AODE Shifting problem - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 10-15-2009, 09:31 AM Thread Starter
MustangChuck's Avatar
Hey folks. I have a 95 GT with an automatic transmission. I recently started having problems shifting. When I am going at partial throttle, the car will hickup when shifting from 1 to 2 (kinda feels like it is either going into neutral then back to first or all the way to second and back to first, but happens too fast for me to really know what it is doing). After the speed/rpms go up a little more, it shifts fine from 1 to 2. At WOT, the shift is fine. When decelerating, the transmission will wait too long to shift from 2 to 1 -- usually it will do it at 300-400 rpms and nearly stall the car.
The problem happened suddenly. I drove it in the morning and it shifted fine. Drove it that evening and I started having problems.
I had searched and saw that some people have said that the MLPS (trans range sensor) will cause strange shifting problems. Others have said that the 1-2 accumulator and/or springs may cause similar problems. The transmission was rebuilt about 4 years ago and I've probably only put on 40k miles since then.
Just want to know what you folks think and where I should start looking.
Thanks,
Chuck
My budget makes a shoe-string budget look like Warren Buffett's personal checking account.
1969 Mustang Fastback (work in progress)
1995 Mustang GT Convertible (daily driver)
1994 Mustang GT Coupe (donor car)
MustangChuck is offline
post #2 of 10 Old 10-15-2009, 09:47 AM
Bullitt95's Avatar
That sounds pretty likely.
2006 GT Deluxe - 5MT - 12.67 @ 108.61
310rwhp 328rwtq with simple bolt-ons
Bullitt95 is offline
post #3 of 10 Old 10-15-2009, 09:07 PM
toyman's Avatar
The shift is determined by vehicle speed (VSS) and TB position. RPM is just a by product
That would be the first place to look.
Richard
KB 2.1L @ 9psi, FRPP M5400-A Suspension System, FRPP Aluminum D/S, Built AODE and TC, FRPP 3.73 Gears, Balanced Roller Cammed Engine, Edelbrock Performer Heads, Comp 270AH cam, AEM EMS, 3.5 Bar MAP, Zeitronix ZT-2 WB, FRPP 70mm TB, modified UPR CAI, Be Cool Aluminum Rad
toyman is offline
post #4 of 10 Old 10-17-2009, 09:20 AM Thread Starter
Is the VSS used for any other inputs in an automatic car? Just wondering if the VSS could be going out. I know the TB position sensor is used elsewhere, so I doubt that is the problem.
Where is the MLPS located? If it is in the transmission, is it accessible without dropping it?
Thanks,
Chuck
post #5 of 10 Old 10-17-2009, 10:40 AM
Bullitt95's Avatar
It's outside the transmission on the driver's side so it's fairly easily accessible.
post #6 of 10 Old 10-21-2009, 02:56 PM Thread Starter
Many thanks!
M/C
post #7 of 10 Old 10-21-2009, 03:37 PM
Davis3's Avatar
Trader Feedback: (25)
mlps is on driver side,just above the pan.
the shifter cable bolts up to it,cant miss it.
Davis3 is offline
post #8 of 10 Old 10-25-2009, 02:19 AM
edumspeed's Avatar
Thanks,
Chuck
The VSS is used just for that, speed reference for the ECM. The TPS can cause erratic transmission operation too, like it happened on my car beginning this year. It acts like a Throttle Valve cable, but electronic instead of mechanical. Mine started to hold and release 1st gear on D, then shifted normaly on D2 from 1st to 2nd, and stuck there even when shifting back into D until I hit 50+ mph, then when going into a stop, all the process started again Since the TPS is not too expensive, change it anyway since it takes a beating. Mine went for $40 in Autozone. No more tranny problems since then.
94 Mustang GT: 3 row aluminium radiator, CC plates, 03 Cobra front springs, Bomz intake, Flowmaster 40 series mufflers, cat delete, air pump delete, fox TRW forged pistons, Melling HV oil pump, fox camshaft.
06 mitsubishi lancer ls- DD
edumspeed is offline
post #9 of 10 Old 10-26-2009, 04:04 PM Thread Starter
Thanks for the input folks. I changed out the transmission range sensor and that didn't fix the problem. Since I didn't have it adjusted right (and didn't know there was adjustments to be made), I had it towed to the dealership (fearing they sold me a bad sensor). (Car wouldn't start -- starter wouldn't even activate.) They got it adjusted and I was talking with the tech. He feels it is more mechanical. He mentioned the torque converter three times as a possibility, as well as the accumulators and maybe a sticking valve. Sounds like a rebuild (again) is on the horizon.
M/C
post #10 of 10 Old 10-26-2009, 04:06 PM Thread Starter
On your back, in the driveway with only low profile ramps and jack stands, it's also pretty easy to smell (almost had my nose on it). Not terribly difficult to remove, if you have small hands. Just need to know that you have to line up the neutral line markings or the car won't start.
M/C
Tags
aode, shifting
