Best piston for nitrous???????? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 06-28-2011, 05:02 PM Thread Starter
Alastang's Avatar
Trader Feedback: (43)
I was just wondering what everyone's opinion of the best piston for a nitrous set up is.
Alastang is offline
post #2 of 11 Old 06-29-2011, 08:34 AM
Short Circuit's Avatar
Trader Feedback: (71)
Mahal flat tops, JE/srp flat tops or Probe flat top pistons, That's just what I heard, I have used Mahal and Probe personally, they were both fine, but I am not a engine builder. I just bought what was recommended.
I never went over 150 shot.
Talk to your engine builder.
Short Circuit is offline
post #3 of 11 Old 06-29-2011, 09:00 AM Thread Starter
Alastang's Avatar
I spray 175 on stock pistons but I know they are gone let loose at some point. Ordering parts for a 347 now and I dont want to have to worry about to much nitrous.
Alastang is offline
post #4 of 11 Old 06-29-2011, 09:26 AM
2618 forgings are the strongest pistons. Je, probe, cp, diamond, wiseco all these are 2618, then you have a 4032 forging such as mahle, srp, probe fps. The 4032 will not handle the same amount of nitrous as a 2618 forging, but 150, any of the 4032 forgings will handle with ease, how much nitrous?
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is offline
post #5 of 11 Old 06-29-2011, 05:00 PM Thread Starter
Alastang's Avatar
Thinking about running like a 250 shot. Nothing crazy but I want it to hold up if I want to get stupid with it.
Alastang is offline
post #6 of 11 Old 06-29-2011, 05:14 PM Thread Starter
Alastang's Avatar
I have looked at your 347 shortblocks on your website. Which one would you recommend for a street/ strip with a good shot of nitrous? I have a few guys with some GT 500's and 03 Cobra's that I cant do anything with right now and I want to leave them in the dust. Both of them cars are dynoed at like 480rwhp.
Alastang is offline
post #7 of 11 Old 06-29-2011, 05:16 PM
Trader Feedback: (32)
Does this also apply to force induction scenarios?? obv not going to use the same CR, strictly talking the material used as mentioned above.....?
95 GT 5.0 TW heads, Freezy 74 custom cam,S-trim,2.95 pulley,custom built intercooler,2.5 in and out running all on passenger side.65LB inj,BBK long tubes,O/R X pipe,mac flowpath,75mmtb.Tweecer R/T Dual Tuned92 octane/E-85 522rwhp on corn 10psi
gupthefish is offline
post #8 of 11 Old 06-29-2011, 10:04 PM
Consider one of his Dart based shortblocks, will remove much of the limits the factory block has. Then you can just keep going until you pull on those cars without hitting a limitation.
2007 BMW 335i
Goody_Seven is offline
post #9 of 11 Old 06-30-2011, 12:04 AM
250 shot on a stock block 331-347 will not last long, one tiny hiccup and your done. If anyone tells you otherwise, they want your money
strokeme is offline
post #10 of 11 Old 06-30-2011, 06:34 PM Thread Starter
Alastang's Avatar
would the stock block stroker hold a 175 shot or would I need to step up to the dart block? Seems like if the stroker makes 400-450 the 175 would be to much also, correct?
Alastang is offline
post #11 of 11 Old 07-01-2011, 01:01 AM
Your margins for human error and mechanical failure are very small, your window is narrow. Been done a million times and been blown up thousands of times. If your a gambler, you know the answer already. Think worse case scenario, always
strokeme is offline
