TFI module: use dielectric compound or heat-sink compound - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 35 Old 12-04-2007, 09:20 AM Thread Starter
Dean Scheidt
SLO 5-OH's Avatar
Trader Feedback: (53)
The Advance Auto guy said I should use silicone dielectric compound on the connectors and the flat metal surface of the TFI module. He pulled a TFI module from the shelf and it comes only with silicone dilelectric compound, which is clear. The two times I've removed a TFI module if had a white compound on it that looks similar to heat-sink compound used for heat generating electronic components.
Isn't the purpose of the large metal-to-metal area to provide heat dissipation for the TFI module? If so, does silicone dilectric compound transfer heat as well as heat-sink compound?
Regardless, does anyone know what I should use on the flat metal surface of the TFI module where it contacts the metal body of the distributor?
1989 Mustang GT - original owner
1/8-mile: 6.57 @ 102.67
1/4-mile: 10.40 @ 128.13 (1.37 60')
425 RWHP:
, TW 205 heads, tmoss TFS Box-R intake,
AOD,
8" converter, 4.10's, Team Z Suspension, M/T 26" ET's, full interior, 3,340 lbs race weight. Tuned by Willie at
SLO 5-OH is offline
post #2 of 35 Old 12-04-2007, 10:40 AM
cevtv's Avatar
White heat-sink compound.
1992 Titan. Frost Met. Coupe (1 of 253) T-5. Cobra intake, FRPP 65mm TB, Pro-M 75mm, Pro-5.0 shifter, SPEC Stage 1, 3:73 gears, Fiore FWA, FRPP shorties, H-pipe, Flowmasters , CGS subs, Team Z Street Beast arms, March pulleys, Moroso CAI, 3G Alt., FRPP Al. rad., Lakewood 70/30's, Strange shocks.
cevtv is offline
post #3 of 35 Old 12-04-2007, 10:42 AM
gadget73's Avatar
The Ford manuals say to use silicone dielectric compound, but thermal paste would also work fine. Guess it doesn't matter all that much
86 Lincoln Town Car
5.0 HO,FMS 1.72 roller rockers, BHPerformance ported E7 heads, Explorer intake, Hedman shorties, 2.5" dual exhaust with Impala tailpipes, traction lock with carbon-fiber clutches, 4 wheel disc brakes, ASP underdrive pulley
91 Mark VII LSC SE - triple black, all stock
gadget73 is offline
post #4 of 35 Old 12-04-2007, 12:11 PM
Dustang83's Avatar
White thermal compound
'93 LX Hatch - 331
'79 Fairmont Futura Sport Coupe - Novi 1k
'67 Comet Caliente Hardtop - 76mm on3 302
Dustang83 is offline
post #5 of 35 Old 12-04-2007, 12:29 PM
Joel5.0's Avatar
Either will do.....
ACRONYMS:
LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S***
1986 Mustang GT w/T-Tops
NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears
WIP: 3.90 Gears(Motive Performance), LS Overhaul (FRPP), Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), Caster/Camber Plates (MM), Subframe Conn. (MM) T-Top weatherstriping and rear braces bodywork
Joel5.0 is offline
post #6 of 35 Old 12-04-2007, 01:16 PM
You can get it from Radio Shack. Thats where I got my last tube http://www.radioshack.com/product/in...entPage=search
gnvair is offline
post #7 of 35 Old 12-04-2007, 01:19 PM
silicone di-electric compound has doesnt last long enough. In Ford FACT training we were instructed to you white thermal compound AKA heat-sink compund.
96 GT- Complete 4v swap, 4.10's
93 GT- Traded
97 F150-PI swapped.
Fastfox400 is offline
post #8 of 35 Old 12-04-2007, 02:40 PM Thread Starter
Dean Scheidt
SLO 5-OH's Avatar
I am going to Radio Shack to get their heat sink compound. Thanks for the responses.
425 RWHP:
AOD,
SLO 5-OH is offline
post #9 of 35 Old 12-04-2007, 03:05 PM
You use heat sink compound. Its amazing how many manuals have it wrong.
Delectric grease is just for electrical connections. Keeps them from corroding.
Im really not sure who was the moron who started telling everyone to use dilectric grease on modules. But that has got to be one of the biggest myths in the auto maint industry
"Socialism is inseparably interwoven with totalitarianism and the object worship of the state. It will prescribe for every one where they are to work, what they are to work at, where they may go and what they may say. Socialism is an attack on the right to breathe freely."
-Winston Churchill
TommysCarbd86 is offline
post #10 of 35 Old 12-04-2007, 04:53 PM
gadget73's Avatar
I always thought it was supposed to be thermal compound as well, but my factory Ford manuals say dielectric grease. I guess they revised that at some point, these are 85 and 86 manuals after all.
86 Lincoln Town Car
gadget73 is offline
post #11 of 35 Old 12-04-2007, 06:13 PM
stangPlus2Birds's Avatar
Nope. They are used for very different reasons. Using Dielectric grease instead of thermal compound is just plain wrong. Dielectric grease can boil, run, "evaporate", etc. Thermal compound stays through out temperature cycles and doesn't "boil" off (unless the parts light on fire ).
With the above said, when working on a car, I've used Dielectric grease when I should have used thermal compound because I have Dielectric grease handy in my tool box (small tube). And, having "some" protection for the metal (from oxidation. rust, etc) is better than nothing.
But, for the TFI, using Dielectric grease is not a good idea at all. The TFI gets too hot. The Dielectric grease *will* "go away". Plus, it "could" then even leave a film on the heat-sink which would reduce it's ability to transfer heat to the distributor.
Also, for a PC's CPU's heat-sink, using Dielectric Grease instead of Thermal Compound is another way of saying "I want to buy another CPU soon".
Joe
MS Elec Engr /Comp Engr
semi-Mech Engr
stangPlus2Birds is offline
post #12 of 35 Old 12-05-2007, 09:40 AM
nos8ed's Avatar
Part# SL203 from Autozone
90 GT 331 C4 11.370@118.84
1993 Cobra Black
nos8ed is offline
post #13 of 35 Old 12-05-2007, 10:11 AM
white99gt's Avatar
I use artic silver thermal paste on my tfi.
Current: 2013 GHIG BOSS 302 447rwhp~390rwtq
90LX 301rwhp~331rwtqSOLD
99 2V 2.2KB GT: 608rwhp~542rwtq SOLD
2v t-trim combo:621rwhp~504rwtq
white99gt is offline
post #14 of 35 Old 12-05-2007, 10:24 AM
And the answer is .......
Thermal compound.
Artic Silver Thermal paste is a good example. The entire purpose of putting some thing on the back of the TFI module is to disapate heat and keep thre TFI from burning up. If I'm not mistaken Ford changed where they mounted the TFI to keep engine heat away from the circuit inside.
Mike-89Sport is offline
post #15 of 35 Old 12-05-2007, 10:41 AM Thread Starter
Dean Scheidt
SLO 5-OH's Avatar
I tried searching the AutoZone website and couldn't find this part number.
Also, where can I find artic silver thermal paste? I've seen this product mentioned in other threads.
425 RWHP:
AOD,
SLO 5-OH is offline
post #16 of 35 Old 12-05-2007, 12:08 PM
88Brawler's Avatar
Radio Shack carries Arcitc Silver. I just bought some there about 2 months back.
88Brawler is offline
post #17 of 35 Old 12-05-2007, 12:09 PM
nos8ed's Avatar
It's not on their website, but I made a phone call to make sure they still have it. This is what Wells puts in the box with the control modules they sell. The SL203 is a box with about 3 or 4 packets in it. I t sells for 99cents. You may have to tell the dumba$$ @ the counter it is in the ignition section or Wells section.
1993 Cobra Black
nos8ed is offline
post #18 of 35 Old 12-05-2007, 12:32 PM Thread Starter
Dean Scheidt
SLO 5-OH's Avatar
Last question, I promise.......
I checked the Radio Shack site and found two Arctic Silver products listed:
Arctic Silver - Silver 5 for $9.99 (Radio Shack # 28-1099)
Arctic Silver - Ceramique for $6.99 (Radio Shack # 28-1098)
Which one are you guys using?
425 RWHP:
AOD,
SLO 5-OH is offline
post #19 of 35 Old 12-05-2007, 02:34 PM
Either one will work
Ceramique has some properties that might be of benefit to sophisticated electronics components but for our application, a TFI bolted to a distributor, both are equal.
post #20 of 35 Old 12-05-2007, 02:46 PM Thread Starter
Dean Scheidt
SLO 5-OH's Avatar
Thanks for all of the informative responses.
425 RWHP:
AOD,
SLO 5-OH is offline
post #21 of 35 Old 12-07-2007, 06:34 PM
No more Radio Shacks in Toronto.
This heat sink stuff isn`t cheap here.
A local computer store has OCZ Ultra 5+ silver thermal compound for $7.99cdn for only 3 lousey grams.What a rip.
Auto parts stores don`t carry the stuff.
8950HO is offline
post #22 of 35 Old 12-07-2007, 08:15 PM
white99gt's Avatar
Thats not a bad price..Plus you dont need as much as you think..I have a 3 ounce tube that has lasted me thru 6 computers and my TFI module with some left over..
post #23 of 35 Old 12-07-2007, 08:45 PM
I said 3 grams.
1 gram = .0352 ounce
So if you have a 3 ounce tube that would be roughly 85 grams.
1 ounce = 28 grams
I hate the metric system .
8950HO is offline
post #24 of 35 Old 12-07-2007, 09:20 PM
You can also buy thermal compound from newegg, SCUM tigerdirect, or digikey.
Here, if you buy 5,000 of them, you can get 2oz for $5.45 each.
http://search.digikey.com/scripts/Dk...me=345-1007-ND
post #25 of 35 Old 12-07-2007, 09:28 PM
white99gt's Avatar
I said 3 grams.
1 ounce = 28 grams
SOrry i typed it wrong.I meant 3 grams (actual tube is 3.5 grams).
The 3.5 gram tube contains enough compound to cover a layer 0.003" thick, the 3.5 gram tube will cover approximately 16 square inches.
post #26 of 35 Old 12-07-2007, 09:39 PM
...."SCUM" tigerdirect is the place I`m referring to for 3g for $7.99cdn.
Why does this stuff cost so much for so little?
The syringe looks so much bigger in the internet pics compared to what they give you,I was like wtf is this?LOL
8950HO is offline
post #27 of 35 Old 12-07-2007, 09:46 PM
white99gt's Avatar
Read what its made for:
http://www.arcticsilver.com/as5.htm
post #28 of 35 Old 12-07-2007, 10:33 PM
I know the main use is for computer useage,but people have been using dielectric grease for years on TFI`s and I rarely read of any failures unless it`s a pos aftermarket TFI module like an Accel.
When I took my original TFI off there was hardly any heat sink or whatever the factory used and it was dried out and hard.
I put dielectric grease on it and reinstalled it 2 years ago.
This original 18 year old TFI module has 113,000 miles on it.
8950HO is offline
post #29 of 35 Old 12-07-2007, 11:31 PM
white99gt's Avatar
Why is a accel a POS? Ive been running one almost two years with no issues.
I think most TFI's aftermarket or other wise die because of other internal distributor issues.Or one that was installed improperly.
post #30 of 35 Old 12-08-2007, 12:11 AM
I tried an Accel TFI module for a short while.
I figured I`d replace my high mileage original TFI module for something new.(mistake)
It crapped out after low mileage use.
The car still ran,but the timing wasn`t being advanced with the spout connector in place,and the car felt like a dog accelerating.
Installing the original Motorcraft TFI fixed the problem.
A mechanic on my local forum mentioned a high failure rate with Accel TFI`s.
Check your ignition timing with the spout connector in place to make sure it`s bouncing all over the place at idle like normal to be sure with the Accel TFI.
8950HO is offline
post #31 of 35 Old 12-08-2007, 12:26 AM
white99gt's Avatar
If it starts feeling doggy ,i may check that..But right now,its still has enough pep to go sideways in 2nd.
post #32 of 35 Old 12-08-2007, 12:42 AM
kd7cwg's Avatar
Works great.
http://search.ebay.com/search/search...ty=MetaEndSort
86GT with 5 LUG and some other fun parts
13.05@102.55 I'd add the youtube url, but It don't let you do that!
THE FUSION HAS BEEN REPLACED BY AN 88 TC!!!!!
kd7cwg is offline
post #33 of 35 Old 12-08-2007, 12:44 AM
gadget73's Avatar
Had the same thing happen to me. Died at an intersection with no warning, module had well under 10k on it. Cop pulled up behind me and was nice enough to stop traffic while his partner helped me push the car across the road to the gas station. Then he let me use his cell to call my stepdad to bring my spare distributor with the old module on it. Still running it actually.
One of my friend's customers also had one of those Accel modules #### the bed not long after mine. Had about 5k miles on it at most, then it just quit for no reason.
86 Lincoln Town Car
gadget73 is offline
post #34 of 35 Old 12-08-2007, 02:34 AM
Yeah,the Motorcraft TFI`s are the best quality.
Pop the cover and the electronics inside the Accel look like a joke compared to the Motorcraft TFI.
I think the pos Accel is probably made in China.
8950HO is offline
post #35 of 35 Old 12-08-2007, 09:07 AM
cevtv's Avatar
You can get it at Best Buy, too.
http://www.bestbuy.com/site/olspage....=1075583463530
cevtv is offline
