#1 |
Trader Feedback: (156)
anderson n-51hr cam
i am new to this site but hang out hear once in a while, also on mustangforumns, well i heard a while back someone on here was runnin the anderson n-51 cam,i would like to know how u liked it and how did it perform any sound clips?
i am lookin at this cam or the n-41 i am building a 306 w/9.5 flattop probes,twisted wedges,rpm 2, 30 lbs inj,along with full boltons, also have a zex 100/125 wet kit for when its broke in and then a blower later. thanks jason(the new guy ![]()
| Sponsored Links | |
Advertisement |
#2 |
Moderator
Trader Feedback: (128)
N-51HR
I'm not sure if you are talking about me or what...But I'm running the afm N-51HR cam in my DD ('90 LX).
My current "engine" combo consist of the following... 308ci roller block bored .040 over 10:4.1 comp with 59cc chamber GT-40 iron heads fully ported with ferrea valves with a comp valve job afm hi-rev springs N-51HR cam GT-40 tubular intake with ported lower 70mm bbk tb/spacer kirban fpr 30lb fms injectors 95mm pmas meter calibrated to the 30lb injectors...I just swaped this meter for a 80mm afm powerpipe 4" This whole combo has only about 400 miles on it, so NO dyno numbers yet... As for drivability... It's a little soft below 2k, but once the tach reaches 2300-2400 rpm it pulls hard all the way up to 6400-6500 rpm...I have a rpm extender on this car, and the a/f is set at 12.5 It has a slight rough idle...it idles at 850-950 rpm. My future plans for this car is to replace the heads, and intake for... Ported edelbrock 60229's heads, and a extrune hone rpm 2 intake... Luis.
__________________
| Sponsored Links | |
Advertisement | |
| Bookmarks |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
