Passanger A Pillar rust 1991 hatch - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By cu racing
post #1 of 7 Old 02-17-2017, 09:06 PM Thread Starter
Gixxer2k4's Avatar
Has rust on A Pillar, getting quotes now to have it fixed.
Gixxer2k4 is offline
post #2 of 7 Old 03-22-2017, 07:30 PM Thread Starter
Gixxer2k4's Avatar
Going rate seem to be between $1000 to $1500 to fix.
post #3 of 7 Old 03-22-2017, 10:51 PM Thread Starter
Gixxer2k4's Avatar
post #4 of 7 Old 03-26-2017, 11:55 AM
The surface rust is faily easy to fix, its the rust in between the layers of sheet metal is what is hard to fix. The body shop will almost need to do exploratory surgery to see how bad the rust is to determine if you will need those parts off of eBay. Did the body shop say they would need additional sheet metal to repair your rust?
Gixxer2k4 likes this.
cu racing is offline
post #5 of 7 Old 03-26-2017, 05:35 PM
Dachipsta2004's Avatar
Exploratory surgery is the best route. I am attempting a similar repair as yours. I knew at the base of the A-pillar where all the panels come together and the cowl had some rot but I assumed that behind the door hinges did too but they didnt. A bit of surface rust and that was all. The cowl and up by the windshield is keeping me busy enough but mine near the hinges wasnt bubbling thru nearly as bad as yours. Good luck with it. Rust sucks.
SD,302,Stkheads/cam,70mmTB,GT40Intake,PMCobraT5,Triax,3:73,BBKEqu, H-Pipe,155Lph,MMAdjLRCA,StkUppers,BilHDRear,MMFLSubs , Front MMCCPlates,MMCoilOv's,BilHD's
Dachipsta2004 is offline
post #6 of 7 Old 04-18-2017, 07:03 PM Thread Starter
Gixxer2k4's Avatar
Didn't say I needed them right away but I picked them up for insurance. If needed the car won't have to sit waiting on locating parts. Hoping its not worse once they look into it. Waiting on the funds right now to drop it off. Hopefully in the next month I can do it.
post #7 of 7 Old 04-18-2017, 07:04 PM Thread Starter
Gixxer2k4's Avatar
I hit mine with a flat head and it went all the way through. Hoping mines not worse once cut open.
