#1 |
1970 fastback tranny help
Hey everyone. I'm new to the forum and not sure this is the best place to post. I just got a 1970 fastback (Grande Mach 1 clone) with a Cleveland. I'm having trouble with the transmission. It works fine once it warms up but I have a lot of trouble getting it in gear when it's cold. I move the shifter to drive or reverse and nothing happens. I can rev. up and it won't move. Any ideas? Thanks.
__________________
1970 Red 2011 GT Black |
| Sponsored Links | |
Advertisement |
#3 |
I agree with this, sounds exactly right. I'm afraid you have a rebuild in your near future.
__________________
about.me/jevchance myrestoproject.com - coming soon! 1966 Mustang Coupe |
#5 |
If its so bad that is not even going into gear when cold i'd just rebuild it. fix it in a can is good when its just slipping a little but if its not even going into gear then i would look into a rebuild
#6 |
I'm thinking about replacing it with a manual. Ideas? This is my priority fix. I just want to drive it. No dragging, no shows except cruise-in style. It was bucking at the light with foot on brake-- don't like that. Not interested in revisiting this next year either... Thanks everyone for your replies!
__________________
#7 |
the fix it in a can was just a suggestion that may improve drivability while he decides what to do.
the hardest part about going to a manual is finding the clutch pedal assembly. the rest of the partts are easy to find ( new or used)but be preparred to spend more than rebuilding you Fmx will cost. American Powertrain makes a completee swap kit for around $3500. It includes a clutch pedal and tranny mount for a T-5 Remember that you need a 28 oz flywheel and the flywheel diameter and bellhousing must match. you cant't run an 11 inch flywheel in a fox bellhousing , and you can't run a large bellhousing with a 10 1/2 clutch. |
#8 |
The clutch pedal assembly is available new from most suppliers, it is not hard to find.
You can get a lot of information about the swap and what parts you will need at this link: Modern Driveline - 5 speed Transmission Swap - T5 and TREMEC TKO conversions for Mustang, Falcon, Cougar, HotRod, Cobra The rebuild will likely be less expensive, and will likely get you back on the road quicker.
__________________
#9 |
Pedals are very easily had, modern driveline makes a two piece clutch pedal you dont even need to take the column down to get in. they are $160.
If you have the money to do a T5 swap I would do it. The flywheels are easy to find as well, If you go with modern drivelines hydraulic clutch setup you can be all said and done for under $2000 if you get a good deal on a trans. I'm in the middle of a T5 swap in my 70' coupe actually, I have a spare T5 for sale if you're interested send me a private message. |
#10 |
I put a Keisler Engineering RS 400 5 speed in my 73 2 years ago.
They make a perfect fit kit that allows installation with no alteration to the car itself. Considerably stronger than a T-5 it is based upon a beefed up T 45, yet is s nice compact package. It is available in 3 different strengths and with everything you need right down to the driveshaft, or you can get just what you want. Their prices aren't bad, but their customer service is awesome! |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Frankenstang
Linear Mode
