Water pump going out? what does it sound like - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 01-01-2002, 05:22 PM Thread Starter
paluka21's Avatar
been noticing lately that when i first start the car up when its cold there is a bad clancking noise in the front end. You can feel the "knocking" through out the car, vibration in the blower bracket, upper intake, and you can feel it in the shifter.
I pinpointed where it is coming from and I beleive its coming from the water pump.
I removed the belt and started the car and the noise went away. Therefore I beleive it to be coming from here.
is this typically what a water pump sounds like when it goes out?
Whats a good replacement to keep my car cooler?
thanks
Dan
95 rio red cobra #2021
2014 Shelby GT00- Oxford White/Sonic Blue Stripes
1995 Rio Red Cobra #2021 - SOLD
8.8:1 comp. Dart 331, Procharger D1 16psi, AFR 185, Edelbrock RPM II, custom cam, TKO, Glenns 1000hp fuel system.
690rwhp on Mustang dyno
paluka21 is offline
post #2 of 15 Old 01-01-2002, 10:45 PM
my water pump went out last week. it didn't make a whole lot of noise, but i could hear it a little when my car was at idle. the way that i knew it was going out was that fact that it was streaming out antifreeze from the two holes on the waterpump. i would get under the car and check that first to see if it is leaking antifreeze out.
94 GT TFS Track Heat Intake, Twisted Wedge Heads, FTI Cam, 65mm TB, C&L 73mm MAF, 24# Injectors, Kirban AFPR, 255lph, BBK Longtubes, Off Road H-Pipe, BBK Underdrive Pulleys, Mac CAI, Pro 5.0 Shifter w/ tri-ax handle, Eibach springs, 3:73's, SPEC Clutch, JMS Chip. KB Subframe Connectors.
Best Time-13.00@110 320rwhp 320rwtq
white94 is offline
post #3 of 15 Old 01-02-2002, 02:37 AM
BenW's Avatar
Are those the "weep" holes? Someone was telling me that water pumps leak at weep holes before they go out. I haven't seen these holes before so I don't know.
BenW is offline
post #4 of 15 Old 01-02-2002, 08:54 AM
Thpose are the weep holes. I never really heard anything when my water pumps went out, they starting leaking antifreeze.
brock95gt is offline
post #5 of 15 Old 01-02-2002, 01:09 PM Thread Starter
paluka21's Avatar
I have no leaks at all to be honest.
However the sound appears to be coming directly from the water pump, as it doesnt make this sound when the belt is disconnected. I guess it would kinda make sense to be the water pump since it only makes this noise when the car is cold for the first minute?
What about a bearing in the pump itself?
Should the water pump pulley spin freely and easily? mine does w/o a problem in either direction.
just wondering
Dan
paluka21 is offline
post #6 of 15 Old 01-02-2002, 02:46 PM
my car has started to make clanking noise when i first start it up when its cold, but it only makes the noise right when it starts up...
i've been wondering what the noise is, it just started to make it.
302 block, destroked 351 cleveland crank, 4.03 bore, 3.3" stroke, 337 CID balanced and blueprinted by Keith Craft racing Arkadelphia, Arkansas,
Fully ported and polished Canfield heads, 2.08 intake, 1.625 exhaust Ferrea valves, Eagle 5.4 rods, Forged JE pistons, Lunati 51012 cam (232/242 duration @.050" 544/565 lift).... lots more
jordanpace is offline
post #7 of 15 Old 01-03-2002, 12:18 AM Thread Starter
paluka21's Avatar
jordanpace,
yep you got it! Only when the car is cold and you first start it, but as soon as you drive it for like 20 seconds its gone. I narrowed the noise down to the waterpump area. if your remove the belt its gone, but when you put the belt back on it comes back. If you let the car sit and idle it will keep making the noise, but if you get in the car and back it up right away it will go away within 20-30 seconds, i guess as the rpms go up. Might be a sticking bearing or something.
I guess this has got to be what it is, as there is really nothing else around that area that could cause that sound
cya
Dan
paluka21 is offline
post #8 of 15 Old 01-03-2002, 03:55 PM Thread Starter
paluka21's Avatar
OK does this still sound like the water pump?
Now the car has a squeaking noise to it, sounds like a bird or something chirping under the hood. You can hear it at idle and its getting much louder. Its definetly louder than my supercharger, and its coming directly from the water pump area.
so is this what it is?
There is no coolant coming from anywhere however
Dan
paluka21 is offline
post #9 of 15 Old 01-03-2002, 06:36 PM
erik_94COBRA's Avatar
That is probably what the cause is. They will usually leak when they go out though.
If you replace it, either get a new or remanufactured (rebuilt) Ford unit. And get one with a lifetime warranty. Make sure to get all of the gasket material off as well.
Erik
'94 Cobra #2182
erik_94COBRA is offline
post #10 of 15 Old 01-04-2002, 12:40 AM
i got my car in may so i don't have any other winters to compare it to, but the other day i started to notice a little bit of a clank sound when i first start it for like 1-2 seconds. then it goes away for good. I replaced my water pump with a stewart a little less than a month ago. It was leaking out of the weep hole. Its a small hole in the bottom of the pump that looks like it should leak out of there on purpose. Anyway, I would like to know what that clank is. Any chance its not enough oil in the engine when its first started? I changed my oil about 2 weeks ago and never heard the sound before, but its definitely gotten colder since the oil change and I've been driving the car less as well. I did prime the oil filter first before putting it on and I get good oil pressure after its first started. somewhere in the neighborhood of 50-55 PSI.
95 GTS, 5-speed
Bullitt Suspension, Pro3i C/C plates, MAC unequal shorites, MAC crank pulley, Stewart water pump, 180* stat, MAC CAI, H-pipe, flowmasters, '02 GT front calipers, chrome Cobra R's replicas
FordFactory is offline
post #11 of 15 Old 01-04-2002, 03:39 PM
When my pump went out on may car some years ago the clanking sound was the impleller hitting the pump housing. It was weeping a lot too. The bearings and seals just eventually go.
Terry Patton
Sold this one now... 95 5 speed 'vert...now with Fluidyne radiator, Pullies, 65mm TB, Bullet 75MAF, WMS Cold Air Induction w/ K&N, PBR 2 piston caliper brake upgrade.
THE 94 HAS BEEN TOTALED 3/19/02...LONG LIVE THE 95!!!
Used to have a:
94gt Convertible w/AODE (OINK!)
JMS Chip, Romac Balancer, Art Carr modified valve body and some internal upgrades, Borla cat-back, FMS 3.73 gears, FMS "B" springs & Tokico non-adjustables, Hotchkis CC plates
In my garage waitin' for heads...Cobra intake, 1.7RR's
TJ 94gt vert is offline
post #12 of 15 Old 01-04-2002, 03:43 PM
Terry Patton
Used to have a:
post #13 of 15 Old 01-04-2002, 05:05 PM
Possible Cause of problem
Check your belt tensioner. Often times if the tensioner is out as far as it will go, the front and back pieces will hit eachother where they cross and make a knocking noise as the belt tension varies. (you will see what i mean when you look at it.) This happened to me once and I couldn't figure out for the life of me where the noise was coming from untill i looked there. I figured that since this is close to the water pump, it may be the cause of this noise. Hope it helps.
Turbocharged 1995 Mustang GT
10.90 @ 130 mph
Stock Bottom End
Killer95GT302 is offline
post #14 of 15 Old 01-04-2002, 05:21 PM Thread Starter
paluka21's Avatar
Re: Possible Cause of problem
God do I feel like an idiot!
I did the ole' screw driver trick of listening to hear where the noise was coming from. Well its coming from the tensioner. Everytime the tensioner moves it makes a knocking sound!
So would the tensioner cause a squealing noise at idle as well?
Where can I get a new stock tensioner for a reasonable price?
thanks
Dan
paluka21 is offline
post #15 of 15 Old 01-04-2002, 09:06 PM
Guarddog II's Avatar
Usually when a water pump goes out it sounds like marbles...not like detonation marbles, but kind of like shaking ball bearings in your hands kind of sound.
Guarddog II is offline
