Anyone try cam bolts to fix camber issues? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-31-2012, 06:00 PM Thread Starter
This space for rent
99FiveOh's Avatar
Trader Feedback: (54)
Long story short my car is lowered and starting to eat the inner tire shoulder a bit. I know the car needs alignment but I was trying to hold out until I could score a set of CC plates. Well I still can't afford CC at the moment but want to get the car aligned. So, could I use those cam bolts to get me by for now? I completely plan to buy a nice set of CC plates when funds allow but I don't want to eat up any more tires in the mean time.
I'd appreciate any insight from someone who has used them. I have my stock CC plates slid as far as they'll go to eliminate negative camber but it's just not enough, I can look at it and tell it's still too much negative camber!
2003 Cobra - 2.3 Whipple, Return style fuel system, dual Walbro GSS342 pumps, Aeromotive FPR, SCT BA3000 MAF, Accufab TB, UPR X pipe, SRA conversion, MAC catback. 589 rwhp, 554 rwtq
1994 Cobra - TFS top end, S trim: 436 rwhp 425 rwtq SAE - sold
Sold
Originally Posted by kim View Post
There are two problems with the system. 1st is there are more parasites than hosts.... second, the parasites are allowed to vote.
99FiveOh is offline
post #2 of 6 Old 05-31-2012, 09:05 PM
Trader Feedback: (34)
I would think of it this way CC plates run 200 bucks maybe another 70 to install or a pair of tires runs 250 atleast and then you will still need the cc plates just buy the plates and hope you will still have some life left in the tires.Stan
'The true soldier fights not because he hates what is in front of him, but
because he loves what is behind him.' G. K. Chesterton
Ruslow is offline
post #3 of 6 Old 05-31-2012, 09:57 PM
Noslo5.0's Avatar
I use both on mine. The bolts are a great $30 fix. In my case, it lets the CC plates set up more toward the center of the car which gives me max clearance to the body with a coilover setup. Just using the CC plates alone caused interference.
'00 V6 conversion - Dart SHP 363, RPM XTs, RPM 2, 1-3/4 LTs, TFS 2 cam, 87mm Pro-M, Fox 80mm TB.
'10 Taurus SHO - defies physics routinely
Noslo5.0 is offline
post #4 of 6 Old 05-31-2012, 10:15 PM Thread Starter
This space for rent
99FiveOh's Avatar
Not sure you read my post thoroughly.
NoSlo, thanks for the heads up. I will get the bolts and see what happens. If it will get me withing spec I'll be a happy camper. The bolts and alignment together won't cost half as much as a set of CC plates!
Sold
99FiveOh is offline
post #5 of 6 Old 06-01-2012, 12:24 AM
MFE
Super Moderator
MFE's Avatar
Just an FYI, the inner-edge tire wear's root cause is toe problems, either the static toe setting isn't right, or the suspension is letting it toe out when the car is underway. The camber is simply concentrating the resulting wear into a smaller strip. The bottom line is, you can set the camber wherever you want, but if you don't address the underlying toe problem, all you're doing is moving the wear around the tire.
MFE is offline
post #6 of 6 Old 06-01-2012, 07:23 AM Thread Starter
This space for rent
99FiveOh's Avatar
I see. I know the alignment is out of whack. When I did my 5.0 conversion I used your DIY alignment guide thread to get the car as close as possible so I could drive it. I've actually been driving it for a year now and the inner tire shoulders are just now wearing out! And I put over 10k miles on it so I guess my home alignment was descent.
I was just holding off on getting a professional alignment until I could get some CC plates. I'm going to take my car to an alignment shop in a couple days and take the cam bolts with me. They can install the bolts if needed.
Sold
99FiveOh is offline
