Side molding adhesive/tape removal? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-08-2008, 08:40 AM Thread Starter
Moderator
Jeff88coupe's Avatar
What's the best way to remove the adhesive and tape off the body panels that is left from pulling the side moldings off? I don't want to hurt my new paint. I had to pull off the side moldings to have my paint guy redo them.
Xtreme 8.5" -Heads up 1/8th mile limited 8.5 class at Kilkare Dragway
Dedpedal Racing;Sponsered by
;Tuned by
Boss block Big bore 347/225 TFS HP's/SR/BW S476R/A2W/PG/FAST xfi on E85
5.33 at 134.9 on 26x8.5 in 1/8th @3380#
Jeff88coupe is offline
post #2 of 6 Old 05-08-2008, 08:53 AM
04Mustang's Avatar
Trader Feedback: (74)
3M make good products
http://solutions.3m.com/wps/portal/3...be4GV2DMPHQWgl
4v Next...
"A lazy Man works Twice"
04Mustang is offline
post #3 of 6 Old 05-08-2008, 09:31 AM
keithnra's Avatar
Trader Feedback: (29)
see ive heard laquer thinner but do a search in the body work section
89 GT convertible 5.0 GT40 irons BBK 70mm TB,
66 289 bored .40 over Holley 600 comp cam
85 GT with T-tops yeah its rough!
86 coupe with 4 banger 96 GT vert 86 GT
keithnra is offline
post #4 of 6 Old 05-08-2008, 10:06 AM
bhleonard's Avatar
Trader Feedback: (54)
I've used a long handled gasket scraper with good results. Just don't 'SLIP'..
bhleonard is offline
post #5 of 6 Old 05-08-2008, 09:08 PM
It sucks but the the best way to not risk hurting your paint is the old rub it with your thumb technique.
cobrafox46 is offline
post #6 of 6 Old 05-09-2008, 01:11 AM
Trader Feedback: (32)
They make a rubber wheel that goes on a drill that will take it right off. Or you could use the technique that I always have which works great too. I get a rubber sanding block and just rub it with the block ( obviously with no paper on it) and it will come right off and not damage the paint.
cbibb is offline
