24 LBS injectors on 94 GT - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 02-06-2005, 07:34 PM Thread Starter
I have a basicly stock 94 GT Vert with the mods below. Would it do any good to put 24 LBS injectors one it? I have a adjustable fuel regulator.
Thanks, Jason
1994 Mustang GT Convertible AODE
FRPP 65mm Throttle Body
MAC 2.5" Pro Dump Exhaust
MAC 2.5" Off Road H-Pipe
FRPP Underdrive Pulleys
MAC Fenderwell cold air
Adjustable fuel regulator
NITO 245/50//16's on stock rims
93,000 Miles
my94gtvert is offline
post #2 of 7 Old 02-06-2005, 07:41 PM
94twinscrew's Avatar
Absolutely not.....and why would you have your fuel pressure that high??You're boggin the motor,back it down to @32-35psi,and leave it alone until you do more mods that warrant more fuel.
Teal94GT,Kenne Bell 2.0 (16.5psi),Ported Manifolds,World E7s ported w/3 angle valve job,Steeda #19 cam,MSD Ignition,3:55s,Snow Performance water/alcohol injection system,FMS Cobra Clutch,75mm TB,MAC CAI,Phantom Gauges,all the other typical bolt-ons,....and a good set of bald tires
!.........Mustangs are like our women,...you have to put up with a lot of crap to get what you want,but when they put out,life is good!!
94twinscrew is offline
post #3 of 7 Old 02-06-2005, 07:58 PM Thread Starter
Stock fuel pressure is 39, Would it be better to set it below 39?
93,000 Miles
post #4 of 7 Old 02-06-2005, 08:13 PM
Stock fp with a non adj fpr,is typically 30-33psi at idle with vac,and will jump to 42psi or so,under load.If you were seeing that much on a stock reg,then the reg was sloppy.If you trim it out to where I suggested,you will get better gas milage,along with smoother acceleration,and most likely,...a little more power.At 85k miles,your injectors have seen better days,and tend to become sloppy,and puddle with stactic pressures above 48psi.Your present combo doesn't warrant the need for extra fuel at this time,so why waste it?
post #5 of 7 Old 02-06-2005, 09:15 PM Thread Starter
I have mine set @ 42psi with vaccune line off and pluged. Is that ok? or should I back it down alittle more with the line pluged and off?
93,000 Miles
post #6 of 7 Old 02-06-2005, 11:31 PM
Hook the vac line back up,and that will be good.It should be close enough if that was originally set without vacumm.....that should bring your idle pressure to @ 33psi or so with vac.
post #7 of 7 Old 02-07-2005, 12:09 AM
Two 95's's Avatar
You would also have to get a maf meter calibrated for the 24lb injs.
Chrome Yellow '94 GT vert.
306ci, AFR 165s, FTI cam, Cobra intake, Tremec T-5
Two 95's is offline
