Convertible top issue 95 gt. Leaking at quarter window - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 12-29-2011, 12:27 PM Thread Starter
Trader Feedback: (38)
Like the title says. I just installed an entire frame, top, etc off a 98 cobra and I still have a gap where the quarter window meets the lowest part of weatherstripping on the top. I can take pics if it helps. This is the same reason I just gutted the interior and wanna fix it before installing the new stuff. Any help is appreciated.
XThe ResurrectionX is offline
post #2 of 5 Old 12-29-2011, 06:50 PM
Sounds like the adjustment on the quarter window is off, or the top is off, or a combination of both
Midwest Mustangs, Inc.
Complete Auto Body and Paint
Specializing in 79-93 Mustang Repair
847 356 6771 Lake Villa, IL 60046
Opher is offline
post #3 of 5 Old 12-30-2011, 01:46 PM Thread Starter
Can the top be adjusted? I tried to open it yesterday and couldnt. It is too tight and started to tear from the frame? Mind you I replaced the entire frame assy, and all from the 98. I am thinking I did not leave enough slack under the trim on the sides?
post #4 of 5 Old 12-31-2011, 11:17 AM
What you did typically does not work. Once a top is taken off, they tend to shrink. Since you removed the frame/fabric as an assembly, it could have shrunken enough to cause you problems.
Not to mention the slight tolerances from year to year.
You may find that you have to start from scratch. Get the old top material off, adjust the top, then install a new top.
There is adjustment in the top. The tops arent very complicated, just time consuming to make it all fit correctly.
Chris
Opher is offline
post #5 of 5 Old 01-02-2012, 09:49 PM Thread Starter
From what I can tell it is binding. The rear window is getting stuck under the frame. I am going to remove the headliner tomorrow and see what is hanging up, and try to correct it.
