GT40X heads with Typhoon intake - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 06-25-2012, 09:26 PM Thread Starter
Hello all, i am new to this forum and i have been wondering about my current set-up that i hope to have in the next year... 1995 Mustang GT
Heads~ GT40X306
Intake~ Typhoon
Cam~ Comps 35-312-8 (even thought about either the X-cam or Z-cam)
CR~ 11:1
along with supporting mods, 30 lb injectors and 190 internal fuel pump
believe me i am aware of better heads out there and intakes, however i am just trying to get this car better than stock with any and all aftermarket parts i can think of, even if it's from ford, in order to get to at least 300 to the wheels, if not better. i have thought of ways to decrease weight in the front end and to keep it safe for my kids as well.
please do not stray to much off topic and thanks ahead of time
1995 Mustang GT: PA Racing K-Member + A-Arms, Bullitt Suspension Kit, LRS Rear Control Arms, Ford Racing Aluminum Driveshaft, Summit Racing H-pipe...Carb Conversion in process
A1CCrash7 is offline
post #2 of 17 Old 06-25-2012, 09:38 PM
Trader Feedback: (51)
I am building a mild 95 gt and after my research decided to go with the Steeda 19 to keep the stock ecu happy and still be able to pass smog. It seems to be one of the only aftermarket cams that plays nice with an un tuned 94/95 ecu. I don't know anything about your comp cam at all. You might have to get a tune.
The X heads are nice quality and good for a mild build. A couple of my friends have them and I've had the Gt40Y's and had no problems.
The Typhoon intakes are a bit of a crap shoot. I've had a couple and they were ok after I cleaned up all the casting flash. I'd never buy one new and unless I could get one cheap I'd rather have a Exploder intake for the same/less money.
92 Hatch On3 Turbo, T56
92 Vert 349 Lunati Stroker T5
87 Gt Eddy HCI T5
87 Notch in progress
fmyth is offline
post #3 of 17 Old 06-25-2012, 09:58 PM Thread Starter
true on the typhoon however, i found one for $310 at dynamicracing.com and the comp cam is
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,200-6,200
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 230
Duration at 050 inch Lift 224 int./230 exh.
Advertised Intake Duration 276
Advertised Exhaust Duration 282
Advertised Duration 276 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.544 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.544 in.
Valve Lift with Factory Rocker Arm Ratio 0.544 int./0.544 exh.
Lobe Separation (degrees) 112
Computer-Controlled Compatible Yes
Grind Number FW XE276HR-12
Valve Springs Required Yes
Quantity Sold individually.
Notes Designed to be used with 1.7 ratio roller rockers.
however i will use 1.72 rockers in order to make the lift an even .550"
post #4 of 17 Old 06-25-2012, 10:23 PM
1.72 rocker comes to .584 lift , stick with 1.6 rockers
93GRNLX is offline
post #5 of 17 Old 06-25-2012, 10:35 PM Thread Starter
no no...it's designed to be used with 1.7 rockers
post #6 of 17 Old 06-25-2012, 10:40 PM
LOL , then use a different cam , way too much lift for that setup IMO , the .544 would be good though trust me , my .542 lift cam setup also higher compression has dynoed 320 rwhp 342 rwtq SAE with a smaller intake than you are running , larger cam is going to slow air flow and make it a dog off the line
93GRNLX is offline
post #7 of 17 Old 06-25-2012, 10:52 PM Thread Starter
what cam are you running? comp cam or X-cam
post #8 of 17 Old 06-26-2012, 01:19 AM
I just sold 2 typhoon intakes for $100 for a cast and 125 for polished. Unless you have to have new you can pick one of these up cheap.
87 Gt Eddy HCI T5
fmyth is offline
post #9 of 17 Old 06-26-2012, 03:33 AM Thread Starter
how many you got...just wondering i have not gotten to my engine mods yet next up is my fuel system (new tank and pump and plumbing) then rear end and tranny rebuild and brakes...thank you though...if you have one in the next few months i shall ask ya if you got one or not....but jeez 125 for polished i do likey...i will definitely let you know about the polished cuz i kinda do want a nice and shiny engine bay
post #10 of 17 Old 06-26-2012, 06:48 PM
I found one here on the classifieds and another on craigslist. Keep your eyes open for bargains before you start your build. As soon as you really NEED a part you won't find it used and will have to pay retail....
87 Gt Eddy HCI T5
fmyth is offline
post #11 of 17 Old 06-28-2012, 08:19 PM
X
93GRNLX is offline
post #12 of 17 Old 06-30-2012, 05:03 PM Thread Starter
hows the vacuum of the X-cam... what readings are you getting?
post #13 of 17 Old 06-30-2012, 09:48 PM
SilverSmith82's Avatar
Trader Feedback: (26)
Even with 11:1 I doubt you'll see 300whp. The combo will probably run good enough provided the typhoon doesn't have issues with the ports and the cam selection is good. If you're going off the shelf with cams, look at the Comp Xtreme Energy line. Had very good luck with a XE270HR-112.
-2000 Mustang GT Steeda #0048. Going 4V, IRS swap in progress, original Novi 2000 car.
SilverSmith82 is offline
post #14 of 17 Old 07-07-2012, 10:48 PM
Never measured the exact number but it idles fine and brakes are fine
93GRNLX is offline
post #15 of 17 Old 07-08-2012, 10:39 AM
P63
Moderator
P63's Avatar
Why are you chasing a measurement? From your mod list, you don't have gears yet.
3.55 or 3.73, take your pick. I bet this will register on the SOTPM better than the HCI work you're talking about.
Victor Marshall
Copyright 2017.
P63 is offline
post #16 of 17 Old 07-11-2012, 12:49 AM Thread Starter
i am going with 3.73 with a T5Z gear set and having the cruising RPM be 2000
post #17 of 17 Old 07-11-2012, 02:46 PM
Cruising RPM at 70mph with 3.73s and a T-5z with a stock overdrive is going to be around 2300RPM depending on tire size.
