HELP car won't start after Head Gasket change - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 05-31-2007, 11:44 PM Thread Starter
Okay,
My 88 LX Vert blew a head gasket. I replaced both head gaskets along with new upper and lower intake gaskets, ARP head bolts and valve cover gaskets. So, After putting everything back together I tried starting the motor and it just turns over but does not start. I checked the ignition coil and have good spark. I checked and double checked all the connectors and vacuum lines and still nothing!!
Is there anyway to check if I am getting fuel into the injectors without taking off the upper intake again?? (ps my fuel pump is turning on when I turn the ignition to the on position).
Any other suggestions would be appreciated.
1995 GT 302 Vortech S-Trim- MM Suspension
1989 Fox 392 Stroker Ford "R" Block - Full GR40 Griggs Suspension
95CALI-5.0 is offline
post #2 of 11 Old 06-01-2007, 12:32 AM
cobradvm's Avatar
How did you set up the dizzy when you put it all back together? DId you set the rotor pointing to just before the #1 plug with the #1 cylinder at TDC? Double check firing order as well.
cobradvm is offline
post #3 of 11 Old 06-01-2007, 06:29 AM
what ^^^^^ said
i guess that its either the distributor is not in right, the firing order is wrong, or the timing is out.
double check those items before anything else.
2014 Mustang Shelby GT500, SGM stripe delete
speedin' is offline
post #4 of 11 Old 06-01-2007, 06:35 AM
Darksyne's Avatar
In before someone tells him he installed the distributor a tooth off.
92 5.0 Notch - DJG, T5, Factory A/C & Radio Delete, P/S Delete, 17x8/17x9 Bullitt Wheels, Bullitt Springs, MM C/C Plates, Bilsteins
Darksyne is offline
post #5 of 11 Old 06-01-2007, 08:56 AM
stangbanger87's Avatar
got to be timing issue!
-Randy
1990 GT "Black Beauty"
-Randy B
stangbanger87 is offline
post #6 of 11 Old 06-01-2007, 12:29 PM
Moderator
Ehardy1971's Avatar
another vote for timing!
'89 LX Coupe
GT40 306 with a few bolt ons and in the 12's
'01 Lightning
#6257 of 6381 Bolt ons, pulleys, and tuned.
'06 TBSS
K&N drop in, and Borla dual exhaust, for now.
Ehardy1971 is offline
post #7 of 11 Old 06-01-2007, 01:12 PM
Jimmies's Avatar
Very likely to be a timing issue, even among experienced mechanics. I've done it plenty. Have you pulled a plug or 3 to see if you're getting spark when cranking it over?
"Don't waste your time, or time will waste you."
Jimmies is offline
post #8 of 11 Old 06-01-2007, 08:06 PM Thread Starter
Thanks everyone,
The firing order is correct. I'll check the dizzy this weekend.
post #9 of 11 Old 06-02-2007, 09:27 AM
wifehatesit's Avatar
distributor timing problems are over-complicated many times. heres what u do-
bring the #1 cylinder to tdc on the compression stroke..(rotate engine with finger over spark plug hole till u feel compression, then just line up the timing marker with the 0 degree mark on your balancer)
then just rotate the distributor til the rotor is just before the #1 cylinder.. about 1/4" should be good.
and thats it. no problems. no "one tooth off" crap or other problems. have your timing light ready and when she starts up, time it exactly where u want it.
if its don't start now, then its not your timing. start looking at fuel problems or over tightened valves.
-86 GT Convertible 306 w/4.88's & Weiand Supercharger - 10.23, 72 Buick Electra 455 w/offset Crank & NOS - 10.90's
-93 Honda CBR 900, -90 Suzuki Quadracer 500 2 Stroke 'Zilla
-03 Honda 400EX...Wife hates 'em all!
wifehatesit is offline
post #10 of 11 Old 06-05-2007, 07:22 PM Thread Starter
Did exactly what you said. Started right up!!!
Thanks everyone
post #11 of 11 Old 06-05-2007, 09:46 PM
Jimmies's Avatar
Fantastic! Glad it was something simple - I really had a feeling it was.
Jimmies is offline
