Factory amp location? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 02-01-2005, 02:39 PM Thread Starter
i was wondering if anyone knows the location of the factory amplifier in a 95 GTS. the momo that put the system in the car didn't bypass it and now all my speakers are dead. can anyone help???
LX SN95 is offline
post #2 of 10 Old 02-01-2005, 03:35 PM
In my vert there is one forward of the shifter (under the dash on hump) and 2 right behind the rear seat.
Rio Red '94 Cobra
Yellow '95 GT Convertible
White '95 Gen 1 Lightning
Racer-X is offline
post #3 of 10 Old 02-01-2005, 03:49 PM Thread Starter
the only thing there is the air bag control unit, no amp, someone please help, i need my tunes!
LX SN95 is offline
post #4 of 10 Old 02-01-2005, 07:06 PM
nateg20's Avatar
mine was in the center console on or near the floor behind the stereo. Its just the premuim set up though, not the mach.
94 GT
11 G37S
nateg20 is offline
post #5 of 10 Old 02-01-2005, 07:28 PM
the mach amps are behind the rear seat.
Stalkerfiveo is offline
post #6 of 10 Old 02-02-2005, 03:25 PM
KenI's Avatar
My Cobra had 3(Mach 460). One behind/under the deck, and 2 under the rear tray.
'95 Cobra w/Vortech
Dyno:
RWHP 515.4
RWTQ 454.8
2004 ZO6
KenI is offline
post #7 of 10 Old 02-02-2005, 03:35 PM
FastGT94's Avatar
Trader Feedback: (37)
How do you get at the one in the dash (in front of the shifter?) I've been meaning to take it out for ever now... Do you have to remove the dash to get at it? (Non-Mach)
-Dale
1994 Mustang GT TKO 500 5 spd
Fox 75mm TB, FTI Ported Edelbrock Perf RPM, 58cc AFR 165s, FTI Cam, 4.10s, Drag Susp, PMS Tuned by Mike Post
316 RWHP & 335 RWTQ // 3,225 lbs with driver and fuel // 11.919 @ 113.92 All Motor
FastGT94 is offline
post #8 of 10 Old 02-02-2005, 04:57 PM
Non mach systems don't have an external amp. Though an easy way to tell is to look at your radio harness plugs; two wide flat plugs=not amplified.
1996 Mystic Cobra
1995 Black GT convertible
AODE w/4r70w gearset, baumann shift kit, SCT chip, bassani cat. x-pipe. *SOLD*
1994 Canary Yellow GT *SOLD*
Cobra intake, rustmasters, aluminum driveshaft, Romac, fluidyne, pro 5.0 w/tri-ax handle, H&R's w/Bilsteins, twEECer RT, C&L 76mm kit...blah blah blah
94CanaryGT is offline
post #9 of 10 Old 02-02-2005, 06:04 PM
DarkMesa8's Avatar
94CanaryGT is right, but if you ever need to pull one just remove the radio and you can get semi-easy access to it. I also go around the center of the dash to help get my hands on bolts, etc.
1991 Grey Mustang LX Hatch
1995 Jeep Grand Cherokee Limited V8 4x4
1994 Suzuki GSX750F Katana
DarkMesa8 is offline
post #10 of 10 Old 02-04-2005, 10:03 AM
FastGT94's Avatar
It has one amp behind the dash, I know this for a fact. I believe there were three types of systems. Basic, some upgraded form and Mach. I know there's an amp because I can see it and I had to bypass it when I put the radio in.
I'll look at pulling the radio to see if I can get at it. Does it help to pull out the little "cubby" below the radio as well?
-Dale
FastGT94 is offline
