Anyone know how to hook up a one wire alternator to a 65 mustang? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 02-15-2008, 05:23 PM Thread Starter
99coupeGT's Avatar
Im looking to go with a one wire alternator setup. has anyone done this? can you explain to me what i need to do as far as wiring? also pictures would be a huge help. I need more than the 65amps of charge my stock alternator is giving
1965 Mustang Fastback: 408w, Gforce T5, 9 in Novi 2500SL in the works
2003 Mach1: 5spd, IRS, 480rwhp @10psi
1965 Mustang Coupe: SOLD
1960 Falcon 2dr: SOLD
99coupeGT is offline
post #2 of 7 Old 02-15-2008, 06:25 PM
72coupe's Avatar
Go to fordfuelinjection.com they have a bunch of alternator diagrams there. I used one to hook up a 2G on my coupe.
72 Mustang Coupe, 203,000 miles, 331 Scat steel crank & pistons, 9.0 compression, TFS twisted wedge aluminum heads, 19 lb injectors, BBK 70mm throtle body & EGR, 73mm mass air, Crane 1.6 roller rockers, FMS E cam, FMS roller lifters, AOD & original 3.00 gears in 8" differential with Auburn locker.
72coupe is offline
post #3 of 7 Old 02-15-2008, 07:08 PM
nastynotchback1's Avatar
install the alt and run a wire from the back of the alt to the positive side of the battery.if you want a gage then run said wire through the gage and then to the positive on the battery
81 coupe S/W#7(SOLD
90 hatchback S/S#20
94 WHITE LIGHTNING
nastynotchback1 is offline
post #4 of 7 Old 02-15-2008, 07:10 PM
One wire, connect the wire to the + side of the solenoid.
10secgoal is offline
post #5 of 7 Old 02-16-2008, 02:52 PM
65 fastback's Avatar
Here is a link to a great write up on installing a 1-wire alternator and removing all of the excess wiring.
http://forums.stangnet.com/showthread.php?t=409944
Tim
65 2+2 302-GT-40 heads, Perf RPM, 600 cfm 4bbl. JBA shorty's, 2.5" Dr Gas X-pipe
T-5 world class 5 speed, .80 OD 9" with 3.55's & T-loc
4 wheel discs 17" AR CL-205's 225/45 & 245/45
TCP/Global West suspension subframe connectors, Traction Masters, Panhard bar TCP manual rack & pinion
65 fastback is offline
post #6 of 7 Old 02-18-2008, 12:10 AM
66mustfb's Avatar
99coupeGT,
You will need to install a voltmeter. The original meter is an ammeter with an external shunt (part of the wiring). If you route the alternator output lead through this meter it will be toast.
All the vendors for classic Mustang parts have the books with wiring diagrams in them.
AL
'66 fastback w/MegaSquirt II, MAF & EDIS, 5.0L 2k Exp, Fuel Safe, Total Control R&P, 4w Disk, T5z, Hyd Clutch and 8" 3.55
66mustfb is offline
post #7 of 7 Old 03-15-2008, 09:06 PM
keithnra's Avatar
Trader Feedback: (29)
great info
89 GT convertible 5.0 GT40 irons BBK 70mm TB,
66 289 bored .40 over Holley 600 comp cam
85 GT with T-tops yeah its rough!
86 coupe with 4 banger 96 GT vert 86 GT
keithnra is offline
