1993 Cobra w/ B303 cam:What length pushrods? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-12-2007, 03:58 AM Thread Starter
jcg9777's Avatar
Trader Feedback: (51)
Just like the title says. I have a 93 Cobra, motor is stock except for a FRPP B303 cam. I want to be sure that the pushrods (stock) that were used were the proper length when this cam was put in (By previous owner). So my question is what length pushrods are needed with this cam in the 93 cobra motor (1.7 rockers, etc.). Will the stock length pushrods work? Any input or experiences are welcome. Thanks in advance.
1991 Coupe: Dart Sportsman 331, AFR205's, Holley Systemax, Hellion T76 turbo kit, TKO, PMS and other extras.
1993 Cobra: 52K, Black/Grey cloth #4740, SOLD
jcg9777 is offline
post #2 of 6 Old 05-12-2007, 04:06 AM
Yes, they will.
'89 Notch, AFR 165 minor porting, Comp XE282, RPM2, 75mm Accufab, 24lbs. injectors, you know the rest
SHIFTY50 is offline
post #3 of 6 Old 05-12-2007, 04:10 PM
Michael Yount's Avatar
The valve train on these cars are only marginally adjustable. Anytime a camshaft is changed, you should use a pushrod length checker to determine the proper length pushrod to use. If the stock block/heads haven't been cut, then the stock pushrods may work -- the B cam is designed with the same base circle dimension as the stock HO and Cobra cams. However, you won't know for sure until you check. If the stock pushrods turn out to be a bit too long, it's easy to shim the rockers up in .030" increments. If, on the other hand, optimum geometry indicates that they're too short - then you'll have to order longer pushrods.
Lastly -- what happened in someone else's application even with the same parts isn't predictive of what's gonna happen in your engine. When you start measuring things down in the hundredths and thousandths of an inch, every engine/combo is unique - even those running the 'same' parts.
Michael Yount is offline
post #4 of 6 Old 05-12-2007, 07:46 PM
Trader Feedback: (15)
very well said Michael. A few hundredths might as well be a mile in valvetrain geometry. You should check no matter what when you change anything
BigPimpin' is offline
post #5 of 6 Old 05-13-2007, 03:27 AM
vristang's Avatar
check the length.
It will be worth the time / effort
jason
- jason
1990 GT - something 351w based... some day
vristang is offline
post #6 of 6 Old 05-13-2007, 11:24 AM
89Justang's Avatar
If you are wondering I believe the stock pushrods are 6.27"
89Justang is offline
