#1 |
Does the Crowfoot need to be flush with Dampner? Balancer removal
Looking at the manual it doesnt appear that the crowfoot is flush at all. Looking at a video online, ASE certified guy on a 9 min video, he has it flush. Just wondering because I ran into an issue where the bolts that came in the Kit from advance didnt work. Good thing I had some for which we replaced my horn few yrs ago. I had ended up then getting bolts cause I borrowed the tool kit from advance at that time too. The bolts I have fit but they are about an inch too long for it to be able to fit flush against the crowfoot and fitting the foot flush to the balancer. I found a few that were an inch shorter and they were much better but wasnt flush. It had maybe 1/4 - 1/2 inch of space because the bolts have about an inch of non threads from the head of the bolt.
Just wondering which way I need to go about doing this thing. If i have to i will just get bolts same size but just threaded all the way.
__________________
95 V6 converted GT/SALEEN. Trick Flow heads, Crane CR 444231 (supp to be same as E), FR 1.6 Roller Rockers , Edelbrock Performer RPM 2 intake, 24 lb injectors, Mac shortie headers, Basani X-pipe with 2 chamber flowmasters,75 mm Mass Air, 70 mm TB, 3.55 gears, MSD 6AL with coil, 255 lb ph FP |
| Sponsored Links | |
Advertisement |
#2 |
As long as you have two of the same length that's all that matters.
Sent using nothing
__________________
95 GT Back from the dead. 342 stroker with 190 Trick Flow heads and intake and the other usual bolt ons with TR3650 transmission |
#3 | |
I actually thought about that logic but one thing I have learned in life is to be patient and ask questions if you aren't sure. I would much rather my car sit and wait till i take my time knowing what I am doing, than to rush and get it back running only to have to do things over. A few more things: Would it be wise to put a thin bead of silicone on the TC before attaching it to the housing/gasket? I know the gasket goes onto the housing first and let get nice and firm then put on he TC. Saw this video where a guy used spray on rtv looking thing
__________________
95 V6 converted GT/SALEEN. Trick Flow heads, Crane CR 444231 (supp to be same as E), FR 1.6 Roller Rockers , Edelbrock Performer RPM 2 intake, 24 lb injectors, Mac shortie headers, Basani X-pipe with 2 chamber flowmasters,75 mm Mass Air, 70 mm TB, 3.55 gears, MSD 6AL with coil, 255 lb ph FP Last edited by from6to8; 05-06-2012 at 08:07 PM. |
#6 |
A light layer of silicone is good. Also put a little extra in the corner where the oil pan, timing cover, and block meet.
Sent using nothing
__________________
#7 | |
i definitely dont want to screw that part up |
#8 |
and is it necessary to use thread sealer on the bolts?
__________________
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
