What size skinnies (wheels) needed to clear 13" cobra brakes? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > Drag Racing
Old 08-06-2010, 12:04 PM   #1
Bishop's Avatar
Question What size skinnies (wheels) needed to clear 13" cobra brakes?
Can you run a 15" diameter with a spacer? What size backspacing?
THanks
Keith
__________________
94 GT Vert
DART Block 347 ~ Vortech S-trim ~ AFR 185's ~ Aeromotive Fuel System ~ 55lb. injectors ~ AFM PMS ~ SMC Alky inject.
657 rwhp; 628.5 tq
My Pics...
Stang #1(rear)
Stang #2(top)
Stang #3(engine)
Tow Vehicle: 04 V8 Touareg
www.kockyproducts.com
Bishop is offline
Old 08-06-2010, 03:18 PM   #2
Formerly eades5.0
4Jenna's Avatar
Bogart offers 15x4 front runners with a spacer welded to the wheel which clears 13" brakes.
__________________
WWW.JENNABEARSFOUNDATION.ORG
4Jenna is offline
Old 08-06-2010, 06:19 PM   #3
Stopsign32v's Avatar
Trader Feedback: (15)
You could get some Greg Weld 17x4.5 wheels. They clear and cost $99 each right now.
__________________
03 Mach 1 5 speed gears, RAI, catback, shifter
Stopsign32v is offline
Old 08-06-2010, 09:37 PM   #4
Get 1" bolt on spacer and and 15"wheel should work.
__________________
95 GT-306,S400sx 80mm,glide,E85,275's
95 Cobra-stock huntin a vortech
TRmustangTR is offline
Old 08-06-2010, 10:23 PM   #5
And stick out like a Mexican car.
__________________
Old 08-13-2010, 12:06 PM   #6
Formerly known as 20thAniv
Unatural's Avatar
Here's what the Bogarts look like that are made to clear Cobra brakes.
These are pictures of how they fit with factory length A arms and then with 1" shorter than factory A arms.
__________________
Wayne
'91 LX Hatch
Single turbo
http://forums.corral.net/forums/turbochargers/1379238-unaturals-diy-build.html
Unatural is offline
Old 08-13-2010, 01:15 PM   #7
2 cam sam's Avatar
Get 2 spare tires from a Cobra and put some Hoosier skinny 17 inch tires on it.
__________________
1997 Novi 2000 powered Cobra droptop
2008 Gt stock
2 cam sam is online now
Old 08-15-2010, 02:37 PM   #8
justamach's Avatar
i run 15 3.5 prostars on my car with a 1.75 bs and a 1" spacer. i had to still grind my calipers slightly. i have a mach 1
justamach is offline
Old 08-15-2010, 04:46 PM   #9
Greg welds won't clear cobra calipers, a 3/8 spacer is required
__________________
81 hatch, 357 highport.
Gforce built nash, v gate shifter
Real cars have 3 pedals
facracr is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
