What does a bad u-joint sound like???? What are the symptoms?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 01-23-2006, 06:41 PM Thread Starter
I have a 95GT and I think the front u-joint is going bad. What are the symptoms/sounds of a bad u-joint. It or something is "clicking" and the sound is rpm specific and only happens when in gear and under a load or in gear and under extreme deceleration (i.e. 15-20mph decel. in 1st gear).
Thanks,
Brad
slowfiveO is offline
post #2 of 11 Old 01-23-2006, 07:38 PM
One of the symptoms of a bad u-joint is when the decelerating, the car will vibrate quickly. There could also be a little bit of a hum to it. The only time i've ever felt it is when slowing down after racing from about 130-150mph. This was with the clutch engaged. It would stop if you pushed in the clutch or at least be less noticeable.
Shane
1994 red GT: DSS 331, AFR 185, AFM PMS, Viper spec t-56, 331.9rwhp/353.4rwtq 13.234@108.54 RIP!!! totalled and cracked block (WORST of both worlds)
1994 white Cobra (in pieces all over the garage)
1994 white Cobra (daily driver)
^They are exactly the same.
Stang_Shane is offline
post #3 of 11 Old 01-23-2006, 08:22 PM Thread Starter
Thanks for the reply although I haven't really felt any vibrations in the car. Then again I don't think this lead sled could get up to 130.
This noise happens when the tranny is in gear but continues whether or not the clutch is engaged or disengaged. It is most noticeable though when the car is under load or decelerating.
post #4 of 11 Old 01-23-2006, 11:43 PM
That would be a bad front u joint. The front one makes noise under accel, and the rear makes noise under decel. Get that fixed asap, it is bad for tranny, and it can come apart, esspecially with spirited driving.
post #5 of 11 Old 01-24-2006, 12:16 AM
95KBconv's Avatar
I had on go out on an old Challenger and I thought the whole damn engine had come apart! Makes sense though since thats alot of off balance rotating mass.
1995 Ford Cobra w/IRS, white - Coyote swap with full MM front end in progress.
1994 Ford Lightning, red - HCI and Kooks in progress.
1993 Lexus LS400, grey - stock
2003 Infiniti M45, black - stock
95KBconv is offline
post #6 of 11 Old 01-24-2006, 01:37 AM Thread Starter
Thanks for the suggestions.
I agree that it must be the front u-joint. A buddy of mine took a ride with me and, using a stethescope through the shifter opening in the tranny tunnel, determined that the noise (clicking?) was loudest at the very end of the extension housing. So, since the u-joints have 116,000 on them I'm sure they're due. If it fixes the problem then great, if not........I have new u-joints.
I really don't feel like pole vaulting down the road any time soon.
post #7 of 11 Old 01-24-2006, 03:58 AM
Trader Feedback: (35)
If it is a slop issue, you should feel it when under there and torqueing the opposings sides of the shaft together and apart. I have had the joint feel nice and tight but the needle bearings were all rusted (lived in the Pac NW) - it would squeak/chirp it various situations.
With as cheap as U-joints are, I would replace both. In my experience the fronts wear about about half as often as the rears.
My two cents.
Good luck.
HISSIN50 is offline
post #8 of 11 Old 01-24-2006, 09:42 AM
Steeda90GT's Avatar
A good way to test ujoints is to drive around 50-60 MPH in a high gear, let off the gas and stab the throttle again quickly. If you feel or hear the buck then most likely it's the ujoints. Parts are cheap, but its a pita to press in.
94 Oxford White GT. 18" Saleen wheels with BFG Drag Radials. Vortech S-Trim, etc. 89 Oxford White Notchback. Chrome Pony Wheels, Full exhaust, Pulleys, yadda yadda yadda, 94 GT Vert (Stockish cruiser)
Steeda90GT is offline
post #9 of 11 Old 01-30-2006, 01:40 PM Thread Starter
Well I removed the driveshaft this weekend and man was that front u-joint toast. One of the caps was frozen solid and took a lot of effort to remove. With the cap removed you could see only a few needle bearings left, the rest had been reduced to rust and powder. I replaced them with the greasable #270 Precision u-joints from Oreilly's. Hopefully they'll last me a while.
I'm glad I found this before it decided to let go on me. A driveshaft loop may be my next mod/safety net.
So, if you hear an rpm specific clicking, popping, or snapping like noise coming from underneath your car, check your u-joints first before replacing your tranny like I did.
My justification: It did have 116000 miles on it!
post #10 of 11 Old 01-30-2006, 04:54 PM
Glad you got it. How bad was the rear joint (or did you just do the front)?
HISSIN50 is offline
post #11 of 11 Old 01-31-2006, 12:52 AM Thread Starter
Thanks.....me too!
I replaced the rear joint at the same time but it was in much better shape than the front. They were both original w/116000 miles.
