Gears, 410's or 373's?? What do you guys have?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 29 Old 08-01-2003, 03:50 PM Thread Starter
Question Gears, 410's or 373's?? What do you guys have??
I am looking to get some gears for my 1994 GT. The car is a five speed and I would like to still be able to go on long trips on the interstate and such without to many issues. Would you guys reccomend the 410's or the 373's?? I went for a ride in a 1995 cobra the other day with 410's and a five speed, but on the interstate at 80 he was turning 3000rpm. That seems pretty high for a sustained rpm. Give me some input on what you guys have and what you think of them. Thanx
quick90coupe is offline
post #2 of 29 Old 08-01-2003, 03:51 PM
Anaconda's Avatar
What about 3.90 gears then?
See sig for what I have (it's an AODE)
Anaconda is offline
post #3 of 29 Old 08-01-2003, 04:07 PM
94svt5.0's Avatar
I have the 3:73s and as far as gearing goes I have been happy with them. At about speedo indicated 80mph it is turning about 2500 rpms.
1994 cobra # 1067
white ex./black leather int.
-Crane 2031 cam
-Bullit suspension
-BBK off road h-pipe
-basani cat-back
-superchips power chip
-mac cold air induction
-frpp king cobra clutch
-18" konig wheels with nitto 555zr
- 3:73 Ford racing gears
-Ford Racing aluminum driveshaft
-Auburn HD limited slip diff.
- 75 mm bullet MAF
94svt5.0 is offline
post #4 of 29 Old 08-01-2003, 04:08 PM
94CobraPace's Avatar
I have 3.73 gears in my 94 Cobra. It's not bad at all, 80 mph is around 2600 rpms.
2010 Shelby GT500, Kona Blue W silver stripes.
2007 Shelby GT500, Vista Blue with Tungston gray stripes, 1 of 119, Wifes car...
94 Cobra Pace car Convertible # 591
2001 Cobra vert # 2001 SOLD
94CobraPace is offline
post #5 of 29 Old 08-01-2003, 04:46 PM
JWALKER's Avatar
373 HERE. Seems to be pretty good.
Jeff
95 GT
12.07@ 117.86
60' 1.79
tfs heads, st ht intake, 70mm TB, CAI, 30LB inj, 75 MAM, steeda #19 cam, Mac unequal shorties and X-pipe, FPR, 373 gears,
MSD ignition,tremec 3550, 125 Shot N2O.
Trying to tune with the Tweecer RT....
JWALKER is offline
post #6 of 29 Old 08-01-2003, 04:46 PM
rpfuror's Avatar
3.73
I have 3.73 and they are great with running a 5 speed. I know you should go to 4.10 if your running an auto to get about the same pickup with a stick. 4.10 is not a bad choice for the 5 speed either, you'll have alot of pickup but when you getting to freeway speed your rmps will be higher.
FTI / AFR165 combo, tweecer tuned
rpfuror is offline
post #7 of 29 Old 08-01-2003, 05:54 PM
I have 373's now, but am upgrading to 410's in a the next week.
FRPP GT-40X Long Block, FRPP GT-40 intake, ASP underdrives, FRPP Plug Wires, MSD Super Coil, BBK 65mm Throttlebody, Pro-M 75mm MAF, BBK Billet Adjustable Fuel Pressure Regulator, FRPP 24lb fuel injectors, Walbro 190lph fuel pump, FRPP King Cobra Clutch, FRPP 3.73 gears, MAC 1 5/8th Shorty Headers, MAC O/R H-Pipe, Flowmaster American Thunder Cat-Back, Autometer/SVO 5in Tach, Nitto 245/50/16 555R's, FRPP Aluminum Driveshaft, Lakewood Driveshaft Loop, Kenny Brown full length sub frames, Trick Flow Rear End Girdle, Autometer Ultralite NOS pressure gauge, Autometer Ultralite A/F meter, PJM Console Cluster, PJM ashtray, switch kit, PJM Rear Seat Delete .
Up Next: Pro 3i LCA's, Steeda HD UCA's, Eibach Sportlines, Tokico shocks and struts, ZEX 125 wet shot, MSD 6AL w/ Adjustable Timing Control, Jacobs Nitrous Mastermind, M/T 26x10.5x16 ET Streets.
RoughNTough is offline
post #8 of 29 Old 08-01-2003, 09:43 PM Thread Starter
Thanx for all the replys so far and keep the coming. I think I am leaning towards the 410's. I mean i hate to do it and regret not getting the 410's. Also how bad off is your speedos with the 410's??
post #9 of 29 Old 08-01-2003, 09:56 PM
unclejackrock's Avatar
I had 3.27's stock and with 4.10's I seem to be about 10-15 mph off.
Forest Green '92 GT
Eddy intake, TFS Stg. 1 cam, Tri-ax, Flows, LT's, MSD, K&N, 3.73's, Mild E7's
No times...NO TRACTION!!!!!
unclejackrock is offline
post #10 of 29 Old 08-01-2003, 10:03 PM
HYBRED's Avatar
i have 3.55's in my 95, i'm very happy with them as a daily driver car. i have 3.73's in my 87 coupe, and i can notice a difference but i contribute most of that to the huge weight differences.
HYBRED is offline
post #11 of 29 Old 08-01-2003, 10:04 PM
You can correct your speedo by changing out the internal speedo gear. Even with the 3.73 gear and the 23 tooth gear it will be app 5% off. I had the internal speedo gear changed (when the tranny was rebuilt) from a 8 to a 7 and have the 21 tooth, it is exact now. With 4.10 and the 23 tooth you will be app 10% off.
post #12 of 29 Old 08-01-2003, 11:31 PM
Imyourzero's Avatar
I would definitely go with the 4.10's then. I went from 3.27 --> 3.73 because everyone said "3.73's are better for a 5-speed and 4.10's are too much gear for a stock 5.0." Well, the 3.73's were an improvement but it wasn't long before I wanted more. I swapped them out for 4.10's and have not regretted it at all. The pull in every gear is so much harder. You have to like to shift with these gears, though...cause around town you'll be doing a lot of it.
My speedo was 5 mph off @ 60 with the 3.73's, and now it's 10 mph off. I have the white 23 tooth gear and when I'm going 60 my speedo reads 70.
1994 Canary Yellow GT 5-spd
Sold.
Imyourzero is offline
post #13 of 29 Old 08-02-2003, 02:35 AM
texsn95's Avatar
Why can't someone make a gear that will fix the speedo with 3.73s or 4.10s correctly??
Interlagos Blue 06 BMW M5
White 95 Cobra 347 Stroker 355 rwhp 378 rwtq
Grey 2012 Armada Platinum (wife)
texsn95 is offline
post #14 of 29 Old 08-02-2003, 02:43 AM
Imyourzero's Avatar
Because on the 23-tooth gear (the one that is closest to being correct), the teeth are so small that a lot of people find that the gear gets chewed up quickly. If they made a gear with more teeth to get the speedo more accurate for the steeper gears, it would have even thinner teeth and would not last long at all.
I believe you can correct the speed with either a Speedcal or by changing both the drive and driven gears in the tranny (not just the driven gear like most people do).
post #15 of 29 Old 08-02-2003, 12:34 PM
VIPERBLUELX's Avatar
get the 4.10's
98 SVT Cobra 610rwhp/632rwtq Hellion T76
VIPERBLUELX is offline
post #16 of 29 Old 08-02-2003, 01:23 PM Thread Starter
Thanx again for all the replys. Nice to see you chime in there at the end Mark! After riding in your cobra and hearing from these guys I am certain that I want to go with the 410's. The car will mostly be drive just around town, but when I do drive it long distances I dont see a problem with the 410's. I'll get in touch with you when I get ready to have these put in. Thanx agian to everyone.
post #17 of 29 Old 08-02-2003, 11:03 PM
my95.0l's Avatar
Don't fear the gear! I went from 3:55's to 4:10's and I LOVE them. Yes rpm's are a little higher on the interstate, but well worth it. You've got a V8, sustained 3,000 rpm's is no big deal. Yes I have a 5 speed.
my95.0l is offline
post #18 of 29 Old 08-03-2003, 01:47 AM
427Windsorman's Avatar
I have had 3.55's, 2.73's, 3.08's, and 4.10's. I like the pull of 4.10's, the cruising RPM's of the 2.73's, and was happy with them all. The 4.10's were definitely the funnest, but also killed any semblance of gas mileage on the highway, and will drive you crazy on the highway with the motor at 2800 to 3000 RPM's constantly.
My brother has 3.73's, and they seem to be pretty good, but the 4.10's are noticeably better in the acceleration department
You really need to think about what you want out of your car. If it is a daily driver in town, then 4.10's may be the ticket, but if you do a lot of freeway speeds, then 3.55's may be a better choice.....
The Problem Is Not With Guns. It's Hearts Without God, Homes Without Discipline, Schools Without Prayer, People without Compassion, and Courts Without Justice.
http://www.linkedin.com/in/dougcrummey
427Windsorman is offline
post #19 of 29 Old 08-03-2003, 05:11 PM
MrGreen94GT's Avatar
4.10 with an AODE here. I also used the Speecal to correct the speedo. The gears really aren't as severe as a lot of people think.
1994 GT vert green w/tan top & interior
MAC CAI, Edelbrock Performer, ASP pulleys, BBK shorties, VRS cat x-pipe, Spintech Sportsman mufflers
AODE w/ Trans-go shift-kit, 4.10 gears + speedcal
FMS C-springs, Cobra Bilstein struts, Pro3i CC plates, X2 balljoints w/bumpsteer, Kenny Brown subframes, Eagle Cobra R's w/ 255/45-17 Hankooks
MrGreen94GT is offline
post #20 of 29 Old 08-05-2003, 04:34 PM Thread Starter
So what is this speedcal that you speak of? Will it work with a 5 speed car and how much is it? Thanx
post #21 of 29 Old 08-05-2003, 08:00 PM
Ron95gt's Avatar
Mine came with 3.27's, went to 3.73's, then 4.10's. With the 26" tall tires, and a 23 tooth, my speedo is right on the money.
Got about 12,000 miles on the speedo gear too.
523" carbed motor
Ron95gt is offline
post #22 of 29 Old 08-05-2003, 08:41 PM
3.73's are the best all around compromise...you will not be unhappy with them. 4.10's will give you little if any performance gain and will have you rowing that tranny like a Olympic Kayaker.
94 GT
sponsored by Ebay
Edelbrock 6037's-Steeda #19-Mildly Ported Edelbrock--Pro-m 77,--3.55's--Mac X-pipe--Equal Length Shorties--Magnaflow Catback--65mm TB--Z-spec T-5--Crane1.7RR --pulleys--Tweecer--BBK AFPR--FMS Alum. DS--255lph FP--Homegrown CAI
94Fauxbra is offline
post #23 of 29 Old 08-05-2003, 09:08 PM
MadDAWG's Avatar
I have 3.73s with an AODE. While I would love to have more gear for around town I probably gonna drop back to 3.55s to keep the crusie rpm down. I don't drag race any more so I'd rather keep the rpms down on the long cruise.
I really wish our cars had a steeper overdrive. I had a tranny built for my 86 once that had a 0.59 overdrive ratio. That let you run alot of gear. In 5th 4.30s ran the same rpm as 3.73 with the standard .68 od ratio.
25 years of pushrods, but a Modular Noob! 2003 MACh 1
MadDAWG is offline
post #24 of 29 Old 08-05-2003, 09:27 PM
On a 5sp with 410s, use a 6 tooth drive gear and a 19 tooth driven gear and it will be dead nuts accurate. You have to remove the tail shaft from the T-5 to change the drive gear but this sounds a lot worse than it actually is. If you already have the T-5 sitting there it would be a piece of cake.
'95 GTS bright blue metallic, 398, AFR 225s, ported Victor 5.8, FTI cam, Kooks headers, PA Super Comp C4, Coan converter
10.69@125 1.39 60'
NXGTS is offline
post #25 of 29 Old 08-05-2003, 09:45 PM
Little electronic box that Dallas Mustang puts out. Works on any 94-up Mustang, 5spd or auto. Gives you accurate speedo no matter what gears or tire size you have.
post #26 of 29 Old 08-05-2003, 09:48 PM
strokercharged95GT's Avatar
i have 3:73's in my SC347, would like to go back to 3:55 since i just light up my 295/30/18's street tires anytime i step on it
2013 Mercedes GLK-350
strokercharged95GT is offline
post #27 of 29 Old 08-06-2003, 12:12 PM
MadDAWG's Avatar
Nice!
My N/A would do that with 3.55s so you may want to go to 3.27s
MadDAWG is offline
post #28 of 29 Old 08-08-2003, 02:29 AM
racereddy20's Avatar
I have a stock 88 lx 5.0 5 speed. are the 4.10 gears a good choice or should I get the 3.73's. I mean the car is bone stock minus the FMS tranny (my stock t-5 took a crap). My FMS tranny came off of my project car and I'm thinking of pulling the rear end out now because it has 4.10's. I need some input. thanks all
Peter
<NONE>
XBL Gamer Tag-
xX Mero DawG Xx
racereddy20 is offline
post #29 of 29 Old 08-08-2003, 07:29 AM
Why dont you just get 3.90's and meet in the middle of the two? Thats what I plan on puttin on my car. Only problem is FMS doesnt make them.
1996 Saleen S281 SC #03
SlowFiveOh94 is offline
