Electrical interlock? - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > Classic Mustangs & Fords
Old 01-16-2007, 04:53 PM   #1
93 EFI engine into 66. Thought it was a spark problem, but I got that fixed. Now it is fuel. Fuel pump runs and I have fuel pressure at rail. For some reason, apparently the computer is not telling the injectors to spray. Is there some interlock between engine compontents/relays that I am missing? I know the ECM has to know that your fuel pump is running, that is in place.
I do not think it is a ground problem, as I grounded the wiring harness to the battery just to get it running. I am not getting the noid light to blink when I crank it over. Any help would be greatly appreciated! Thanks.
Gary in GA
gcroix is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
