Flux core - Ford Mustang Forums : Corral.net Mustang Forum
Go Back   Ford Mustang Forums : Corral.net Mustang Forum > General Tech Forums > The Body Shop
Old 03-30-2011, 08:13 PM   #1
BradleyRJ's Avatar
Trader Feedback: (22)
Flux core
So I got a flux core welder given to me.. Its an older model that cant be changed over to gas...can I use it to weld the holes under the hood and weld in some Scott Rod panels? I am a pretty fair welder with a mig, and since it wont have any structural properties I think I'll be fine.. but thought I'd ask before I got started.
__________________
They say what goes up must come down but I ain't reached my cruising altitude.
Take a look at what I did but can you imagine what I'm about to do.
BradleyRJ is offline
Old 03-30-2011, 08:19 PM   #2
I have done sheet metal work with flux core one time, and I won't do it again. It was really hard to control the heat, flux burn hotter and it made more of mess. I would just convert it to run gas.
JD1969 is offline
Old 03-30-2011, 10:13 PM   #3
ya, that gasless crap is all junk, dont bother even trying it
tiptopss is offline
Old 03-31-2011, 04:14 PM   #4
It's not junk, it just is meant for certain things. I used FC all the time when I used to weld on cell towers, and it worked great.
JD1969 is offline
Old 04-01-2011, 01:35 PM   #5
NotchAbove's Avatar
Kinda harsh don't ya think.....
Everything has a use and purpose. Flux Core is fine to weld thicker material with, if you know how to weld you can weld real good with it.
With that said, the sheet metal used on Mustangs is very thin, and you will without a doubt burn through eventually. You best bet is to convert to gas if your going to do sheet metal work.
__________________
1993 Reef Blue Notch
Thumper E7's|Cobra Intake|Crane 2031|FMS 65mm TB|90MM LMAF|30# inj|190lph|3.55's|Zex|Moates QH/BE/EA
NotchAbove is offline
Old 04-01-2011, 05:39 PM   #6
BradleyRJ's Avatar
This welder is pre able to convert to gas.. so I'll just use this one for other stuff and look for a good used gas welder when I am ready to do the underhood hole filling.
__________________
Old 04-05-2011, 01:12 PM   #7
Quick69's Avatar
I picked up a new hobart 140 on sale($420.00), got a tank and haven't looked back. Its hard to beat for the price and I would go with it if your on a budget
__________________
1978 Fairmont
"The Tapioca Terror"
Quick69 is offline
You may not post new threads
You may not post replies
© 2010-2011 Corral.net
