GROUP BUY: Russel Fuel Line Fittings - Page 7 - Ford Mustang Forums : Corral.net Mustang Forum
post #211 of 275 Old 06-20-2010, 03:51 PM
Would the quick connect fittings work on the sending unit? Or are there ones that would. I posted in another post about redoing my fuel lines.
MJ86GT is offline
post #212 of 275 Old 06-21-2010, 01:14 PM
StarrMan's Avatar
Not sure, I can't remember what the connector is like for that, but here is a link to a good article about running braided fuel lines from the pump using some neat compression fittings.
http://www.mustangandfords.com/proje...fuel_pump.html
StarrMan is offline
post #213 of 275 Old 06-22-2010, 10:59 PM
Trader Feedback: (15)
holy #### 7/12 until the last peice is shipped anyone got a set they are not putting on for awhile maybe i could buy them at summits price i need them asap
customsound is offline
post #214 of 275 Old 10-08-2010, 02:01 AM
everyone whos done this did you run braided lines from the tank? or just in the engine bay? whats a part number for the lines?
i_love_my_stang is offline
post #215 of 275 Old 10-08-2010, 12:25 PM
I think you're missing the point of the new specially-made fitting.
No.. I'm not "Fast."
Originally Posted by fkurls1 View Post
Simply awesome! Its like you came down from forum mountain with two stone tablets...
Fast94CobraSVT is offline
post #216 of 275 Old 10-08-2010, 12:28 PM
no i know theirs a new fitting but is that for running braided lines from the tank? or just new lines in the engine bay?
post #217 of 275 Old 10-11-2010, 12:39 PM
No, the new fitting is to connect to the existing hardlines. Fittings to run braided lines from the tank have been around for years.
post #218 of 275 Old 12-11-2010, 04:35 PM
408gt91's Avatar
Any pics of these kits installed?
408gt91 is offline
post #219 of 275 Old 12-22-2010, 11:37 AM
StarrMan's Avatar
There are pics on the previous 2 pages (5 and 6) of this thread
StarrMan is offline
post #220 of 275 Old 12-30-2010, 06:25 AM
Where can I find That?
PSST-GT is offline
post #221 of 275 Old 12-30-2010, 09:03 AM
SVTOA Chapter Director
95SVT5.0's Avatar
You can get them at jegs, sumitt. Not sure of the part number, just moved all my stuff is packed. Do a search, you will find the part #.
South Eastern NC SVTOA Chapter Director
1996 SVT ROUSH Cobra
1994 F150 Lightning
SOLD! 1995 SVT COBRA #1723
95SVT5.0 is offline
post #222 of 275 Old 01-15-2011, 10:18 PM
TrickVert's Avatar
Trader Feedback: (28)
Finally going to get around to doing this, and will be heading to Summit next week for supplies. One shocker, though, was that nylon braided hose is more expensive than stainless-braided ($39.95 vs. $26.95)? --and yes, same size and length.
Any big plus to one over the other (other than appearance?) One thing that I seem to recall is hearing that braided stainless hose can abrade things it comes in contact with (other lines, for instance)?.
I'll likely pay the extra for the nylon, since it will likely be easier to work with, and I don't have anything else dress-up" under the hood. I'm still curious about the cost delta and benefits of one vs. the other, though.
Andy
'95 GT Vert - Rio Red - Grey Leather - Black Top
TrickVert is offline
post #223 of 275 Old 03-06-2011, 10:22 AM
what length lines do you use?
Johnspec is offline
post #224 of 275 Old 03-06-2011, 10:52 AM
and the pdf file for the install instructions doesnt work
Johnspec is offline
post #225 of 275 Old 03-07-2011, 07:04 PM
n/m gonna go with the goodyear efi cheaper and seems to do the job well
Johnspec is offline
post #226 of 275 Old 03-20-2011, 11:40 AM Thread Starter
FastGT94's Avatar
Trader Feedback: (37)
I think russel's website has em too if you search around
-Dale
1994 Mustang GT TKO 500 5 spd
Fox 75mm TB, FTI Ported Edelbrock Perf RPM, 58cc AFR 165s, FTI Cam, 4.10s, Drag Susp, PMS Tuned by Mike Post
316 RWHP & 335 RWTQ // 3,225 lbs with driver and fuel // 11.919 @ 113.92 All Motor
FastGT94 is offline
post #227 of 275 Old 04-26-2011, 01:23 AM
92stanggt5.0's Avatar
For anyone that is looking for the high pressure firewall side push on connector. Part number 641303, which is the black one. I contacted about 4 vendors and none of them had any in stock. I had been waiting for one from Summit for about 3 weeks and am now to the point where I am going to be needing it. So at that point I figured I would just try contacting them direct. I did and I must say that the woman that I talked to went through all the trouble and had the people at the factory whip up another fitting and they are going to ship it to me direct.
So, if you are looking for a fitting that they do not have in stock at any vendors I suggest contacting them direct. They are more then willing to help and it will only end up costing a few bucks more.
FWIW
1995 Cobra white/tan and a T64
92stanggt5.0 is offline
post #228 of 275 Old 04-27-2011, 09:58 PM
Short Circuit's Avatar
Trader Feedback: (71)
FWIW
Can someone post up the step by step install or how to for these fittings with pics when you install yours? that'll be awesome!
I am in a same boat. I ordered the black ones from summit and havent got the last fitting that you mentioned. I will be giving them a call as well.
Short Circuit is offline
post #229 of 275 Old 05-16-2011, 10:14 PM
1svtfan's Avatar
As much as I love using stainless or pro-lite hoses eventually they all smell like gas. I wanted to find a simple solution and ideally using PTFE hose so I would not have to worry about the gas eroding the rubber lines. I decided to go with these.
Fragola Performance Systems 375024 - Fragola Performance Systems P.T.F.E Hose Assemblies - Overview - SummitRacing.com
They are pre-made 30" braided stainless lines with -6 fittings on both ends. A 45 degree for the rail end and a straight end for the hardline adapter. It saves quite a bit over making the lines myself as well.
All (4) Russell fuel lines fittings and (2) of these hoses make it a $133 project. (Actually $132.70 plus the shipping charge)
For what it's worth, I figure this makes the entire swap about a 15 minute affair.
This is a link to the Fragola pages where they clearly state these lines are designed for nitrous, fuel, oil, or water.
I'm going to put the hoses in split loom to keep the abrasion at a minimum, and figure they should last at least as long as the factory ones.... I'll post an update and pictures when the box gets here from Summit.
Here are the parts. You should be able to see the part numbers clearly.
Here's what they look like assembled in some split loom ready to go on the car.
1svtfan is offline
post #230 of 275 Old 05-30-2011, 07:23 AM
Very nice find my friend! Be sure to post some pictures the when you are finished.
post #231 of 275 Old 07-13-2011, 03:53 PM
powered427stang's Avatar
Need this fitting!
Where can i order this! I need it asap!!!
powered427stang is offline
post #232 of 275 Old 07-13-2011, 07:24 PM
All are available from summit. I just got these not too long ago as well. not installed yet.
post #233 of 275 Old 07-14-2011, 09:37 AM
TrickVert's Avatar
Hey, 1svtfan, how did the 30" lines work out? Any pics?
Andy
post #234 of 275 Old 07-14-2011, 11:23 AM
1svtfan's Avatar
Andy
Hey Andy,
Sorry, work has taken over the last few months and a leaking fuel filler neck sidelined me. I'll try to get some up this weekend. My intent was to post the how to with pics but just buried. Shortly
Steve
1svtfan is offline
post #235 of 275 Old 07-15-2011, 08:35 PM
ZoSo15's Avatar
Andy
I got the same set he did and posted pics in the other thread. Here's a link to the post. Not a step-by-step but should give you an idea.
They work great. I was still getting some fuel smell after I did it but replacing the vac line to the carbon canister fixed that. You can see how deteriorated it is in the pics. I know the fuel lines were shot though for several reasons so I'm glad I did them. Car's running great now.
Thanks again, 1svtfan, you made things pretty simple with that set.
1995 Mustang GT Convertible AOD-E
Stock engine, gears, shocks, exhaust, TwEECerRT, some other stuff
ZoSo15 is offline
post #236 of 275 Old 07-15-2011, 11:59 PM
Ordered mine finally last week since my motor should be coming home soon... Got the fittings and they look great, the lines are on B/O until the 18th. So Late next week I should have mine assembled and ready to go on the car.
95 GT Convert|347 stroker
95 Cobra coupe|Rotrex supercharged|Sold
Former Dr.Gas X pipe distributor.
MRBiggs is offline
post #237 of 275 Old 10-14-2011, 04:22 AM
advent's Avatar
Finally I was install the lines but I'm have problem with the 5/16 fitting in the hard line. I had read that is necessary push hard and I did that , but when I grasped and pulled up hard the fitting , the white plastic clip stayed attached in tube and the fitting went out in my hand ...
How I know when the fitting is proper snapped ? And does the white plastic clip have do stay between the two flares in the tube ?
I just finished to pushed very hard the fitting and now with a moderate pull it seems to stay in place ... I’m not sure if it is proper seated ...
GT40X heads,RPM2 intake,Crane 2031,1.7 rr,BBK 70 tb,BBK equal shorty headers ,catted 2.5" H pipe,2.5"catback,42lbs inj.,bilstein struts,H&R Race springs,MM C/C plates,MM bumpsteer kit,steeda X2 balljoints,hurst shifter,Cobra brakes,Baer 13" rear brakes.
advent is offline
post #238 of 275 Old 10-15-2011, 07:34 AM
advent's Avatar
Well , it seems that it snapped in place now ... There aren't leaks and fuel pressure is ok . What a pain in the ass these -6AN to 5/16" tube adapters (duck-bill connector) ! The 1/4" one is much better design and much more secure !
I still don't trust in that fitting... If you pull a little hard the line , like I said before , the connector goes out and the white clip stay on the flare of the tube ... But it seems that this is normal ... Maybe I just worry too much ...
advent is offline
post #239 of 275 Old 10-23-2011, 02:37 PM
Are you talking about the return line not seeming to go on securely? Because I was concerned about that too when I installed mine yesterday. But then I thought about how it was fastened in stock form... which is basically the same as the fuel filter connectors and I've never had or heard of a problem with those popping off.
MRBiggs is offline
post #240 of 275 Old 10-24-2011, 04:50 AM
advent's Avatar
Yes , I was worried mainly because this type of connectors on stock fuel filter line and OEM fuel lines of others cars , don't need push hard and you hear the "click" when properly installed . But later , with a mirror, I saw that the connector is correctly seated and until now there aren't leaks and everything's fine .
Edit: And I was talking about the feed line (5/16 one) .
Anyway , I found other 5/16 russell connector with the same design of 1/4 line , with threaded cap in the bottom . It's a RUS-644110 (summit part number) . I bought one just for spare and mind tranquility .
advent is offline
post #241 of 275 Old 10-24-2011, 09:19 AM
TrickVert's Avatar
Guess I missed this. Whoops. Thanks for posting the link. The pre-made lines are a pretty close fit. It looks like one needs to be just a little shorter than the other to run together all the way back, but for the non-OCD, this looks like a good time/work-saving option.
Andy
post #242 of 275 Old 12-08-2011, 04:02 PM
Fragola Performance Systems 375024 says that it is a 24" hose. Is this correct? I want to make sure I get the correct one. part #375030 says it is 30". Will the 24" work or do I need the 30"? Thanks
95 Mustang GT Conv. -5 Speed, tri-ax shifter, asp pullies, BBK headers, magnaflow catted x-pipe, magnaflow cat-back, centerforce clutch, MM subframe connectors, alum. driveshaft, tokico shocks/struts, AFS cobra r’s(17x9/17x10.5), kaenan heat extractor hood, black cloth top, steeda HD swaybar
chaos2543330 is offline
post #243 of 275 Old 01-20-2012, 03:19 PM
98snakehorse's Avatar
Wow I wish I would have found this thread sooner. I currently have a turbo kit on my car and this would benefit me great as my downpipe runs direclty underneith my fuel lines. Will someone please get me a list of part#'s that I need to make this happen, down to the tool that I need to removed my old lines? I need to get this changed asap because of the dangerous heat they are exposed to. Thanks in advance,
Nick
98 Cobra_stock bs/exhaust [SOLD]
2000 s/c gt, 511rwh 450rwtq [SOLD]
1995 331 Turbo Gt, 420rwhp 498rwtq
1998Gt , PI SWAP + Bolts ons (Build in Progress)
98snakehorse is offline
post #244 of 275 Old 01-20-2012, 09:55 PM
Fuel lines
Andy
I personally used 30" line on both sides. the feed side is perfect but the return line is little long. But stick with 30" lines. Buy one 45* line and one 90* line for perfect fit. 90* will also help if you have tall valve covers
post #245 of 275 Old 02-07-2012, 12:02 AM
ram360's Avatar
Trader Feedback: (68)
Interested in a black set
Bad to the BLOWN!
ram360 is offline
