#1 |
tire size on 95
i am looking on getting lighter tires and rims i have 2001 cobra polished with 245-45-17. what would be a good tire size either 15 or stay 17
__________________
95 YELLOW GT 347 ported TW heads,N-91 cam,BOX R intake,75tb,60lb,97dbx,powerpipe,15/8 equal shorties,prochamber,2 chflow,tko 600 4.10,drag springs w/ airbag,150 shot dry kit HP 353.69=TQ378.99=MOTOR old combo HP 466.11=TQ540.54=150 SHOT |
| Sponsored Links | |
Advertisement |
#2 |
Depends on what you do with the car. If it's a DD, find what you like and look to see what they weigh. Pick what you want based on looks and weight. If the car is a weekend warrior, pick up some Weld's.
Jason
__________________
95 Cobra #2604 Crystal White 271 HP 331TQ Lookin' for more HP GT-40 Y's, Crane cam, BBK LT's, 3.73's, Bullit suspension package and QH tuned by me. 02 F250 PSD SC LB 4x4 DP Tuner 300 HP 600TQ
#3 |
For a daily just get whatever you think looks the baddest ass and run that. For a drag car get some 15" welds. For autox be prepared to pay for a really light wide rim.
__________________
-98 Atlantic Blue on Black. PI swapped. Actually enjoying it vs fixing it till its broke this time. -00 Contour SVT #1245 of 2150. Daily driver, basic bolt ons, big brake kit. -95 Cobra SVT #3914 301whp/325 wtq - Sold 2011
#4 |
as of now its not street legal but its not a dd either if i go 15 what size tire will fill wheel well and look good.
__________________
#5 |
Moderator
Will a 15" wheel fit on your car?
The following is a comparison for cobra wheels. I don't know what size tire/wheel you're starting with. Also, keep in mind that using a tire with less mass than stock can be dangerous, especially in the case of spirited driving over the speed limit. But if a person wanted less-unsprung weight and rolling resistance, they might decide to get a 17x7" wheel (if such exists) 7" is about 178 mm The outside dia of a cobra wheel is 2*(.45*255/25.4)+17= 26.0". So to maintain your diameter, let's go backwards to find the necessary profile: 26.0 = 2*(P*178/25.4)+17 solving (26.0-17)*25.4/(178*2) = p p=64 Of course, there's no such thing as a 180/65-17... The closest thing I see at discount tire is 185/55-17 which will have an inch less outside diameter than we started with. So lower the car along with your tire costs, and enjoy a better ride and slightly increased acceleration (about 4% more torque). All bets of safety will be out the window with respect to high speed driving, so obey the speed limits. Undersized tires can fail catastrophically. Note also that the car will be lowered half an inch closer to the ground, but you will also get an additional 1/2 inch clearance to the fender, so your highwaters will get higher. Your speedo will also be off. Hope this helps.
__________________
Victor Marshall Copyright 2013. May be quoted on the Corral. Not to be otherwise copied or reprinted without permission. Last edited by P63; 09-23-2010 at 01:12 PM. |
#6 |
Also remember that 15" wheels can have issues clearing stock brakes, especially 13"+ since most guys like to upgrade to at least the SN95 Cobra or Bullitt units.
I went with 18x9 and 18x10.5 Saleens for my weekend/great weather driving Cobra and would not have it any other way for the street. Something to be said for having a 295+ wide tire out back.
__________________
#7 |
Banned
Trader Feedback: (-1)
P63, your math is wrong, mathematically, a 255/45/17 tire should be 26.03"
IMHO, a 17x9 set of wheels should run 245/45/17 front and 275/40/17 tires 17x9-17x10.5 sets should run 245/45/17-275/40/17 front and 315/35/17 rear 15x3-15x8 wheel sets should run 165/80/15 front and 275/50/15(26x10.5x15) As for a skinny 17" wheel. There is a company (hankook?) that makes a 26" tall skinny R17 tire. |
#10 |
Trader Feedback: (22)
I'm happy with my 18s. Car is dropped about 1.75" all around..i'm running 265/35R18 and 295/35R18.
Its also good to have a 2nd set of wheels. 1-Show Wheels; 1-Race wheels
__________________
1994 Canary Yellow Mustang GT - 14.4@96 ~ Explorer Intakes ~ E303 ~ 65MM TB ~ DirtyDirty Tune ~ MAC LTs ~ X-pipe ~ Spintech ~ Tri-Ax ~ KYB AGX ~ Tokico Blue ~ BBK Springs ~ Factory 5 Arms ~ Saleen Kit ~ 18x8/10 Chrome Saleens |
#12 |
My car's lowered 1.5" and I had 17x9 03 Cobra's with 275/40's and it looked good. I never got a chance to weigh them but they were heavy as hell. Now I have 15x4's and 15x10's Centerline Warrior's with 165 metric's and 275/60r15's and they fill the wheel well so much better with a ton of clearence. The new wheel's weigh 25lb's each on the front's and 43lb's each on the rear's, that's tire,wheel,lug's,and center cap's. The 275/40's are 26" tire's and the 275/60's are 28" tire's but they both look to fill the wheel well pretty good.
#13 | |
Trader Feedback: (60)
IMHO, 245 is way too small for anything larger than 17x8. It looks funny.
__________________
-1995 Cobra #182 of 4005; 275hp/ 305tq, 221k miles, export tails/mirrors, etc -1996 Mystic Cobra #1666 of 2000; 308hp/304tq, ARH L/T & X, IMRC deletes, Mezeire, LMAF, JLT, MM suspended, 194k miles -1993 Mustang LX, 2.3L w/ T5 conversion, SN95 suspension w/ 8.8, 03 Cobra steering/brakes, 263k miles |
#14 | |
Banned
it makes a difference not to mention, he edited his post to correct what was up there... so keep your remarks to yourself Last edited by AdderMk2; 10-03-2010 at 08:17 AM. |
#15 | |
Lets stick to the facts: Op stated he has 01 Cobra wheels in his original thread. If you run a 245/45/17 front tire on a stock 01 Cobra wheel (17x8) that would be the smallest I would run on there, otherwise the beads tend to balloon out wider than the tred and it looks horrible. If you like the look of a stagered set (backs wider than the fronts), then run a 275/40/17 in the back to match your 245/45/17 fronts. they will fit comfortably on your 17x8 rims and look killer. not only that, they will fit n your fender well with no modification. If you do not like the look of a staggered set, you can even go as wide as a 275/40/17 in the front without rubbing on a '95 (I do it with my autocross wheels). If you want to go wider than a 275/40/17 in the back, be prepared to spend some coin on a set of wider wheels because a 295 will physically mount on a 8" wheels, but it isn't really that safe. and if you decide you want to go with a 315 wide rear you need nothing less than a 10.5" rim and remove your quad shocks for clearance. My setup ('95 GTS) Street: is 245/45/17 front 275/40/17 rear on Stock 01 GT Bullits 17x8 Autocross: is 275/40/17 front and rear on 17x9 Aftermarket Bullits from American Muscle.
__________________
MY LUGNUTS REQUIRE MORE TORQUE THAN YOUR HONDA MAKES
#17 | |
As far as keeping my remarks to myself, fat chance. This board could do without your constant mr. know it all attitude and continous snide remarks towards people coupled with your holier than thou demeanor. You're no better than the rest of us so shove it.
__________________
#18 | |
Personally if you're going with a 17x8, the width should be at least 255. Its what came on my '95 Cobra from the factory and it just looks "right".
__________________
#20 |
ripnitup did you have to remove the quad shock and did u have to clearence anything. i would like to go either 275 or 315.
__________________
#21 |
Banned
275's dont require the removal of the quad, however you might need to flip it end for end. Im not sure if the quad can stay with the 315's because I had already removed mine... I doubt they will, realistically... because I had to bend my inner fender lip slightly due to rubbing.
#22 |
i have been told that sn95 have more room in the rear for bigger tires than fox cars. just looking to fill wheel well up without cutting lip. i guess looks like biggest i could go is 275
__________________
#23 | |
Eveyone knows that not all tire manufacturers keep a consistent width so maybe you could get away with using quads with Nittos but not BFGs.
__________________
#25 |
My car is lowered well past 2" using MM adjustable coilovers and heavy springs. With that set up, I have the AREs Torque Thrust IIs 17x9s (10' lip to lip) up front and 17x11s (12" lip to lip) out back with 275 40s (front) and 315 35s (rear) Nitto tires. I don't know if I had to remove the quad shock but I did it because I installed the MM lower control arms and coilovers all at the same time. I went with Nittos DR in the rear because they were just a bit narrower than the other tires so I could clear the fender lip. I did not want to have the rear of the car up high to clear the tires, which is greatly aided by the MM adjustable coilovers; they allow me to adjust as necessary. I have no rubbing of the tires. You can get an idea of the rear by the picture in my avatar. Oh and they look nasty, too.
__________________
95 Mustang Cobra (Black on Black on Black) Engine: Owner built 306, forged bottom end, AFR 165 (10:1 CR),Edelbrock Performer RPM, 75mm MAF,BBK 70mm TB, MAC CAI, lunati cam,Crane gold 1.6rrs Electronics: TwEECer R/T-1.30v(J4J1),MSD 6AL, wires/coil, Autometer lunar gauges Suspension/Chassis: MM Coilover (F/R), MM LCA/UCA, '03 Cobra LCA, global west subframe Suport System: Walboro 255, Fluidyne, 3.73s, Yellow top battery B&M ripper Looks: ARE Torque Thrust IIs, 17x11 (315/35), 17x9.5 (275/40) Last edited by Methodical; 10-12-2010 at 11:42 PM. |
#26 |
I have 315 NT555s under my 95 over 17x10.5 95 R replicas. My biggest issue is clearance to the inside (as little as 1/2" at some points) which became an issue during autoX even with a panhard bar installed.
The wheels fit fine with the quad shocks and stock tailpipes (both of which have since been removed) - only thing I had to do was bend the e-brake bracket on the lower control arm.
__________________
1995 Cobra Black/Black, cloth interior. 12.84@109 |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
