#1 |
coilovers, what do I have?
My car has coilovers on the rear that were on the car when I bought it. I was told by the guy they were ground pounder but they were on it when he bought it also. The springs have ccm10x250x150 on them. Can any of you tell me what I have? The shocks are bolted to the rearend using the original shock mount brackets and hardware and the shock eye bushings are toast from holding up the weight of the car. What parts are supposed to be on the bottom end of the shock?
__________________
1993 Reef Blue unmarked Florida SSP Coupe 1992 Arizona SSP Coupe 1935 Chevrolet Master 2dr sedan....bagged, suicided, chopped, shaved, so many mods I cant remember them all. Last edited by GTdriver; 12-01-2009 at 01:05 AM. |
| Sponsored Links | |
Advertisement |
#2 |
Well I have found these heavy duty lower shock mounts. I still need info on my springs and what about the shock eye bushings? Anyone make urethane or solid bushings for lakewood shocks?
__________________
1993 Reef Blue unmarked Florida SSP Coupe 1992 Arizona SSP Coupe 1935 Chevrolet Master 2dr sedan....bagged, suicided, chopped, shaved, so many mods I cant remember them all. |
#3 |
on my car i did rear coil overs and they have like 150/2?? i was told that was a progressive spring to give u a better ride. u can see how the spring is made with the spring getting smaller and the smaller the psi raises. it may be the size of the spring in mm
#5 |
I have found a little more info. The kit I have is indeed ground pounder and the ccm on the springs stands for Central Coast Mustang who I understand is out of business. I found this picture and I am missing the shock mounts, the solid bushings, and the sleeves that slide over the bottom of the shocks. Heavy duty shock mounts are no problem to find and are cheap. I assume the sleeve is just for safety because the shock looks a little weak where the eye is welded to the tube. If I just replace the shocks, the new bushings will do the same as the ones I have. I have a neighbor who has a lathe and I might get him to make some solid bushing if I can't find any. Now what does the 10x250x150 mean and will they work for drag racing?
__________________
#8 | |
__________________
#10 |
I'm thinking about replacing my southside uppers with the baseline street-launch setup and I need to replace the bushings in my UPR lowers (or replace the arms). I just want to make sure the coilover setup I have will work OK. Thanks for the help.
__________________
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
