Best Spark Plugs For Mild Stock 5.0 . - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 25 Old 10-25-2008, 12:59 AM Thread Starter
Lookin into changin my cusin plugs what would be the best to run on his full bolt on 5.0
What are a good number to gap them at? .40?
2000 Black Gt stock with bolt on's +Hi Tech Stage 2 Cam's
304RW/317TQ
2001 Black Cobra
SS-Bassani Catback
Saint is offline
post #2 of 25 Old 10-25-2008, 10:49 AM
94CobraPace's Avatar
Gap them at factory gap of .053".
NGK's are good. For a good cheap plug, cannot beat the Autolites.
2010 Shelby GT500, Kona Blue W silver stripes.
2007 Shelby GT500, Vista Blue with Tungston gray stripes, 1 of 119, Wifes car...
94 Cobra Pace car Convertible # 591
2001 Cobra vert # 2001 SOLD
94CobraPace is offline
post #3 of 25 Old 10-25-2008, 09:17 PM
Regular Motorcraft ... i have tried several others and they dont compare to Motorcraft!
2003 Ford F-250
7.3 Powerstroke Diesel, SCT Tuned, 34.5" Tires/4" Lift
1994 Mustang GT
X-pipe, Cam, Bassani Headers, Cobra Rims, Mac CAI
mus1994stang is offline
post #4 of 25 Old 10-25-2008, 11:43 PM
mike early's Avatar
Autolites. I'd still buy them if they cost 5x as much as they do.
I've tried too many others to remember.
1994 GT 5spd: Track Heat Heads, Track Heat Intake, FTI Camshaft, TFS 1.6 RR, Mac LTs, ProChamber, Borla XS, C&L 76, 24lb injectors, 70mmTB, pulleys, 3.73, Bilstein BTS package, Eibach sway bars, MM panhard bar, Pro 5.0, Cobra brakes front and rear. 306. Stock ECU.
mike early is offline
post #5 of 25 Old 10-26-2008, 08:23 AM
95cobraguy's Avatar
Trader Feedback: (73)
cant go wrong with autolites, they're cheap and u can find them anywhere and they work.
95 Cobra #1679
Copy and paste link for my 363 thread
http://forums.corral.net/forums/5-0-5-8-engine-tech/1283537-fordstrokers-363-pics.html
95cobraguy is offline
post #6 of 25 Old 10-26-2008, 09:05 AM
TTOPCPE's Avatar
Trader Feedback: (49)
I use autolite 25s in all my 5.0s.....for the 94-95s I've been gapping them between .045 and .048 instead of the factory .052/.053
TTOPCPE is offline
post #7 of 25 Old 10-26-2008, 10:44 AM
homer302's Avatar
Plain, cheap Autolites. Dyno proven results and they are only like $1 each.
Don't even get the Platinum ones, just the plain copper ones.
'94 GT5.0 5speed, 170,000 mile long block, GT40, FRPP headers, 65mm TB, Pro 5.0, 3:55s, pulleys, Flowmaster, BBK X-pipe, FRPP Cobra front AND rear brakes, Tokico 5-way Illumina struts and shocks, Eibach springs: 235 rwhp, 291 rwtq.
04 Screaming Yellow Cobra - pretty much stock.
458 rwhp, 435 rwtq.
homer302 is offline
post #8 of 25 Old 10-26-2008, 12:15 PM
TTOPCPE's Avatar
Actually $1.95 each
TTOPCPE is offline
post #9 of 25 Old 10-26-2008, 12:19 PM
Formerly 9dpony
Funford's Avatar
X2
I use motorcraft plugs with my blown setup
Funford is offline
post #10 of 25 Old 10-26-2008, 11:59 PM
SilverSmith82's Avatar
Trader Feedback: (26)
Autolite 25s for a stock 5.0 all the way. Regular version, no platinum, no fancy crap just the cheapest ones.
-2000 Mustang GT Steeda #0048. Going 4V, IRS swap in progress, original Novi 2000 car.
SilverSmith82 is offline
post #11 of 25 Old 10-27-2008, 01:48 AM
92stanggt5.0's Avatar
Autolite Copper plugs
25's for my fox bodies
3094's for the Cobra
dont quote me on the number for the Cobra right now though.
I only fouled out the plugs once in the Cobra but it was my fault.
85 octane + 120 deg weather + stop and go traffic in Vegas + 14 deg advan = fouled plugs
1995 Cobra white/tan and a T64
92stanggt5.0 is offline
post #12 of 25 Old 10-27-2008, 12:41 PM
millhouse's Avatar
Originally Posted by Funford View Post
X2
Which are identical to the Autolite versions….as that’s who makes them.
I’ve had great luck with NGK’s….although my application is a tad bit different.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #13 of 25 Old 10-27-2008, 07:20 PM
homer302's Avatar
Originally Posted by TTOPCPE View Post
Actually $1.95 each
You must not know anyone that works at the store so are getting hosed!
Ha. It's been a while since I bought 'em and I was taking a guess. I was way off I guess.
458 rwhp, 435 rwtq.
homer302 is offline
post #14 of 25 Old 10-27-2008, 07:55 PM
Ryno8705's Avatar
I just put autolite 25s ($1.64 each) gapped at .054 in my 94 GT last week and they solved my missing problem. I've read that some people have had good luck gapping at .045-.050, but I just stuck with the Ford specs for now. I had NGK UR45s for the last 2 years and ~9000 miles. I don't know what happen to the NGKs because they all visually checked out but for less than $15 I took a chance and just replaced them. I'm going to guess that somehow one of the NGKs grounded out or the insulation cracked and I just couldn't see it. Either way, I searched a while trying to find a good plug, just as your are, and I found that most people leaned toward Autolites 25s in a 5.0 GT. I only have 150 miles on them but no complaints either.
1994 Mustang GT Convertible. - YMR# 8045
Moates QH & BE/EA, J4J1/CBAZA, LC-1, 306, GT40s, TFS1, SVO Intake, #24s, MAC headers/catback, Bassani X, MM CC plates+springs+SFCs+LCAs, K&N, KYB shocks+struts+quads, MGW shifter, tires:245 F/275 R, 3.55 gears, FRPP Alum DS, Centerforce DF
Ryno8705 is offline
post #15 of 25 Old 10-27-2008, 11:49 PM
The autolite Cobra plug is the 764.
post #16 of 25 Old 10-28-2008, 02:18 PM
I knew I was off. Dang memory is slackin.
post #17 of 25 Old 05-05-2009, 12:20 AM
Mildy stock with Heads Holley intake TB long tubes pulleys 93 onctain 14~ * timing
Best bang sounds like Autolites, eh? I have a 95 Cobra 5.0L 302
autolite 764 huh ?
psychotuner is offline
post #18 of 25 Old 05-05-2009, 02:46 AM
1trkpny95's Avatar
Trader Feedback: (41)
autolite 764 huh ?
YES, Autolite 764's are for the Cobra's. I'm running Autolite 3924's gapped at .044'' in my 185's.
Do you have GT40 heads or aftermarket?
'03 OW Cobra CPE 470/483
1trkpny95 is offline
post #19 of 25 Old 05-05-2009, 03:00 AM
kbernal1016's Avatar
Trader Feedback: (27)
which autolites should i get for my gt40p heads? the heads are decked .020" for higher compression btw...
gap?
89 Mustang LX 5.0 Coupe, C4, stripped, etc.
95 Mustang GT 5.0, IRS, 3550, etc.
03 F150 FX4 Supercrew 5.4, Lariat, lifted, etc.
06 Focus ZX4 2.0, MPG!
kbernal1016 is offline
post #20 of 25 Old 05-05-2009, 09:03 AM
Where can you get the Autolight 764's shipped international?
bcLVSn95 is offline
post #21 of 25 Old 05-05-2009, 09:52 AM
Corral Charter Member
Cobra Jet NJ's Avatar
Trader Feedback: (40)
did you try here:
http://www.sparkplugs.com
OR here:
www.rockauto.com
- Phil
1994 Cobra coupe SVT #0013, 2016 Mustang Fastback Premium EB/PP
Cobra Jet NJ is offline
post #22 of 25 Old 05-05-2009, 10:44 AM
Id normally use the Motorcraft plugs...but this time around Im going to try the NGK V-Power plugs, see how they work out...
2dxtrm is offline
post #23 of 25 Old 05-05-2009, 11:23 AM
liljoe07's Avatar
Trader Feedback: (18)
At least no one suggested the E3 or Split Fire plugs. LOL
liljoe07 is offline
post #24 of 25 Old 05-05-2009, 11:56 AM
LAPS 5.0LX's Avatar
As mentioned Autolite makes the Motorcraft plug. I always used the Motorcraft plugs(Even in my procharged BB Chevy boat motors). I switched to the Autolites because the coldest Motorcraft gasketed plug was a 32series, Autolite racing plugs go down 3 to 4 ranges from the Ford plug and there racing plugs (AR series) work great and are cheap(heavy body,cut back electrodes). This same conversation is going on in the 5.0/5.8 forum. If you spend a little time on Autolites web site you can find out a ton of info. In a HP application a colder plug is a better plug.
If its a NA car with tappered seat heads go with the Motorcraft AGSF 32C, or Autolites cross referenced on that #. The AR plugs are an impressive plug though, under $4, and easy to get, Summit carries all of them.
LAP
Proud owner of a family of fine Fords:
1989 5.8 Vortech Coupe, 2005 6.0 Eddie Bauer Excursion, 2006 Explorer Limited V8
LAPS 5.0LX is offline
post #25 of 25 Old 05-05-2009, 12:50 PM
Just found out that Autolite 764s are now Autolite 104. Just a number change. That's it.
