#1 |
Trader Feedback: (40)
pic of built rear installed and wheels/tires
Pics of the new rear installed narrowed 2.25" each side , 9" ends , housing welded and powder coated gloss black , moser 31 spline axles , detroit locker , 4.10 gears , 1350 yoke , trickflow cover , 94 GT disk brakes ( slotted and black zinc finished rotors ) with cobra edition calipers and braided brake lines http://www.northracecars.com/ brake brackets , upper spherical bushings and http:/www.southernoutlawshop.com/ axles braces and the billet specities street lites 15x4" fronts and rear 15x10" 6.5 bs with nitto drag 325/50/15 tires . I feel like a kid on xmas day when I got the car back on the ground and moving afetr 3 months . I still have to add 1 brake line to the rear mount the muffler brackets and tie up the battery cable , emergency brake cables and I am sure a few more things . So tell me what you think .
| Sponsored Links | |
Advertisement |
#3 |
Trader Feedback: (46)
looks ready for some launches!
__________________
93GT electric red & titanium gray 306ci 7.44 @ 91mph 1/8mi gone but not forgotten Friends don't let friends go to the track without sticky tires! 600 hp/10 sec 374" N/A build in progress. |
#10 |
Thanks . No clearance issues from what I can see I have about 1/2" or so clearance may be more should measure might help other that may want to do something similar but if I had gone with the cobra rotors it would have very close that much is for sure .
#11 |
Trader Feedback: (18)
Wow, that looks great!
__________________
Driven by an amazingly untalented person, this rolling pile of rust has managed to continually drain a bank account, all the while never actually getting the driver from point A to point B. Please help |
#13 |
US Air Force Active Duty
So if you had 2.25" cut off each side, how far did the brakes push the wheels out? It seems like having the rear narrowed 5" the tires would tuck in more. It looks damn good though. Do you have any pictures of the tubs
__________________
'81 COBRA, 10.7:1 332 10.93@123.59 1.43 60ft. "Think before you say something stupid" |
#14 | |
#15 |
Moderator
Trader Feedback: (49)
thats one nice looking capri. im so glad you lost the bubble lookin ugly hatch and put some lx tails makes it look hella better. do you plan on putting some side skirts and rear bumper on the car to match the front up? any plans for paint?
good craftsmanship on that rearend too man. looks very nice. |
#16 | |
#17 |
Nice a$$....
__________________
My old car: 1985 GT with T-tops. Sportsman based 342, AFR 205's into a Vic Jr. and a C&S Billet Aerosol 800 carb fed by a Novi 2K, MSD Digital 7531. Street tune is 582rwhp at 6500rpm . Tube K-member and arms. Built 8.8 with 9 inch ends. Cage and chassis work by DMC Racing. Tuning by SD Concepts. |
#18 |
Are you nittos mounted backwards? Looks like their mounted wrong. Plus whats the deal with the mufflers hanging so low? Not hating, just questions. I love the car.
__________________
1990gt 306,Novi 2000,C4. |
#19 |
I'm assuming the mufflers brackets arent welded up yet just a guess. I love those wheels thats bout the only wheel I think looks as good as a prostar. Does anyone think you could run that same wheel combo 15x10 with a 295/50mt radial without tubbing. Obviously you'd have to do alot of beating and banging to make them fit. Car looks sick whats the motor combo?
__________________
1988 coupe |
#20 | ||
#21 |
Trader Feedback: (224)
looks killer man. nice job
__________________
1989- gt full drag build in progress.. 1991- emerald coupe- stroked, caged & sprayed 1999 cobra- 5.0 stroker and single turbo coming soon |
#24 |
looks great but i think the t fitting for the brake lines is on the wrong side. I know on my gt its on the left side of the rear end housing.
__________________
96 GT- Complete 4v swap, 4.10's 93 GT- Traded 97 F150-PI swapped. |
#25 |
Look under you car again Fastfox400...he has er right...the brake lines are run down the passenger side under the carpet then threw the floor to the rearend. Not sure what your thinking?
Nice job 460capri...shes getting there! Keep at it (haha...this is one of those "Do as I say not as I do" things). Obviously need to go work on mine now!
__________________
"Those who live life by the sword...get SHOT by those who don't!!" |
#26 | |
79mustang351 I know what its like I get burned out sometime and dont work on the car for several weeks at times . To get in the mood I sometimes go out to the local hang out on fridays to get the construction juices flowing . Thanks for the compliments guys . |
#27 |
Looks good Scott. Really good. That car has come a long way...
In one of the pix I think I see an ARB, was that a custom deal or an off the shelf unit that was modified? The billet brackets for it look sweet... BTW, what type of control arms are on there? I couldn't get a good look...
__________________
My Hooptie: '85 GT. Just about bone stock and knocks down 24 on the highway... LONG LIVE 7.5's and 2.73's!!! |
#28 | |
#29 |
Cool man... I didn't see the pic, can you try and post it up again?
__________________
#31 |
Sweet set up. Did you have to mod any of it to make it work? It looks like a bolt/weld in deal all ready to go...
BTW, did you do all the welding on the axle housing for the ends and brackets or did someone local do it?
__________________
#32 |
Thanks it is a nice set up that is why I bought it . It was to wide for my car the ends had to be cut off . I had a local shop install it and they also did all the welding on the rear .
#33 |
That front air dam looks great! What is it and where did you get it?
__________________
Neal -86 coupe project sitting in my garage on a 5 lug conversion.. and the motor is in.. and it runs -newspeak SUCKS |
#34 | |
VW parts now )and I bought the one pictured on ebay to replace the one that was on my other car that was totaled the air dam got damaged I am keeping it as a spare . Now the bad news they dont make them anymore if I find another one I will buy it also .
#35 | |
Trader Feedback: (32)
Here is what I think. I think you should give it to me I will trade you a perfectly good stock 8.8 for it. Hell, I will even do all the labor to swap it out. J/K looks awesome!!!!!
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
SGT, US Army 1-101HHC
Linear Mode
