Car cranks over slow. Whats wrong? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 06-15-2011, 05:45 PM Thread Starter
fast94gt's Avatar
After I drive my car and get the engine warm, It wont restart. It cranks over very slowly and drains the battery very fast. If it cools down it cranks normal and fires right up. Whats up with this?
1994 Mustang GT. Yellow, Black Interior, 5-speed, 3.73 gears, cold air kit, Trick flow track heat intake, E cam, ported gt40's, aluminum underdrive pulleys,70mm throttle body, 255pump BBK long tubes, off-road h-pipe, 3 chamber flowmasters, pro5.0 shifter, mega bite jr.'s, Best time-8.84 in 1/8th
fast94gt is offline
post #2 of 9 Old 06-15-2011, 05:54 PM
Sounds like either your starter getting heat soaked and going bad or it's time for new grounds.
94 convert many mods and many more to come
Daves94vert is offline
post #3 of 9 Old 06-15-2011, 06:04 PM
well, the "mini" starters are known to fail when they get too hot... It is also know that long tube headers can cause the starter to get too hot much easier than shorties do. It is a very good possibility it is the starter. As someone else said this also could be a power/ground issue. What you may be identifying as a dead battery could actually be caused by either the power or ground wires not allowing current to pass. The heat may be causing some sort of expansion in the power or ground wire causing the wire to not allow amperage to pass thru the wires, so while 12 volts may be present, the wire doesnt allow the amperage to pass causing the slow/sluggish cranking. when the battery dies, have you tried going back a few hours later to see if the car will start easily? if so, is the battery in fact dead?
Turbo Teal 95 GT 5 speed
HP hotside, custom coldside, H/C/I, 526HP 569TQ
(old setup)V1SC 8lbs H/C/I 385WHP 380TQ
Blown 91 LX Coupe 5.0, 5 speed Sold
Dwain is offline
post #4 of 9 Old 06-15-2011, 09:07 PM Thread Starter
fast94gt's Avatar
Once everything has a chance to cool down it will crank right up. Im tempted to bring the batt back up front as much as I dont wont to. Look better with it in the trunk, but just one more thing to go wrong I guese
fast94gt is offline
post #5 of 9 Old 06-15-2011, 09:24 PM
This space for rent
99FiveOh's Avatar
Trader Feedback: (54)
when's the last time you replaced the starter?
2003 Cobra - 2.3 Whipple, Return style fuel system, dual Walbro GSS342 pumps, Aeromotive FPR, SCT BA3000 MAF, Accufab TB, SRA conversion, 604 rwhp, 581 rwtq
1995 GT - H pipe and welded in Flowmasters. Stock otherwise.
GT40 Aluminum heads, F-303 Cam, Holley Systemax intake, Procharger P600B kit 400 rwhp. Sold
Originally Posted by kim View Post
There are two problems with the system. 1st is there are more parasites than hosts.... second, the parasites are allowed to vote.
99FiveOh is offline
post #6 of 9 Old 06-15-2011, 09:29 PM
bigbroncojeff's Avatar
Plenty of people have batteries in the back that work fine... It's obviously your call but I'd find what is causing the issue. Hot/weak starter sounds like the issue since it cranks right up after cooling off. It wouldn't be the battery.
Hot cables won't cause an amperage passing through issue... The current passes around the outside of each strand of wire in the cable and it's not going to affect this. But do check the tightness of all of the connections and check for corrosion.
Where the #### are our picture signatures??
bigbroncojeff is offline
post #7 of 9 Old 06-15-2011, 10:02 PM
Check your grounds, and battery cables. Make sure there isnt any/too much corrosion... then if nothing is found, start looking to replace starter.
95 GT Convert|347 stroker
95 Cobra coupe|Rotrex supercharged|Sold
Former Dr.Gas X pipe distributor.
MRBiggs is offline
post #8 of 9 Old 06-15-2011, 10:07 PM
Future303's Avatar
I'm having the same issue, but my starter is ancient.
Mustang Preference: (Favorite to least Favorite):
94-98's
. 05+ Stangs
. A tie for 03-04 Mach 1's and 4 eyed Foxes
. Pre-80's Mustangs.
2 Eyed Foxes and New Edge.
Future303 is offline
post #9 of 9 Old 06-15-2011, 10:27 PM
Get a amp draw meter. It will tell if starter is problem.
Bubba 95SN is offline
