how do you bleed air out of cooling system? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 07-01-2002, 10:44 PM Thread Starter
94svt5.0's Avatar
All this talk about bleeding the air out of the cooling system, but how is is done?
1994 cobra # 1067
white ex./black leather int.
-Crane 2031 cam
-Bullit suspension
-BBK off road h-pipe
-basani cat-back
-superchips power chip
-mac cold air induction
-frpp king cobra clutch
-18" konig wheels with nitto 555zr
- 3:73 Ford racing gears
-Ford Racing aluminum driveshaft
-Auburn HD limited slip diff.
- 75 mm bullet MAF
94svt5.0 is offline
post #2 of 8 Old 07-01-2002, 11:35 PM
a few thoughts...
start the engine, heater max, and squeeze and release (and repeat) the upper radiator hose to draw the fluid...before the engine warms up and overspills...rev it a few times
open the radiator and park on an incline and leave it overnight or while on the incline do like above...
get it as full as possible and drive over bumpy terrain and then open the cap and do one of above...
slo95 is offline
post #3 of 8 Old 07-02-2002, 02:56 AM
Lee8995's Avatar
ROFLMAO
Thats really good man I have to compliment you on that one. Dont take me wrong I am not being an @ss, But there is an easier way than driving down a bumpy road. Just fill your cooling system and break the temp sender loose in the intake screwing it out til its only got a few threads left in the intake. You will notice the sound of air escaping around the threads, Let it bleed the air until you get steady coolant and no air bubbles. The reason this is the best way is because this is the highest point in the cooling system behind the thermostat and all air will trap there in the intake. Do this with the engine stopped.
The real reason that we can't have the Ten Commandments posted in a courthouse is this:
You cannot post 'Thou Shalt Not Steal,' 'Thou Shalt Not Commit Adultery,' and 'Thou Shall Not Lie' in a building full of lawyers, judges and politicians...It creates a hostile work environment.
Lee8995 is offline
post #4 of 8 Old 07-02-2002, 10:37 AM
glad you liked it...I was rollin as I typed it
slo95 is offline
post #5 of 8 Old 07-02-2002, 05:23 PM
Location: tallapoosa, georgia(half way betweeen ATL and B'Ham--in other words NOWHERE!!)
SLO--that is really funny that is what I did to get my wife to pop the baby out!! Kind of the same idea!!
1995 Cobra Coupe(weight 3440) #1011 0f 4005 built(not counting R's),69,000 miles, birth date 1-18-95, rio red(E8) with black interior (4J), 1 of 535 in that combo, Vortech S trim, 435.6RWHP, 441.6RWTQ(before nitrous), NOS stage 1,--every mod you have ever thought about or dreamed about!
Former 2001 cobra coupe owner--went to cobra heaven!!
Loosing weight has the same effect as gaining HP and is usually a lot cheaper!
ratman is offline
post #6 of 8 Old 07-02-2002, 05:55 PM Thread Starter
94svt5.0's Avatar
Crap.... just tried the bumpy terrain. It was going good untill I hit a rock at 45 mph..... screwed up my rims
1994 cobra # 1067
-Crane 2031 cam
-Bullit suspension
-basani cat-back
- 75 mm bullet MAF
94svt5.0 is offline
post #7 of 8 Old 07-04-2002, 11:47 AM
It doesn't burp itself? Usually a day or two of topping off the overflow between stops takes care of it.
bard is offline
post #8 of 8 Old 07-04-2002, 09:27 PM Thread Starter
94svt5.0's Avatar
I just drained part of my radiator to add a greater mix of water to antifreeze. Well, when I went to fill it back up, it ended up holding more then I drained out I must have had some giant are pocket or something. Now the car runs 10x cooler. Cant believe it.
1994 cobra # 1067
-Crane 2031 cam
-Bullit suspension
-basani cat-back
- 75 mm bullet MAF
94svt5.0 is offline
