Oil coming from spark plug hole??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 10-18-2007, 12:38 PM Thread Starter
Blk85GT T-top's Avatar
Hey guys,
My car has been smoking for the last few days from under the hood (the smell of oil on the exhaust). Well, after thinking that I had a valve cover leak, I got out and watched the motor as it was running and saw oil dripping down from the spark plug boot and onto the header. I also saw the spark plug from that same boot kinda wiggling around slightly...obviously it needs to be tightened which I will do when it cools down, but should oil be coming outta there? Thanks!
Black 1985 GT w/T-tops chrome cobra r's, performer rpm, edelbrock carb (bought it that way!), etc...
Blk85GT T-top is offline
post #2 of 7 Old 10-18-2007, 06:56 PM
gadget73's Avatar
um, no. If the cylinder has that much oil that its pushing past the plug threads, you've probably got other issues. Are your plugs oil fouled, or do you have oil burn problems?
86 Lincoln Town Car
5.0 HO,FMS 1.72 roller rockers, BHPerformance ported E7 heads, Explorer intake, Hedman shorties, 2.5" dual exhaust with Impala tailpipes, traction lock with carbon-fiber clutches, 4 wheel disc brakes, ASP underdrive pulley
91 Mark VII LSC SE - triple black, all stock
gadget73 is offline
post #3 of 7 Old 10-18-2007, 07:00 PM
sounds like you got a bad ring
89 347stroker is offline
post #4 of 7 Old 10-18-2007, 09:41 PM Thread Starter
Well, just did an oil change about a week ago and just had to add half a quart already. When I pulled the plug, there wasn't that much oil buildup on the electrode, it was a little black - but not drenched in oil. There was more oil and sludge buildup on the threads of the plug. Kinda confused - this doesn't look good, huh?
post #5 of 7 Old 10-19-2007, 07:03 AM
Trader Feedback: (48)
No reason 2 B confused..If oil was seeping/coming out of the plug hole the cylinder would probably B DEAD(Dead miss).Obviously the gasket is leaking & slowly running down into the plug hole or some blowby is misting a small amount of oil out the spout & running down to plug hole!!!A 3D choice(MOST LIKELY) would B someone was filling oil through the oil fill spout & spilled some..I'd check the rest of the Spark plugs & make sure they r tight also!!!
midnightrider is online now
post #6 of 7 Old 10-19-2007, 01:44 PM
Does the car burn oil, as in, blue smoke out the tail pipes? If not, then its probably coming from the valve cover, or like midnightrider said, could be some that spilled a little while filling. Also, if you had ring, or valve guides/seals to leak that much oil out, you would be burning a ton of oil and would be smoking(out the tailpipes) like crazy.
'89 Notch: 3O4, Novi 2K/12psi, TFS heads, TFS Stage 1 cam, Cobra Intake, Tremec, Spec Stg. 2, C springs, Konis,MM CC plates, Cobra brake conversion w/ Bullitt wheels, and more crap. 12.621@118.87 with no tune- New BBK Long tubes, x-pipe and Tweecer RT and 436rwhp/432rwtq.
Blown85GT is offline
post #7 of 7 Old 10-20-2007, 01:17 AM
MurPHy4570's Avatar
Valvecover gasket is prolly leaking above it.
"Our Country! In her intercourse with foreign nations, may she always be in the right, but our country right or wrong."
- Commodore Stephen Decatur, Norfolk, Virginia, April 4, 1816
MurPHy4570 is offline
