Car misfires when hot - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 05-10-2009, 10:54 PM Thread Starter
ReplicaR's Avatar
Got an interesting problem. Recently the car started misfiring when getting hot. What I noticed is that if I throw a new ignition rotor in it, the problem will go away for a few days, and come back doing the same thing. It's as if something is burning the rotor up.
I've changed Ignition coil, cap, rotor (several times), wires and plugs, but no luck in getting rid of the misfire. What can this possibly be?
94 Mustang GT. Stock.
ReplicaR is offline
post #2 of 7 Old 05-10-2009, 11:37 PM
liljoe07's Avatar
Trader Feedback: (18)
Make sure no fault codes are present first......
I hope everyone reads this. Whenever you car starts acting up, as long as it running, just pull the codes first. Don't throw money at a problem you not sure of. The ECM is full of useful info, so use it.
Now, it sounds like you problem is while its in closed loop. Or a heat induced wiring problem. But pull the codes first. Its free and easy to do.
89 Coupe: POS
Tuner: QuarterHorse, BE & EA, AEM Wideband
liljoe07 is offline
post #3 of 7 Old 05-11-2009, 12:46 AM
1trkpny95's Avatar
Trader Feedback: (41)
PIP sensor in the dizzy gets my vote. A.K.A magnetic pickup or stator.
'03 OW Cobra CPE 470/483
1trkpny95 is offline
post #4 of 7 Old 05-11-2009, 10:56 AM
BlackVert's Avatar
mine did that. turned out to be a bad spark plug wire that had been too close to one of the header tubes. i had equal length headers at the time and they had a tendency to burn up wires.
1995 Triple Black GT Vert ... 1971 351W block 410ci, AFR 205s, AOD, TwEECer ... FOR SALE
1967 Black Fairlane GTA Vert ... stock
BlackVert is offline
post #5 of 7 Old 05-11-2009, 11:09 AM
MFE
Super Moderator
MFE's Avatar
Check/restore/add to all your grounds.
MFE is offline
post #6 of 7 Old 05-11-2009, 11:27 AM Thread Starter
ReplicaR's Avatar
Any links to where the grounds are in the engine bay?
ReplicaR is offline
post #7 of 7 Old 05-11-2009, 12:16 PM
1trkpny95's Avatar
Do you really think it's a ground? You can also take the armature off(it's the little wheel the rotor sits on) and clean it up with some sandpaper. If the "teeth" are rusted or chipped it could cause a problem.
