G-force T-5 Faceplated, or TKO faceplated? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 40 Old 12-03-2009, 02:28 PM Thread Starter
Ok, im either gonna plate my TKO or mabye get a G-force T-5, any pro's/cons between the two? Also, i have a 3.27 first gear in my tranny, while the g-force has a 2.95, i run a 28" drag radial.
Also i like that the t-5 has a lower OD ratio for cruising, a .59 to my .68 in the TKO.
I know T-5's are lighter, but im still up in the air whether i should send my TKO out or buy this g-force t-5 that i found
Doc's Notch is offline
post #2 of 40 Old 12-03-2009, 02:45 PM
blackout50's Avatar
Trader Feedback: (18)
Need to know more about the whole combo.
Weight?
Motor?
N/A or Power adder?
Gear?
Radial or slick?
RPM?
no one knows. thats the issue with EFI, too much guessing.
wisdom from bolt-on-bandito
blackout50 is offline
post #3 of 40 Old 12-03-2009, 03:22 PM Thread Starter
Weight?3160 with me in the car
Motor?345ci, R based 345, 205 CNC heads, Comp 282 cam(gonna be changing that), Untouched R-intake, and all supporting stuff.
N/A or Power adder? N/A
Gear? 3.73(may step to 4.10's or 4.30's)
Radial or slick? 275/60 drag radial.
RPM? Shifting at 6100-6200(this will change with the cam).
Also the motor is set up for nitrous, im not spraying it until i reach my N/A goal, but this thread isnt about me running a number its more to get other peoples opinions/perspectives on my setup.
post #4 of 40 Old 12-03-2009, 03:35 PM
Banned Alleged Scammer
Trader Feedback: (146)
If you are going to spend the money face plating it, stick with the TKO.
post #5 of 40 Old 12-03-2009, 03:57 PM Thread Starter
Could you elaborate on that a little for me?
post #6 of 40 Old 12-03-2009, 04:25 PM
blackout50's Avatar
If you are going to spray it I would say go with the TKO.
The 3.73s would like the 3.27 1st better also.
If you were starting from scratch,going to stay N/A with more cam and gear I would lean towards a straight cut G-Force.
post #7 of 40 Old 12-03-2009, 04:40 PM Thread Starter
Thanks for the input, i was thinking the same about the 1st gear difference
post #8 of 40 Old 12-03-2009, 04:42 PM Thread Starter
So if i sent myne out to pro motion would it be wise for me to cryo treat the gears?
post #9 of 40 Old 12-03-2009, 04:47 PM
blackout50's Avatar
Im not sure if the Cryo treatment is really worth.I haved heard mixed things about it.
post #10 of 40 Old 12-03-2009, 04:55 PM
The weak link in the Tremec is the shifting area. Once you face plate it, that eliminates those problems. The gears are larger than the T5 and the output shaft is larger as well. Its a stronger unit.
post #11 of 40 Old 12-03-2009, 05:34 PM
straight cut gears in a t5 are not recommended for drag racing, first gear is more likely to fail because there isn't enough surface area contact between the gears. they break on the launch.
R0B0T is offline
post #12 of 40 Old 12-03-2009, 05:52 PM
blackout50's Avatar
There is more than sufficient material on the straight cut gears and they dont tend to climb.Helicut gears are used to reduse noise.Jerico,G-Force,Liberty all use straight cut in drag racing applications.
post #13 of 40 Old 12-04-2009, 12:06 AM
flyin2jz's Avatar
I have a g force t5 that's faceplated in my na 347 car. The tranny shifts like butter when it's on the wood but I definitely don't drive the car as much since going to a dogringed tranny. It grinds going into gear every time I shift and I cannot for the life of me figure out how to downshift the car. I've tried raising the rpms and sliding it in gear but can't do it. Sound like the tranny is coming apart on any downshift. I really wish someone could tell me how to downshift so I can enjoy my car. I have 430 gears so I'm in fourth gear pretty early when driving around town. It's tough goin around corners in fourth gear it bucks like crazy. Someone please enlighten me. Kevin
93 gt 352 ci 302 based alum rdi block,bryant billitt crank, je pistons,Bullet racing ots hr cam, linkbar lifters,tfs r heads,super victor efi,42lb injectors, abaco 97dbx meter, 90 mm accufab tb, jesel shaft mount 1.7 rockers,kooks headers, g force t5, 4.56s, 10.52 at 130, 498rwhp/387ftlbs
flyin2jz is offline
post #14 of 40 Old 12-04-2009, 12:10 AM
that is the issue with straight cut gears in a t5 case. that is exactly what walt (from pro motion i think, maybe liberty) told me about a year ago.
R0B0T is offline
post #15 of 40 Old 12-04-2009, 10:00 AM
NUTTSGT's Avatar
The T5 may be lighter to start, but once you put the G-Force internals in it along with one of their cases, it'll be within pounds of a Tremec.
notice how thick the case is
Eric
TOO MUCH IS...JUST ENOUGH
Originally Posted by Cellos88gt View Post
fine. I'm out. I don't need this place.
NUTTSGT is offline
post #16 of 40 Old 12-04-2009, 12:58 PM
Stephen Johnson's Avatar
this tranny is far lighter than the tremec. I helped put my buddy's tremec in, its heavy as crap. the g-force with the upgraded gears and case, is well lighter. I have the g-force/straight cut gears with the upgraded case
SS/D 427 Ford Fairlane NHRA-IHRA (Ex- Van Cleve) 9.47@141mph
SS/D IHRA Record Holder
SS/E NHRA Record Holder 9.49 @ 139mph
1985 mustang Daily Driven N/A 331 10.78 at 123mph
Stephen Johnson is offline
post #17 of 40 Old 12-04-2009, 12:59 PM
where did you get this piece of information from? Because where ever you got it from, they told your WRONG
post #18 of 40 Old 12-04-2009, 01:00 PM
Sorry I just saw your repost, but I dont by that piece of info.
post #19 of 40 Old 12-04-2009, 01:01 PM
honestly, if you already have the TKO,just have it faceplated, it will be stronger than the G-force t-5 with upgraded everything.
post #20 of 40 Old 12-04-2009, 01:12 PM
blackout50's Avatar
The G-Force case is no more than 3lbs more than a stock T5 case ,if that.
post #21 of 40 Old 12-04-2009, 01:55 PM Thread Starter
Well i guess its settled keep the TKO
I just talked to liberty, pro-motion and G-force.
The guy from G-force was a DCK.
The liberty and pro motion guys were very helpful though, i think i am going to go with liberty, because they can keep 1st synchro's in the trans and are a couple hundred bucks cheaper, and shipping will cost me less. I am waiting on E-mail estimates from both companies and will make my final decision from there
post #22 of 40 Old 12-04-2009, 02:01 PM
blackout50's Avatar
LOL! They never fail to impress me with their total lack of customer service..
post #23 of 40 Old 12-04-2009, 02:09 PM
hotrodder's Avatar
i tried to speak with Gforce yesterday and got no help, they didn't even return my phone call later.
hotrodder is offline
post #24 of 40 Old 12-04-2009, 02:19 PM Thread Starter
I hate when i call people and they make me feel like they just wanna get me the F off the phone, mabye next time i should just write them a blank check and skip the phone call. The guy did me a favor though, it narrowed my decision down pretty easily.
So anyone have a prefference to Pro-motion or liberty?
post #25 of 40 Old 12-04-2009, 02:32 PM
lol, I've dealt with promotion before a couple of times, and they didnt return my phone calls back. One time they did, but it was a wk later, hell I had already ordered the parts from g-force. I've dealt with g-force for years, with my super stocker and my mustang. I've always had GREAT help.
post #26 of 40 Old 12-04-2009, 07:53 PM
NUTTSGT's Avatar
You may be right but it didn't feel much difference in weight to me when I used my buddies Tremec. Maybe I'll throw his Tremec on the scale (I have a good scale) and record the weight before he sells it. Then I'll weigh mine when I pull it to do the engine swap on mine.
It wouldn't be the first time I was wrong.
Eric
NUTTSGT is offline
post #27 of 40 Old 12-04-2009, 08:26 PM
hotrodder's Avatar
I would like to go Liberty personally but the last time i talked to them he told me a T5 could not be built to hold up to my power level and launching on slicks. He suggested a faceplated TKO600.
post #28 of 40 Old 12-04-2009, 08:51 PM Thread Starter
Im gonna go with liberty, they were quick on e-mails and gave me a solid price list for every option inside the transmission right down to the sliders. They also have no problem keeping 1st synchroeded which is a must for me, pro motion told me it would be extra if i didnt want first plated and thier base price was higher.
So what im gonna get is my TKO faceplated, they are gonna clearance the cluster, weld the shift finger, modify the cover, and put bronze fork pads in it, i also think im gonna get the surface enhancement done while its there
Also, the Gforce T-5 i was looking at had a stock case i believe with a g-force gearset.
post #29 of 40 Old 12-04-2009, 11:33 PM
call walt, ask for yourself.
let me know if he still feels the same way.
R0B0T is offline
post #30 of 40 Old 12-05-2009, 09:36 AM
dy85merc's Avatar
When my G-force was shipped, I think it weighed 84 pounds (been a while). Don't know about the tremec.
1985 Mercury Capri
dy85merc is offline
post #31 of 40 Old 12-05-2009, 09:41 AM
dy85merc's Avatar
How much power? My G-force is rated for 600 HP.
1985 Mercury Capri
dy85merc is offline
post #32 of 40 Old 12-05-2009, 10:55 AM
hotrodder's Avatar
Thats what i dont understand, GForce will build a T5 rated for 600hp but Liberty told me the T5 can only hold about 450 max if built right.
post #33 of 40 Old 12-05-2009, 01:39 PM
600stunnin's Avatar
I broke my pro motion g-force on the street. I now have a tko600 from hanlon and he faceplated 3rd gear, shiftin at 7k with no issues. Stay away from the t-5s unless you have a super light car with no more than 550hp.
600stunnin is offline
post #34 of 40 Old 12-05-2009, 02:20 PM
dy85merc's Avatar
I've heard that before, might have something to do with the G-force case or hardened input shaft. Hard to tell...maybe the 600 HP rating is bogus???
1985 Mercury Capri
dy85merc is offline
post #35 of 40 Old 12-05-2009, 02:24 PM
dy85merc's Avatar
G-force specifies "not for street use" on their straght cut T-5s. I try not to do too much, but my car is a weekend street car. BTW, mine is 3200 w/410 whp...seems to do OK in mine. I agree with the call you make on the the light car w/lower HP.
1985 Mercury Capri
dy85merc is offline
