Installing Intake manifold: does anyone use the fel-pro rubber end seals in the kit? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 36 Old 11-25-2007, 10:46 PM Thread Starter
Just wondering what most people do to install the upper and lower intake manifold?
polerstock is offline
post #2 of 36 Old 11-25-2007, 10:51 PM
kwikstang's Avatar
Trader Feedback: (43)
Some do...some don't.
Do a search on "installing lower intake" and you'll get a ton of info on this subject.
Good luck!!
92 GT 5sp w/ Thumper ported GT40s, Cobra intake w/TMoss ported lower, Crane 2031, On3 70mm, AIS water/meth, AFM PMS, flashACQ
stocking out 11/13
kwikstang is offline
post #3 of 36 Old 11-25-2007, 11:17 PM
memphis306's Avatar
i just clean the block real good,run a bead of blue rtv across with extra rtv where head and block meet.wait 20 minutes or so until the rtv gets slightly tacky and drop the intake on.
memphis306 is offline
post #4 of 36 Old 11-25-2007, 11:22 PM
Trader Feedback: (40)
Personal opinion:
Ditch the rubber end seals and pick up a can of "The Right Stuff" RTV style silicone from a local parts store supplier.
Modular is offline
post #5 of 36 Old 11-25-2007, 11:25 PM
Moderator
03 DOHC's Avatar
Trader Feedback: (139)
RTV...
03 DOHC is offline
post #6 of 36 Old 11-25-2007, 11:32 PM
Britanski's Avatar
Noooo! and some others are cork. Those inserts can blow-out, sometimes.
Get a can of Permatech "The Right Stuff", or other quality silicone and run a thick bead at the front and rear. That's all you need.
Then put it on and bolt it down.
That's it.
Mike
'91 Mark VII SVO - 347, H-beams, AFR 185's, X-303, Trk Heat intake, A5 Tranny, 24# inj, 76mm meter/TB, 3.73s, Shortys, X-Pipe, 2-1/2 Flowmaster 40's, HD sway bars, Poly's & more... visit - lincolnsvo.com
'10 Escalade - Driver
Britanski is offline
post #7 of 36 Old 11-25-2007, 11:32 PM
RacinNdrummin's Avatar
RTV all the way, the end seals eventually WILL leak, no matter if they are the cork or rubber ones. The silicone just peals off when you change manifolds and completely seals the ends.
79 Fairmont ES 2dr sedan- 3.3L/T5/TC rear 3.73/cobra R's/5.0 brake conversion
RacinNdrummin is offline
post #8 of 36 Old 11-25-2007, 11:52 PM Thread Starter
i had already bought the RTV just wondering if it was necessary but it seems like it is. thanks for the help
post #9 of 36 Old 11-25-2007, 11:54 PM
sam92lx's Avatar
Trader Feedback: (31)
Clean both front and rear of the block good and lay down a NICE and THICK line of RTV.
Speed Productions
2004 Cobra - Future UltraStreet Radial car.....Turbo 4v/th400 in the works.
sam92lx is offline
post #10 of 36 Old 11-25-2007, 11:55 PM
the stock seals suck and can cause int leaks when milling has been done, I always throw them in the trash and use RTV.
htwheelz67 is offline
post #11 of 36 Old 11-26-2007, 08:48 AM
tmoss's Avatar
Trader Feedback: (48)
I use the silicone rubber seals all the time with a dab of silicone at the head on each end - never had a leak yet.
Tom Moss
tmoss is offline
post #12 of 36 Old 11-26-2007, 08:51 AM
Me too. The silicone rubber seals work GREAT! I tried the RTV instead of the silicone gaskets and the RTV didn't seal for me. I think the silicone gaskets are a much better way to go.
DO NOT use cork, though. Those things are crummy.
Hack is offline
post #13 of 36 Old 11-26-2007, 09:23 AM
Puter's Avatar
I use the rubber seals, yet throw away the cork ones. The rubber ones I have found have locating tabs that keep them from "blowing out". Never had any leaks. Prepped with a finger of oil (like any rubber seal) and they work great.
84 GT and 85 GT convertible - http://community.webshots.com/user/puter_pics
carbedMustang Mailing List Owner - http://autos.groups.yahoo.com/group/carbedMustang/
Puter is offline
post #14 of 36 Old 11-26-2007, 09:36 AM
lone sailor's Avatar
Trader Feedback: (38)
Ultra Black Permatex.
lone sailor is offline
post #15 of 36 Old 11-26-2007, 09:43 AM
Rightstuff here. Been using it for a long time. Before that it was Ultra Black. Would never use any manufacturers end seals as they all eventually start leaking. Using RTV atleast gives you a semipermanent bond. Only times it wont work is when the beads arent thick enough, the intake and block are still oil (and not clean) or the person installing it slid the intake and smeared the bead.
gnvair is offline
post #16 of 36 Old 11-26-2007, 10:16 AM
Big Top GT's Avatar
Trader Feedback: (37)
Do you guys use the RTV in lieu of a gasket across teh front, or are you laying down a bead, putting on the gasket, then dropping on the manifold?
I assume the RTV IS the gasket, right?
I'm putting my 5.0 back together later this week, so this is a nice refresher.
It's been a LONNNNGGGGG time since I've had to do this. (Since I moved to a modular...)
Thanks,
Alan
98 Cobra Coupe ~ Back to square one: no motor.
2006 Lotus Exige - 1.8 litres of Supercharged fury!!! SOLD!
Originally Posted by ATOMONKEY
If you don't want to take my word for it, maybe you'll believe the internet.
Big Top GT is offline
post #17 of 36 Old 11-26-2007, 10:20 AM
Michael Yount's Avatar
For me - first choice is the rubber seals - clean/smooth surfaces, lubricate the seals with a bit of light grease. Second choice - completely coat the cork version (lightly) with high temp rtv. Last choice - a bead of RTV. If you've had the heads/block/intake milled -- a bead of RTV may be your only option.
Michael Yount is offline
post #18 of 36 Old 11-26-2007, 02:43 PM
JimsYellow88's Avatar
Trader Feedback: (46)
I've ALWAYS ditched the end seal gaskets and used a nice thick bead of RTV copper instead. Like others have said, let it tack up for 20 minutes then drop the lower intake straight on. Torque the bolts and let it sit over night before you fire it up. No worries.
Jim
88 GT, Street Car, Dart Block 331, YS-Trim ,TKO
649 RWHP! 565 RWTQ! (on 93 octane, Mustang Dyno)
10.79 @130 MPH (Old S-Trim combo)
**Member of the 2-piece Stock Block Club**
JimsYellow88 is offline
post #19 of 36 Old 11-26-2007, 03:29 PM
gadget73's Avatar
I've used the rubber ones that are made into a sort of C shape to keep them sitting on the block ends with good results so far. Just a dab of RTV in the corners where it sits against the intake to head gasket and no problems. The cork ones I throw away and use RTV.
86 Lincoln Town Car
5.0 HO,FMS 1.72 roller rockers, BHPerformance ported E7 heads, Explorer intake, Hedman shorties, 2.5" dual exhaust with Impala tailpipes, traction lock with carbon-fiber clutches, 4 wheel disc brakes, ASP underdrive pulley
91 Mark VII LSC SE - triple black, all stock
gadget73 is offline
post #20 of 36 Old 11-26-2007, 03:56 PM
I used the rubber ones with some silicone in the corners.
They work great.Fel-Pro should include them with every set,not just the ones for stock heads.
8950HO is offline
post #21 of 36 Old 11-26-2007, 03:59 PM
bgjohnson's Avatar
I guess I'm a minority here. I used the cork ends because they stay in place better than worrying about the RTV sealing all the way around. I also use CAT high tack sealant that is like cement, they will never leak with that stuff.
1989 Fox 408W TT REbuild in progress
1979 Yamaha xs1100 restored
1996 splode sport 5spd. Slut beast.
bgjohnson is offline
post #22 of 36 Old 11-26-2007, 05:44 PM
Ok, ok - I BRAZE the manifold to the block. No leaks. No disassembly. Just throw the motor away and put a new one in when there's a problem....like most everything else these days.
post #23 of 36 Old 11-26-2007, 06:19 PM
Thanks,
Alan
I use it in the front and the rear of the lower intake in place of the gasket. When it's applied correctly and given the recommended time to cure it works great.
post #24 of 36 Old 11-26-2007, 07:05 PM
stoksuks's Avatar
Rubber end seals here.No leaks after 1 1/2 yrs.
1992 Gt 306,K.B. hyper pistons ,cobra intake & gt-40 heads,b-303 cam,24# FRPP inj,PMAS maf sensor,FRPP shorties, cobra hood & rear bumper, & so on.in other words moneypit.
stoksuks is offline
post #25 of 36 Old 11-26-2007, 08:23 PM
11Bravo's Avatar
I think I counted 3 "Right Stuff"
I make four and besides the Right Stuff the only other sealant I use is Yamabond. BTW on the virgin 89 I just pulled down the rear gasket wasn't even making good contact on the block from the factory!!!
Almost forgot, some folks have been dimpling the blocks sealing rails with a center punch for years to hold both the gaskets from moving.
11Bravo is offline
post #26 of 36 Old 11-26-2007, 08:30 PM
sabciu's Avatar
I've used both, rubber and cork but always with a bead of silicone. Never had a problem with either so I'm not partial to any of them. The trick is to get the silicone and gaskets situated properly. Good luck!
92 5.0 LX Convertible
302 bored .030 over
Heads-Mild Port
Roller Rockers, triple valve springs, ARP bolts and Studs, mild S.C. cam by COMP CAMS, Cobra upper and lower with spacer, 65MM T.B., 77MM Pro-M mass air meter, 30LB injectors, 3 core alum. radiator, 3.73 Richmond gears, Steeda springs, steeda upper & lower
cntrl. arms, Vortech V2-SQ supercharger, MSD-6BTM ignition, BBK equal length headers, BASSANI X-Pipe w/cats, 2.5" Flowmaster exhaust, Tremec TKO trans., SPEC STAGE II clutch, aluminum drive shaft.
sabciu is offline
post #27 of 36 Old 05-23-2008, 09:12 PM
GTmustang00's Avatar
how thick does the bead have to be? i layed it 1/4 inch and it didn't seem like it pushed out much.
98 Chrome Yellow cobra 9800 miles
1989 Mustang GT, modified to hell
GTmustang00 is offline
post #28 of 36 Old 05-23-2008, 09:16 PM
metalman302's Avatar
Trader Feedback: (173)
I was wondering the same thing.... how thick of a bead for RTV only?
metalman302 is offline
post #29 of 36 Old 05-23-2008, 09:48 PM
Rich G's Avatar
Trader Feedback: (35)
I love the little rubber gaskets, they are C shaped so they grab the edge of the block... I blew out my rear seal 3 times, twice with RTV only and once with cork + RTV, finally I put the rubber seal on and it worked perfectly
Rich G.
Rich G is offline
post #30 of 36 Old 05-23-2008, 10:18 PM
With which gasket set does the rubber/silicone ends come? Is this the Ford-sourced one?
BornInAFord is offline
post #31 of 36 Old 05-23-2008, 10:29 PM
FN RCKT's Avatar
RTV here.
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. -
Thomas Jefferson
FN RCKT is offline
post #32 of 36 Old 05-23-2008, 10:53 PM
The rubber/silicone ones come in the Fel Pro MS93334 intake gasket set for stock heads for one source.
This intake gasket set contains way better intake gaskets than the crap paper Fel Pro 1250 intake gaskets.
I`m not sure but the silicone/rubber end seals may be available separately from the Ford dealer-check with them to find out.
8950HO is offline
post #33 of 36 Old 05-24-2008, 12:30 AM
Trader Feedback: (27)
im another one for the right stuff. i used ultra-black the first time, and did about a 1/4 inch thick bead and had one spot with a very slight leak. second time used the right stuff and layed it on about the thickness of a pen and no leaks what so ever. my heads have been milled slightly though, so my intake sets down a little lower.
Got Booost? is offline
post #34 of 36 Old 05-24-2008, 01:22 PM
93mustank's Avatar
Trader Feedback: (133)
+1
www.facebook.com/FoxBodyPerformance
93mustank is offline
post #35 of 36 Old 05-24-2008, 03:02 PM
MurPHy4570's Avatar
I used the cork gaskets. I installed them DRY on a CLEAN sealing surface, with a small daub of Motorcraft grey aerobic silicone sealant where the gaskets meet at the ends. I have had zero problems.
Cork works very well, if you use it correctly.
"Our Country! In her intercourse with foreign nations, may she always be in the right, but our country right or wrong."
- Commodore Stephen Decatur, Norfolk, Virginia, April 4, 1816
MurPHy4570 is offline
