My Hurst Line Locker install and ABS Delete - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 23 Old 05-14-2011, 09:52 AM Thread Starter
Trader Feedback: (15)
Hello Corralers!
I had a hard time finding any information on installing the Hurst Line locker so I thought I would post a little info and Pictures of how I did mine!
For starters, I have a 1994 Cobra, which means it came with the Bosch ABS. This complicates things a little since it used different fittings that normal setups.
For starters, the Hurst Line Locker installation kit was useless for my car. None of the fittings fit on ANYTHING. This means you have to either make some lines with the right fittings you need, or you get them made. Fortunately, I can go directly to Bosch in Germany and get the exaxt stuff I needed to be successful.
First, I had already pulled the ABS stuff since it sat 1/2" from my Turbo down pipe and melted the hell out of the wires. So I purchased an extremely nice Billet ABS Delete Manifold from Home Of The Original 94-04 Ford Mustang ABS Delete Manifold! pbastian@adelphia.net The manifold is very light and very strong since it is Billet Aluminum. All of the drilled and tapped holes worked perfectly (no modification) with my brake lines. Another great thing with this was that I could use it to split the line going out of the line locker to the front wheels without any modification.
Second, I took my line locker and ABS manifold to Bosch and showed them what fittings I needed and what length of lines I needed. After 30 minutes, I was good to go. I picked up a line bender so that I could make any bends I needed (I had to bend 1 line I made).
I mounted the Hurst line locker in a place I thought would be best and routed the lines. It was a fairly quick install and I was satissfied with how it turned out. The only thing left is wiring and that is the easy part.
Pics:
94CobraGermany is offline
post #2 of 23 Old 05-15-2011, 07:03 PM
94_cobRa's Avatar
Trader Feedback: (109)
Looks great man. I would love to do this with my NON working ABS unit but I just cant push myself to pay $140 for the little piece of aluminum yet haha. Maybe one the turbo kit goes in ill get one!!
94 cobra - 351w - s480 - 5.72@125 1/8 8.896@156 1/4
94_cobRa is offline
post #3 of 23 Old 05-16-2011, 06:42 AM Thread Starter
The price may seem a little high, but once you get it you realize why. If these were made in bulk, I am sure it would be cheaper. But the quality of the Billet, its Lightness (does not require straps), and it fits perfectly with the fittings makes it worth while. I haven't found anything else that you could buy to delete the ABS and make it look nice. How much would it cost to fix the ABS? Also, with this manifold you will get firmer overall breaking since it no longer has to go through all the crap in the ABS unit. My ABS hasn't worked in years.
post #4 of 23 Old 05-16-2011, 03:28 PM
Nice job on the install..!!!
10.739 @ 128.63 mph 175 shot (Oct 2007)
Phil
http://www.prbmachining-absdeletemanifolds.com/
Fill is offline
post #5 of 23 Old 05-16-2011, 06:58 PM
94_cobRa's Avatar
I wont be able to fix my ABS. I have a 9" which does not accept the sensors.
94_cobRa is offline
post #6 of 23 Old 05-17-2011, 09:40 AM
Is it possible to install a line lock while retaining the stock abs?
1995 Crystal White Cobra
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #7 of 23 Old 05-17-2011, 12:31 PM
Yes, not a problem.
Phil
Fill is offline
post #8 of 23 Old 05-17-2011, 02:04 PM Thread Starter
I heard that it is also possible. If you route it the way I did, just minus the ABS Delete it should work.
post #9 of 23 Old 05-17-2011, 03:07 PM
I just put my abs delete and line lock on last weekend also. Got it from Phil as you did. I'll just say your installation is a little cleaner than mine. The ABS delete piece is very well made. Took the 95 gt out for a drive and everything went fine at this point. Wired in the Line Lock but did not power it up yet as I am wiring in a zex switch and a window switch at the same time.
95wanttobe is offline
post #10 of 23 Old 05-17-2011, 03:48 PM
Would you be able to tell me what size fittings I would need to accomplish this?
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #11 of 23 Old 05-17-2011, 03:52 PM Thread Starter
It is dark here but tomorrow I will try and measure the fittings for you. The car had 2 different sizes (to prevent people from messing it up) and the Hurst line locker introduced a 3rd size!
post #12 of 23 Old 05-18-2011, 07:54 AM
94-97 Gt/Cobra ports use (10mx1.0) & (12m x 1.0)
On GT's the port stamped F (front brakes) this is a 10mx1.0 thread.
On Cobra the port stamped F (front brakes) is a 12m x1.0 thread.
This is where the line lock solenoid goes to on the factory ABS pump or the ABS delete manifold.
Phil
Fill is offline
post #13 of 23 Old 05-18-2011, 11:53 AM
Yes, but I recently read this.
. The problem is that there does not exist a M12 x 1.0 thread union with bubble seats to adapt the stock brake line to the line lock lines. If an M12 x 1.0 union existed, you could use another M12 x 1.0 male to female adapter to adapt the M12 x 1.0 union to a 3/16" line with 3/8"-24 thread tube nut. But, an M12 x 1.0 union does not exist. I call everyone (I mean everyone, including Hurst) locking for this fitting.
and this..........
You'll have to cut the stock line, put a 3/8"-24 thread tube nut on it, reflare the stock line with an SAE double flare tool, use a SAE female to female union with with inverted flares. Another option is to use a M10 x 1.0 tube nut on the stock line and use the M10 x 1.0 union in the kit. Does not really make a difference, you're still going to have to cut the stock line and reflare.
Wish I had pictures of said parts or the actual parts. All this talk of double flares, tube nuts, etc.....is better seen then read.
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #14 of 23 Old 05-18-2011, 12:13 PM
For a Cobra, you will have to re-plumb/flare the front brake line from master cylinder to adapt to the line lock 3/8"-24 port, then from line lock to F port using the 12m x 1.0 brake fitting that was cut off the brake line.
For the GT it will be 10m x 1.0 for the F port.
The factory brake lines use a metric bubble flare, but you can get away with an SAE double flare.
Phil
Fill is offline
post #15 of 23 Old 05-19-2011, 09:53 AM
So cut the hose going from the MC to the block.
Remove the nut.
Flare the hose and install a 3/8-24 nut to go from the MC into the line lock
Install the 12m x 1.0 nut you originally removed onto a line that goes from the line lock and into the block.
This sum it up correctly? I'm gonna order one.
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #16 of 23 Old 05-19-2011, 05:44 PM
Remove the nut.
Correct, as long as the hurst line lock solenoid does takes 3/8"-24 brake fitting..
Phil
Fill is offline
post #17 of 23 Old 05-25-2011, 11:33 AM
The hurst line locker and installation kit worked great on my 94 gt. My Abs doesn't work due to a sensor in the rear being bad, but I still kept the abs box anyway. I will eventually delete it, If I don't get that sensor fixed in the rear. Took me a while to figure it out, cause all along I thought I didn't have the right size fittings. Once I figured it out, it was cake. Works great.
bigap15 is offline
post #18 of 23 Old 05-25-2011, 03:08 PM
Brian95's Avatar
line lock
i seen somewhere before that when using line lock that the brake light flashes or check engine light comes on is this the only. needing to do this to car.
95 YELLOW GT 363 ported TW heads,AFM 52s810 cam,BOX R intake,90tb,60lb,97dbx,powerpipe,1 3/4 LT, Powerglide 4.56,200 dry shot, full upr suspension
Brian95 is offline
post #19 of 23 Old 05-25-2011, 05:11 PM
StarrMan's Avatar
I've had the Hurst line lock installed with my ABS for over 7 years. No problems at all and have never really seen any dash lights come on when using it.
The Hurst unit has more ports than needed. Only needs one port in from the master cylinder and back out to the ABS modual.
In Loving Memory, My Son, Anthony Michael Starr 08/14/2007 - 01/21/2008
- 95 GT - Aluminum Heads, Cam, TMoss Cobra intake, S-trim, SCT BA2400, 55's, Longtubes, McLeod bell, TKO-600, 3.55's, etc
- 02 GT (Wife's Toy) - Auto, 4.10's, Lowered, Off Road X, Predator Tuner - 13.6@102
StarrMan is offline
post #20 of 23 Old 07-03-2011, 01:22 PM
zacs86's Avatar
PLUG TO THE ABS CONTROL
SO WHAT DO YOU DO WITH THE BIG UGLY PLUG ON THE ABS UNIT AS I AM DELETING MINE ON MY COBRA AND I WANT TO DO AWAY WITH THE PLUG
TOO
1995 cobra
zacs86 is offline
post #21 of 23 Old 07-04-2011, 12:42 AM
Adam95GT's Avatar
TOO
You can de-pin the harness and remove the wires...
Just a Vert...
Originally Posted by spydermandb View Post
Using a B cam is like taking a shiit on a cake, tuning around the b cam is just like adding extra frosting to cover up the crap.
Adam95GT is offline
post #22 of 23 Old 07-05-2011, 08:25 AM Thread Starter
TOO
I hide them behind my radiator in the spot where my A/C cooler was. I decided to hide all my engine bay wiring and it cleaned up great. yes that is a BIG plug and it was a motivating factor to hiding all wires. It was also hitting my Turbo downpipe and I was afraid it would fry something.
post #23 of 23 Old 07-16-2011, 12:42 PM
TOO
Use some tie wraps to help hide it.
Phil
Fill is offline
