AOD crossmember - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > Classic Mustangs & Fords
Old 03-10-2007, 11:32 AM   #1
AOD crossmember
Hi
I need a AOD transmission crossmember mount for my 65 coupe efi/AOD swap. Anyone know who makes them?
Thanks,
Brian
__________________
65 coupe 302 EFI in the works
88 LX, 4cyl turned 302HO
TrickFlow heads, track heat intake,#1 cam, 1.6 rollers, 65mmTB,
shooky is offline
Old 03-10-2007, 03:53 PM   #2
JBA has one
Thekid760 is offline
Old 03-12-2007, 12:37 AM   #3
dav65mus's Avatar
Ron Morris Performance.
__________________
65 mustang coupe 5.0/ t5z
65 austin healey replica 302/4spd
62 galaxie 500XL convertible 390/auto
dav65mus is offline
Old 03-12-2007, 12:43 AM   #4
dav65mus's Avatar
BTW I have one that was from windsor fox. If you are interested in it PM me and I will get back to you.I yanked my Aod and put in a T5z, and don't need it anymore.
LOL you can buy the aod too, but it would cost a mint to ship from Colorado to North carolina!
__________________
dav65mus is offline
Old 03-12-2007, 03:23 PM   #5
Sorry I bought one from Ron Morris Performance along with some other stuff. Thanks though.
Brian
__________________
shooky is offline
Old 04-18-2007, 09:41 AM   #6
WHAT KICKDOWN DID YOU USE FOR THE AOD AND WHAT YEAR AOD WILL WORK
outlawdan is offline
Old 04-19-2007, 01:03 AM   #7
dav65mus's Avatar
It is not actually a kickdown, it is a line pressure regulator cable that MUST be hooked up and adjusted properly or you won't have your aod for long.
If it is a carbed application, Lokar makes a kit for it (on summits site).
If it is an efi conversion, then just use the stock ford cable.
I used an aod out of an 88 v8 mustang.Just make sure you get an aod and not an aode.
__________________
dav65mus is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
