: My wallet, your company?
http://i269.photobucket.com/albums/jj77/carlrenee1/sigpic1-1.jpg
White90GT is offline
Old 09-22-2011, 11:39 AM   #13
COP_STANG's Avatar
that's pretty damn good
Old 09-23-2011, 07:06 PM   #14
thanks.
I was kinda thinkin the same thing. Car hooks pretty good for what it is, never spun the tires off the line yet.
I come off the brake on spray thanks to the way i have it wired. As soon as the brake releases, the nitrous sprays providing its WOT
Eliminations ran late so I never got a chance to hit it 150 but i will be back oct 14th weather permitting and we shall see.
Not too sure what more I can do for weight at this point, rebars are gone. tube rad support, tubular k member, etc etc
Car tips the scales with me it at 2750
Im a portly 155 lbs after dinner and a shower
Old 09-23-2011, 07:07 PM   #15
thanks
Old 11-06-2011, 10:08 AM   #16
well did it, sort of, not a 9 sec slip but in the right zone.
went out on oct 30 and ran 6.26 @ 111 mph
supposed to be good for a nine sec 1/4 mile pass
Old 11-06-2011, 07:14 PM   #17
what is the 1/8 mile et and mph on motor, also which edelbrock heads do you have and what size shot did it take to do this. thanks
Jarred Hodges is offline
Old 11-06-2011, 07:41 PM   #18
it can be done....i knew youd pick up a lot leaving on the brake too. that mph of 129 is good for 30's, 40's. hyper pistons are no good on spray and if you have a stock block id upgrade that too with the rods and pistons.
id hate to see you grenade and possibly tag the wall or worse. literally......cause i run osca too so id probably see it happen. see you at the races buddy....its a long winter
also...see my sig.....thats why i say you can hit 9's on a 150-200 shot.
__________________
85 GT-302ci,svo j302,victor jr intake,demon 650,hyd roller cam,T5,4.10,26X10S,2785lbs
11.56@118+MPH.....1.49 60' ALL MOTOR!!!
10.70@124+MPH.....70HP plate,c4,28X9@2850lbs
PSP Race Team.....CREW 1320
nick5oh is offline
Old 11-07-2011, 06:50 PM   #19
not too sure I'd have to check one of my time slips.
Heads are edelbrock rpm's, ported and polished by PSP racing.
I had 150 shot jets in it for that pass.
Old 11-07-2011, 06:56 PM   #20
Thanks.
I was a little worried about hitting it with 150 too, but it worked, and still runs, so I cant complain.
Already been talking to Paul about a 351 W based motor, maybe a stroker, Hopefully Santa will bring the wife what she want so I dont have to pay for it.
It was a fun year tho, getting my feet wet in O/C and 10.90, first year with this setup in this car, gotta get a little more consistant with the trans brake and hopefully 10.90 will thin out next year.
See ya at the track next year
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
