#1 |
Trader Feedback: (25)
Not getting injector pulse.
so my car quit on me at a light the other night. i've been using Joel5.0's troubleshooting guide, but would like some other input as well. i've got good fuel pressure, its 43psi with the key on. when i turn the key off it bleeds down, but i dont know whats normal. it will bleed to 30psi in less than 5 mins, the 25psi in about 10, then 20psi in about 20. the pump has never quit whining with the key on though, even before the probs. it will whine all day if you let it with the key on. im getting visible spark at the plugs, and the car fires on starter fluid. the red wire on the injector plug lights my test light, but when i use the test light converted to a noid light it doesnt blink when turning the motor over. i am going to pick up a real noid light today and test it tomorrow. i plan on cleaning the salt and pepper shakers tomorrow. i've been told it could possibly be the TPS, or the TFI, or the PIP. when i try to start the car with the TPS unplugging and feathering the trottle it still wont start. i may buy a DVM and test some things if nothing else works.
heres the original thread that got me to this point. good background info on the issue: http://www.corral.net/forums/showthr...injector+pulse quick notes: car wont start getting spark (starts on starter fluid) good fuel PSI No injector pulse |
| Sponsored Links | |
Advertisement |
#2 |
Trader Feedback: (224)
check and make sure all the terminals are still intact in the salt and pepper connectors.
__________________
1989- gt full drag build in progress.. 1991- emerald coupe- stroked, caged & sprayed 1999 cobra- 5.0 stroker and single turbo coming soon |
#3 |
I apologize in advance for saying things that you probably already know. I'm just trying to help you talk through the whole thing.
Fuel pressure bleeding down that quickly may not be normal, but it's not hurting you now. The fuel pump is supposed to run only a second or so to prime the system when you first turn the key on. If the engine is not running, but the fuel pump is, then either the computer somehow thinks the engine is running, or perhaps the fuel pump relay is mechanically stuck in the on condition. An LED type test light would be better than a regular light bulb type test light because the LED will show far shorter pulses - either off or on - than a regular light bulb. You could be getting spark, but at the wrong time if the computer or TFI module, or some other part is whacked. But of course that doesn't explain how it starts with starter fluid. |
#5 |
TFI or PIP
__________________
The Wagon Queen Family Truckster. You think you hate it now, but wait till you drive it. 89 Country Squire: 96 Explorer Motor, XE264 cam, 24lb injectors, 80mm MAF, '03 Marauder airbox, BBK headers, 2.5" exhaust, underdrive pulley, 3.73's, trak-loc, aluminum driveshaft, big 4 wheel disc brakes, poly bushings, '02 PI steering box, wide ratio AOD, 2400 stall, Lots of suspension work. You did what with that wagon??? Autocross??? (stock 157K engine & suspension) NEW Vid 9/9/06 HERE! (short vid) Full vid here |
#6 |
will the TFI take a #### out of no-where like that? it was running one second at the light, and the next it dies and wont start again. can i take it to autozone and have them test it? also, how can i check the PIP. i know its inside the distributer, but is there anyway of testing if its bad?
#7 |
yes, the TFI will take a random dump. Testing them is a joke, because they will work cold, and heat up and fail again. There is a way to test the pip, but I don't have any of my books handy.
It's good to have a spare TFI, and most ford owners I know carry spares... I do. Amusingly, I also had my car die and fail to restart and it was the fuel filter.
__________________
#8 | |
because money is extremely tight right now, i dont want to just start throwing parts at the car. i read if the TFI is bad, the car will fire with the spout out? any truth to this? will try it tomorrow. |
#9 |
thinking out loud here, could it be a moisture related issue. this was the first time the car has been in the rain since i started driving it regularly. but it has been 4 days since it died and its still not sarting, wouldnt the moisture have evaporated by now?
#11 | |
Trader Feedback: (41)
if you pull the spout you take the EEC computer out of control of the spark timing - it leaves the PIP and TFI to run the engine at base timing. Do it just to eliminate the EEC which I doubt it is. If you replace the TFI, replace the PIP too or vice-versa even though money is tight.
__________________
Tom Moss 88GT Vert 5spd 3:73,Crower 15511 @ 110,70mm MAF w/19# injs,70mm TB,GT40P 1.85/1.55,Jet-Hot P headers, H pipe w/dumped Flows (no more drone),Holley SMII intake.www.fastlanecars.com http://tmossporting.0catch.com/
#12 |
Take the control module to a local parts store and have it tested (you will need a tool to take it off). Make sure to put heat-sink compound on it when you put it back. At least you can determine/eliminate that possibility.
__________________
90 GT 331 C4 11.370@118.84 1993 Cobra Black |
#13 |
took the spout out, still no fire. so does that eliminate my EEC as the problem? im going to go clean my salt and pepper shakers, will respond afterwards. if no go, then ill have my TFI tested.
#14 |
Go to the junkyard if money is tight and swipe one in your tool box.lol
__________________
1989 Fox 408W TT build in progress. 1986 SVO, 26k miles, one owner car! 2005 Suzuki Hayabusa |
#15 |
i did the salt and pepper shaker fix, still nothing. took the injector ground off and cleaned it good, scuffed the chead to make sure it was touching metal. bought a noid light kit, and the ford one didnt fit, but the GM one did good, i dont think the make should matter, as long as it fits? didnt flash. im getting a little frustrated with it, may just put it in the shop.
#16 |
I had this exact problem once. There is the module on the side of the distributor. It was actually fine.
The part inside the distributor that it plugs into went bad. Tells the computer when to fire the injectors. You have to take your distributor apart and replace that module. They should sell one at the parts store.
__________________
1990 Mustang GT Dart IE 363, PT78 HPS, Built 4R70W, BS3, BBRC Fuel system, TeamZ, ect..... Tuned by Bob Kurgan |
#18 |
the pick up coils are about 20 and the tfi module are about 40 i had a lot of trouble with the tfi module when i first got my fox and have had to replace quite a few in other 5.0s
if you hve to replace your tfi make sure you have a socket thin enough to fit down the hole since they are recessed |
#19 |
If getting fire but no spark the pip is working and it is probly the module. Would not get fire or injector pulse if the pip was out. Module takes a thin 5.5mm or special tool also available at parts store.
__________________
2004 SVT Screaming Yellow Cobra 11.98 at 115 at Bristol K&N FIPK, 2.8"pulley, 3" ultra flows, MGW orange handle shifter, LFP cooling mod, Affco heat exchanger, and few other little things. |
#21 |
Sounds like a strait forward problem,
test your modules! it is free, after that we may be more helpful! It it most definitely fuel related since it fires up with starting fluid. You have SPARK and no FUEL. Yet your fuel pressure is good at the rails soo.....start turning wrenches... |
#22 |
My car did have fuel pressure, but not much. Sounds like PIP.
__________________
#23 | |
#24 |
Test both modules, it is free, and I believe they are both very easy to remove.
__________________
1995 Mustang GT 306 c.u.i TFS Heads, Vortech Intake,75mm MAF, 75mmTB, 30lbers, 255lph, ZEX, TweecerRT,LC-1..lots of extras
#25 | |
also, i thought if the PIP was bad that you wouldnt have spark? Last edited by Got Booost?; 11-27-2007 at 08:12 PM. |
#26 |
PIP is used for coil and fuel injectors pulse genration.
If you have spark, PIP is OK within the TFI module confinement...... you only need to verify the PIP signal is traveling to the ECM for the fuel pulse part. When you started the car and kept it idling with the SPOUT connector on, this usually means the PIP is traveling to the ECM and coming back through the SPOUT, with the timing advance added otherwise, the engine wouldn't run even if you use carb cleaner. Suggest to confirm the PIP pulse is present at the correspondent ECM pin (#56)......a LED from Radio Shack will allow you to confirm this if it blinks, connect red LED wire to PIP pin/wire at the ECM connector, and the yellow (negative) LED wire to a good ground and crank the engine.....if the LED blinks, PIP is OK.... if not, check wiring........and do the PIP check described at the end of this procedure..... LUK
__________________
ACRONYMS: LUK=Let Us Know, GL=Good Luck, LMK=Let Me Know, JIC=Just In Case, BTSTDTRT=Been There Seen That Done That Repaired That, YCYDYP=Your Car Your Dough Your Prerogative and the classic... DILLIGAS=Do I Look Like I Give A S*** 1986 Mustang GT w/T-Tops NOW: 5.0L Stock shortblock, X303 Cam, SP Offy. Port-O-Sonic, 700 cfm DP Holley, 289 '66, 1.7 RR, Richmond Gear 4+1 Trans., Centerforce DF kit, 2.73 Gears WIP: 3.90 Gears(Motive Performance), LS Overhaul (FRPP), Adj. LCA's (New Design Granatelli Aluminum), Adj. UCA's (Granatelli), Caster/Camber Plates (MM), Subframe Conn. (MM) T-Top weatherstriping and rear braces bodywork
#27 |
yup it was the ECM, swapped a new one in and the car runs better than ever. exhaust note is alot more agressive sounding, and louder. isnt as hollow anymore. car runs much smoother too. shifts are now seemless without focusing too much on clutch/gas. also seems to pull a little better from a stand still in first.
thanks guys. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
