flywheel/flexplate won't turn after aode removal and reinstall? !!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 10-02-2004, 12:17 AM Thread Starter
Exclamation flywheel/flexplate won't turn after aode removal and reinstall? !!!
I pulled my aode to replace the rear main seal and to do some mild overhaul work to the transmission. I just put the tranny back in and bolted it up, and now I can't turn the crank pulley to get to the torque converter/flexplate bolts! While I had the transmission out I replaced the 1/2 and 2/3 accumulators and did a baumann valve body recalibration. There is NO fluid in the tranny or converter right now, but I drained them both before I pulled the tranny and the crank would turn by hand then so wtf? I am 99% sure that the torque converter is all the way in since the bolts pass through the flexplate as they did before.
Anyone have any ideas?...especially ones that don't require me pulling the aode out again as that was loads of fun!
1996 Mystic Cobra
1995 Black GT convertible
AODE w/4r70w gearset, baumann shift kit, SCT chip, bassani cat. x-pipe. *SOLD*
1994 Canary Yellow GT *SOLD*
Cobra intake, rustmasters, aluminum driveshaft, Romac, fluidyne, pro 5.0 w/tri-ax handle, H&R's w/Bilsteins, twEECer RT, C&L 76mm kit...blah blah blah
94CanaryGT is offline
post #2 of 4 Old 10-02-2004, 12:43 AM Thread Starter
After reading another thread about the same issue in with an aod, I'm convinced its that the torque converter is not fully seated. Yippie hooray and woopie-dee-doo!
Anyone know if you can seaty the torque converter with out fully removing the transmission? I know it clunked twice when I put it in, I guess it didn't get that last position quite right. In the words of the south park boys "dude...weak"!
1996 Mystic Cobra
post #3 of 4 Old 10-02-2004, 09:11 PM
94GTVert's Avatar
Originally Posted by 94CanaryGT
Anyone know if you can seat the torque converter with out fully removing the transmission?
You will have to drop it down to put both hands on the converter and twist-and-shove to seat it.
I remember reading about looking for 3 "thunks" with my Stallion converter.
Black 94 GT Convertible, AODE. Ported GT-40X heads & GT40 intakes. MAC 1-5/8" longtubes, single 3" Ultra-flow dump. ProM 75mm w/Calibrator built-in, MSD 6BTM, MSD dist., MSD coil, Mark VIII fan. EEC Tuner. PI converter. 4R70W internals. Alto direct clutch kit. PA valvebody w/transbrake. 4.10s, AL driveshaft. KB subframes. Lakewood struts 90/10, Comp. Eng. 3-say shocks 30/70, 36#ers, 255lph & T-Rex, AN8 & AN6, splitter.
TODO: 331 -- Forged: Scat crank (0 balance), JE pistons, Crower rods. 1966 289 block, Mexican main caps, retro-fit lifters -- awaiting work and assembly.
94GTVert is offline
post #4 of 4 Old 10-02-2004, 11:09 PM Thread Starter
I thought it was two, so thats what I stopped at...I guess you learn the hard way!
1996 Mystic Cobra
