12 SECOND SET UP'S - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 18 Old 08-07-2011, 12:31 AM Thread Starter
sn95chico's Avatar
12 SECOND SET UP'S
What does it take to get a sn95 into the 12's...
Lets here what mods you have and your times ....
sn95chico is offline
post #2 of 18 Old 08-07-2011, 12:58 AM
memphis306's Avatar
any of the h/c/i "kits" will get you some low 12's with traction.
memphis306 is offline
post #3 of 18 Old 08-07-2011, 05:57 PM
Bullitt95's Avatar
I'm still about 4/10 short but a higher rpm stall torque converter, raised shift points (Baumann Optishift), and more weight reduction would get me there. Only problem is the first two would cost ~$1500 and that's without installation.
2006 GT Deluxe - 5MT - 12.67 @ 108.61
310rwhp 328rwtq with simple bolt-ons
Bullitt95 is offline
post #4 of 18 Old 08-12-2011, 01:58 PM
stock 94 shortblock gt40p heads cobra intake 1" spacer tfs 1 cam 1.6 rr BBK longtubes o/r x pipe bullet mufflers dumped and jlt cold air intake 24lb injectors with 4.10 gears and slicks got me 12.9 101mph
new setup chromolly tubular k member/a arms with strange 10 way adj shocks with coil overs. adjustable upper and SVE weight-jacker lower control arms eibach drag springs w/bag. stock 89 gt short block Trickflow TW 170 heads Anderson hi-rev valve springs, Anderson N-51hr cam Edelbrock performer rpm intake 75mm tb and a tune 343hp 368ftlb to the tire 107* ambient temp on the 9th dyno run.
at the track 12.1 @112mph needs to lose some more weight
LRScasey is offline
post #5 of 18 Old 08-12-2011, 04:20 PM
I ran an 8.5@85 mph and with a 2.2 60' time. That's about a 13.2 in the qtr or a 12.4-12.6 with a 1.7 60' time. I just run it like I drive it so skinnies, no sway bar, spare removal, etc............is out of the question. That being said, I run a 331 with GT40 cast iron heads, and a ported Cobra intake. My cam is in the 228-238 dur range and I run shorty headers with 3.73's. I'm about to bolt on Vic Jr heads, T-Moss ported RPM II intake, Comp Pro Mag RR's, and a 75mm tb. I want to run 7.9 spinning half way down the track like it would on the street.
1995 Crystal White Cobra
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #6 of 18 Old 08-17-2011, 10:15 PM
94CobraPace's Avatar
Vortech S trim on refreshed Cobra engine and sticky tires.
2010 Shelby GT500, Kona Blue W silver stripes.
2007 Shelby GT500, Vista Blue with Tungston gray stripes, 1 of 119, Wifes car...
94 Cobra Pace car Convertible # 591
2001 Cobra vert # 2001 SOLD
94CobraPace is offline
post #7 of 18 Old 08-17-2011, 10:24 PM
Alastang's Avatar
Trader Feedback: (43)
175 shot of Nos, u/d pullies, cai, 3.73 gears, shorty shifter, new igntion, centerforce clutch, and some M\T slicks got me to 12.5
Alastang is offline
post #8 of 18 Old 08-17-2011, 10:29 PM
stock bottom end, with gt40 x heads, f303 cam and cobra intake,30 lb injectors 70mm t/b 70mm maf, 1.7 rockers,shorty headers full exhaust, pulleys , and i still had 308 gears and i ran a 12.7 at 110 with drag radials then added s-trim with 42lb injectors and ran 11.9's then added a dss 347 block with all the same stuff and 100hp more and ran only 4 tenths faster because of traction
fast4point6 is offline
post #9 of 18 Old 08-18-2011, 11:14 AM
I do agree that the poweradder is the easiest route to take to hit the 12's, but it has far more downsides. All the extra plumbing, necessary to run 93 octane all the time. Varying ethanol content of the gas can cause a lean condition that loves to eat head gaskets in hot weather, heat soak without an intercooler, good setup requires a $600 tune. Nitrous bottle pressure is difficult to maintain if the ambient temp is over 100. We have had over 50 days this year over 100. The more you use it, the softer it hits until refilled. Tons of wiring for a properly set up street kit, cooler plugs foul more often under normal driving conditions, limited window of fun time. For a street car I say do it with cubes. Really not that much more cost if using used parts than a used supercharger. I have a mild stroker and get 27mpg on the hwy with the ac blowing.
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #10 of 18 Old 08-19-2011, 10:01 AM
Bullitt95's Avatar
A mild H/C/I 302 could get you into the high 12's, and a mild 331 stroker could get you low 12's or even high 11's.
You don't need forced induction to get those times, and the extra HP from a nitrous kit is short-lived.
post #11 of 18 Old 08-19-2011, 04:59 PM
Completly stock intake to pan 148k mile , 5spd with stock clutch, a boostbrothers 67mm turbo kit, 3:55 gear 14#s and a old accel dfi gen VI, and E85.
11.70@124mph I skipped the 12's and only have $4700 in the car $2800 was the turbo kit and the rest was gear and DFI and buying the car.
New parts are on the car and tuning it now should have a track time in a few weeks. Still stock junk 8.2 deck stuff.
I
I
I
1994 Mustang GT Single 67mm turbo, stock 4r70w/PI 4k lock up, Accel DFI Gen 6, 60# injectors, stock short block, ported '69 windsors, Systemax, custom Keith craft cam. E85 Corn baby! Looking for 10's!
Gameover is offline
post #12 of 18 Old 08-20-2011, 04:41 PM
Trader Feedback: (31)
Ran a 12.9 @ 106 on 28" et street radials with gt40 irons, tfs1 cam, gt40 intake, 4.10's. 1.7x 60 ft.
Ross
08 GT
MotiV8ed_95GT is offline
post #13 of 18 Old 08-22-2011, 01:11 AM
white93pony71's Avatar
Trader Feedback: (23)
slicks and a 150 shot will get you deep into the 12's...
white93pony71 is offline
post #14 of 18 Old 08-22-2011, 09:54 AM
paluka21's Avatar
GT40X heads, E303 cam, Stock upper/lower cobra intakes, exhaust, 3.73's, 80mm MAF, under drive pulleys, and Nitto drag radials: 12.9@105.7. I know the car would have went mid 12's on a good tire.
2014 Shelby GT00- Oxford White/Sonic Blue Stripes
1995 Rio Red Cobra #2021 - SOLD
8.8:1 comp. Dart 331, Procharger D1 16psi, AFR 185, Edelbrock RPM II, custom cam, TKO, Glenns 1000hp fuel system.
690rwhp on Mustang dyno
paluka21 is offline
post #15 of 18 Old 08-22-2011, 04:46 PM
Trader Feedback: (21)
I don't know about that.. I've been running an S trim with NO tune besides the MSD BTM and FMU for 6 years without having one single issue besides a melted spark plug wire..
12 psi +4.10's equals easy 12's.
I run premium all the time but in MT premium contains 0 ethanol
95 Crystal White Cobra #702
BLWNBYU is offline
post #16 of 18 Old 08-23-2011, 03:09 PM
US Army Active Duty
SVTCobra347's Avatar
Trader Feedback: (34)
Gears, slicks, 150 shot should do it assuming nothing breaks LOL.
SVTCobra347 is offline
post #17 of 18 Old 10-03-2013, 11:37 PM
LILBLKSNAKE's Avatar
12.33 @ 110 with 3.73's, full exhaust, 125 shot, DR's
1994 GT Convertible
1997 COBRA **SOLD**
2003 GT Convertible (Wife's Beach toy)
2013 Mustang GT 5.0 **SOLD**
LILBLKSNAKE is offline
post #18 of 18 Old 10-04-2013, 09:13 PM
Before I tore into the motor I had a stock t-body to oil pan 302 with a K&N filter, 3.73 gears, 14* timing and a flowmaster catback. I ran 14.3 around 96-97mph with a 2.1-2.2 60ft on street tires.
I then pieced together a Compucar n20 kit for under $200. On a set of $90 street tires I pulled a 1.92 60ft and a 13.1 @ 107 on a 125 shot granny shifting taking my sweet time as I did not want to powershift on the juice. I had mph for 12's easily.
Now a motor that is not stock and running a 150 shot.
blksn955.o is offline
