Best year 302? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 09-26-2007, 04:54 AM Thread Starter
Best year 302?
Yeah, what year should I pick for my new engine, '86-'95?
And why?
Background:
I'm building myself a really fast street-/strip- car and I need a place to start. In the end I'll need a new block and everything but for starters I want a suitable engine to begin with. I want to get a aftermarket EFI and It'll probably take a while to get the hang of it. No need to blow up a $15000 engine due to bad tuning and general n0ob mistakes.
Plus I'll have a running car while building the freak engine...
MarkusG is offline
post #2 of 11 Old 09-26-2007, 05:02 AM
sinisterGT's Avatar
86-95? All are thin cast blocks and will cost no where near $15000 to build. It would be a good idea to start with a good foundation like a dart, world, or boss 302 casting.
306, e303, gt40x , frpp 1.6rr's, GT40, 70mm tb, 80 mm pmas, frpp 42lb inj, walbro gss340, t-rex, msd 6 btm, BBK Longtubes, off road X, Mac cat back, vortech sq trim, snow boost cooler, pms and zt-2
478 rwhp @6000 new numbers soon
421 ftlbs @4100
sinisterGT is offline
post #3 of 11 Old 09-26-2007, 06:58 AM Thread Starter
Ehrrr, well no...
I'm planning on using a Dart Aluminum race block later on with a lot of goodies. That will be the $15000 build.
The stock 302 (the one I'm asking about) will be used to try out the new EFI and to keep the car running while I work on the other engine.
MarkusG is offline
post #4 of 11 Old 09-26-2007, 09:43 AM
Neomustangz's Avatar
1969 302
Or a Mexican roller block. <---im not trying to be funny.
-87 Mustang GT Boss 363 Stroker, JE Pistons Eagle Crank-Rods, AFR 205s, TFS R Box TKO 600 PT7675 CEA Turbo, Stainless Turbo KIT
-90 Blk Mustang GT On3 Turbo Stock Block/Cam 540HP 585 TQ Mustang Dyno 10.33@134 5speed
-90 Blue GT On3 Turbo Stock Block/Cam 539HP 602 TQ Mustang Dyno 10.72@132 5speed
Neomustangz is offline
post #5 of 11 Old 09-26-2007, 11:57 AM
And you havent even built your first engine?.....
If this is your first kick at it...buy a fresh stock 302..tinker, blow it up, buy another one...tinker, blow it up...
Until you eventually learn what you want...and that way you will NOT have alot invested in your education...
Perryk is offline
post #6 of 11 Old 09-26-2007, 11:57 AM
gadget73's Avatar
86+ blocks are all basically the same, no real difference one way or the other. The factory pistons differ a bit from year to year, but if you're rebuilding it half the time it'll need to be bored and the pistons will become ashtrays or scrap metal anyway.
86 Lincoln Town Car
5.0 HO,FMS 1.72 roller rockers, BHPerformance ported E7 heads, Explorer intake, Hedman shorties, 2.5" dual exhaust with Impala tailpipes, traction lock with carbon-fiber clutches, 4 wheel disc brakes, ASP underdrive pulley
91 Mark VII LSC SE - triple black, all stock
gadget73 is offline
post #7 of 11 Old 09-26-2007, 02:27 PM Thread Starter
I have built engines before, just no V8.
That's why I'm getting the 302, to have an engine in the car and a way to experiment with the EFI (and maybe some other crazy ideas?). At the moment I have a car but no engine.
As for the tinkering bit... I'll have plenty of time for tinkering while I get the rest of the car figured out. The engine is actually the easy part.
MarkusG is offline
post #8 of 11 Old 09-26-2007, 05:01 PM
MurPHy4570's Avatar
Best 302 Ford ever built:
You won't find any for cheap.
Get any stock 302 engine from the junkyard, they're all the same after 1975. If you want SEFI, stick with the 86-01 ones.
"Our Country! In her intercourse with foreign nations, may she always be in the right, but our country right or wrong."
- Commodore Stephen Decatur, Norfolk, Virginia, April 4, 1816
MurPHy4570 is offline
post #9 of 11 Old 09-26-2007, 06:44 PM
quick50mustang's Avatar
Trader Feedback: (15)
Originally Posted by Neomustangz View Post
1969 302
ive always wanted to know what the differnce is between an "american" 302 and the "mexican" 302? any one got an explination?
quick50mustang is offline
post #10 of 11 Old 09-26-2007, 07:57 PM
dan50's Avatar
And why?
Background:
Why do you want aftermarket EFI? What's wrong with the stock mass air EEC with a TwEECer?
Why have you chosen a budget of $15k for your next engine? Why not just pick a performance goal? You can run 10s in the 1/4 and make good turns on the track for a lot less than $15,000. Put $6k into the engine and the rest into the drivetrain and suspension.
If you're new to Fords, the 5.0 has been around a long time, from 68 to 01. Instead of telling you the "best" year, how about you tell us the application? It's hard to go wrong with buying an 89-92 V8 Mustang so you've already got the engine, wiring, chassis all put together for you. If you're sticking this into a Civic, well, then maybe a 5.0 isn't the "best" thing to do.
Dan
2015 Dodge Challenger 392 Hemi
1983 Bronco XLT 351W sleeping until 2018...
1991 Mustang GT 5.0 SOLD!
dan50 is offline
post #11 of 11 Old 09-26-2007, 08:29 PM Thread Starter
With Autronic sm4 I get fully sequential fuel and spark. I can controll everything and use a map + tps sensor as opposed to mass air.
Easier to set up, less fragile and it looks good.
If I can do it ceaper I'll be a happy man but I estimate $15000 to be a realistic number.
I do have a performance goal: mid 9's in the 1/4.
Enginewise that should equate to +700bhp give or take some? It all depends on traction...
The drivetrain and suspension is getting a major overhaul as well. Heck, I'm rebuilding the entire car from the ground up.
Street-/Drag- car, Cobra II body with custom spaceframe chassis. (Or back halved car at least)
Dan
No, not a civic.
How come you picked the 89-92 engines/cars?
MarkusG is offline
