Why does my low coolant light come on when its not low? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 04-11-2003, 03:03 PM Thread Starter
Thumbs down Why does my low coolant light come on when its not low?
The low coolant light has been coming on when the car is just started cold and it will stay on till the car heats up and i turn it off then back on. I checked the radiator and overflow bottle and both are filled to the point were they need to be...The thermostat is working correctly as well....dont know what could be wrong other then the sensor is on its way out....Isnt it located in the engine housing? not sure...thanks in advance
'13 GT
Deespeed99 is offline
post #2 of 6 Old 04-11-2003, 03:24 PM
Killer95Stang's Avatar
Their is a sensor located in the bottle.. its attached to the cap housing... sometimes it gets all gummied up, and gives a false reading.... trying pulling it out, and cleaning it up... might be a free fix..
1995 GT
Old GT40P Combo: 271rwhp & 303rwtq
New Combo: 308 rwhp 315tq N/A
-Neil Erickson (Midwest Induction) race ported GT40P's
-Neil Erickson Spec'd Custom Cam
-Ported Edelbrock RPM Intake
-Tweecer RT + Zeitronix WB
-NOS 05115 kit with 150 shot jets
Tons of other mods.. from LT's, to 10-1/2" bullits..ect..
Reach my goal of 300+rwhp NA, and now I'm aiming low 12's
Should have the dyno numbers in a couple weeks
Killer95Stang is offline
post #3 of 6 Old 04-11-2003, 03:28 PM
azl
hey... no help here but I have just recently been fighting the same issue: low coolant on cold starts w/ a full reservoir, then the light goes out as soon as I key off/key on when warm. I havent given much thought to it yet, I have bigger fish to fry, but I suspect it would be either the sensor in the overflow tank or possibly the computer, seeing as how the light stays on until key off. let me know if you find a solution!
azl is offline
post #4 of 6 Old 04-11-2003, 03:31 PM
Rednels's Avatar
your coolant level sensor is in the overflow tank. I had the same problem when my coolant was cold, its will register a lower amount, once it heats up, it expands and thus the light cuts off.
Black 94 GT- 331, 11lb powerdyne, UPR powerpipe, TW heads,
TFS intake, Comp 284HR cam, full BBK exhaust, 3.55 gears.
All tuned by a tweecer
#s to come with new motor
Rednels is offline
post #5 of 6 Old 04-11-2003, 04:19 PM
Conductivity
The sensor needs a small amount of conductivity between the contacts to "see" the water level. If you added pure water it takes a while for enough mineral/oxide content from the block and such to dissolve and increase the conductivity.
That's one culprit, and the contacts do get gunked up which is an insulator of sorts.
robtmc is offline
post #6 of 6 Old 04-12-2003, 01:11 PM
95KBconv's Avatar
Mine did that. Replugged it and it worked for awhile but came back so I unplugged it to keep the light off.
As long as you monitor your water level I would think you would be OK. I haven't gotten to a junkyard or checked online to see price. Looks like $47 for the sensor at Fordpartsonline.com but some places are a bit cheaper. Guess I'll wait.
1995 Ford Cobra w/IRS, white - Coyote swap with full MM front end in progress.
1994 Ford Lightning, red - HCI and Kooks in progress.
1993 Lexus LS400, grey - stock
2003 Infiniti M45, black - stock
95KBconv is offline
