Engine cuts out while driving - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 23 Old 02-04-2011, 03:17 PM Thread Starter
I have a 1994 GT with about 150k on the clock. It just developed a new but infrequent problem. I'll be driving along and suddenly the tach will flat line to 0, check engine light will come on, and then suddenly the engine comes back to life again. It happens so fast that I can't tell if the engine starts back up on its own or if I shifted and the clutch pop started the engine.
Any ideas what could cause this? Ignition switch maybe?
Corey
2001 True Blue Bullitt
1994 Mustang GT
1965 Mustang
50 Proof is offline
post #2 of 23 Old 02-04-2011, 07:17 PM
Sounds like it might be the stator in the dizzy. Its a small part inside the distributor housing that causes the sn's to cut out suddenly and randomly start up whenever it feels like working again. May be a minute, or 4 days. Its cheap and an easy fix.
94 Canary GT. Basic stock block hero.
Yellow5slow is offline
post #3 of 23 Old 02-04-2011, 08:39 PM Thread Starter
Thanks for the suggestion, I'll check that out.
Corey
1994 Mustang GT
1965 Mustang
50 Proof is offline
post #4 of 23 Old 02-05-2011, 10:27 AM
Mayosailor27's Avatar
Replace the dizzy dont just replace the pick up coil. Try not to geta remanned dizzy because the pickup can be good when they test it (cold) but once it gets hot in your car it s***s out
Machinist Mate, USN
1995 Real Cobra Saleen Clone #969-(it will catch your eye) Full Saleen Urethane, 18" Real Saleen's (96-98), Rare T-1 spoiler, Cobra R hood, L/T's, O/r H, Flows, Borla, susp.
Mayosailor27 is offline
post #5 of 23 Old 02-05-2011, 03:00 PM Thread Starter
Thanks for the suggestion. I was doing some more searching last night too, sounds like the recommended advice for an sn with high mileage is to just replace the dizzy with a brand new one (not reman).
Corey
1994 Mustang GT
1965 Mustang
50 Proof is offline
post #6 of 23 Old 02-05-2011, 07:59 PM
Been using a billet dist from Summit for 1.5 years. 0nly 1900 miles. Toy not dd.
Bubba 95SN is offline
post #7 of 23 Old 02-06-2011, 03:18 AM
Bullitt95's Avatar
Exactly. A new OEM dizzy would be your best bet but if you have trouble finding one, the Summit Racing billet aluminium unit is a good substitute. I have 6500 miles on mine.
2006 GT Deluxe - 5MT - 12.67 @ 108.61
310rwhp 328rwtq with simple bolt-ons
Bullitt95 is offline
post #8 of 23 Old 02-06-2011, 03:42 AM
I've always just replaced the pickup in the OEM dizzy if the unit still spins well without any sqeaks. All has been good.
Plus its cheap, the pickups cost about 25 bucks and a new dizzy (especially OEMs when you can get them) are 125+ bucks.
95 GT Convert|347 stroker
95 Cobra coupe|Rotrex supercharged|Sold
Former Dr.Gas X pipe distributor.
MRBiggs is offline
post #9 of 23 Old 02-06-2011, 11:13 PM Thread Starter
I'll pull things apart and take a look. If the dizzy seems alright, I'll just replace the sensor. Thanks for the replies.
Corey
1994 Mustang GT
1965 Mustang
50 Proof is offline
post #10 of 23 Old 02-07-2011, 02:33 PM
Bullitt95's Avatar
Your dizzy is 17 years old and it's gone well past its design life. I also thought my original dizzy would last forever until it started breaking rotor tips 'cause the shaft bearings had worn (it never squeaked so I had no warning). Replacing the PIP sensor and then getting stranded at the roadside a few months later with an engine that refuses to start (broken rotor tip) isn't fun, so it's a false economy just to replace the PIP sensor. I learnt that the hard way and you don't have to.
post #11 of 23 Old 02-08-2011, 11:26 AM
Draggin90's Avatar
Trader Feedback: (28)
If the distributor checks out, check the ground strap from the engine to the body. I had a car do that exact same thing and found that the ground strap was loose. Fixed it for free!
Draggin90 is offline
post #12 of 23 Old 02-08-2011, 12:16 PM Thread Starter
Good suggestion, I'll check that too. Thanks.
Corey
1994 Mustang GT
1965 Mustang
50 Proof is offline
post #13 of 23 Old 04-07-2011, 01:18 PM
LeKiD302's Avatar
what are the code ??
2003 SVT Cobra Whipple 2.3L
1.51/10.86@134mph
LeKiD302 is offline
post #14 of 23 Old 04-07-2011, 10:12 PM
Brian95GT's Avatar
Takes 2 seconds to do, but check the battery terminals. If they are loose, the engine will cut out while driving. You can rule this simple possible cause out fast too.
1995 Rio Red GT 5-speed Coupe
2011 Black Edge AWD Limited
2003 Black Centennial GT Auto Convertible
Brian95GT is offline
post #15 of 23 Old 04-08-2011, 08:44 AM
Bullitt95's Avatar
So will everything else that's electrically operated.
post #16 of 23 Old 05-03-2011, 04:16 PM
Jsut wondering if you ever fixed this problem?
Been having a similiar issue in my '95 and has gotten much worse in the last few weeks (I only drive the car every once in a while).
Did you change out the distributor or just the pick-up coil/strator?
1995 Cobra Convertable #360 of 1003
Craig K. is offline
post #17 of 23 Old 06-01-2011, 11:48 AM
Anyword on this and if so what was the fix...PIP, Distributor???
Craig K. is offline
post #18 of 23 Old 08-11-2011, 02:13 PM
I have a freind that has a 2001 cobra that does the same thing he will be driveing it and the gauges will wack out and the car will run realy rough and he has to get it off the road and if he lets it sit for awhile it will start up and run fine and wont do it agine for some time does any one have any sugestions
roadrunner2812 is offline
post #19 of 23 Old 10-10-2011, 11:20 PM
Check the power cable going from the battery to the fuse box under the hood........these cars have a bad habit of this cable coming loose for some reason.
STRACER is offline
post #20 of 23 Old 10-13-2011, 10:18 PM
SN-95's Avatar
Sounds like your CCRM CRM CONSTNAT CONTROL RELAY IT HAS A ,FUEL PUMP RELAY INSIDE OF IT.
SN-95 is offline
post #21 of 23 Old 10-14-2011, 02:26 AM
I just fixed this.
I had identical symptoms on my 95 with the same mileage. I just bought a NEW not remaned distributor. Problem went away, been 3k miles.
Dan...
Remow2112 is offline
post #22 of 23 Old 10-14-2011, 12:38 PM Thread Starter
Sorry for not getting back to you guys. The problem is happening so infrequently still that I haven't wanted to spend the money on a new distributor. I don't doubt the advise given here, I'm just being cheap at the moment.
Corey
1994 Mustang GT
1965 Mustang
50 Proof is offline
post #23 of 23 Old 11-02-2011, 05:42 PM
As a follow up I put in a remanufactured distributor about 3 months ago, driven the car a bout 1,000 miles and no issues thus far.
Craig K. is offline
